X3 E83 (2004 - 2010)
Talk about the E83 BMW X3 in this forum! |
BlitzSafe XM Radio
Has anyone heard of/tried/installed a BlitzSafe XM radio in their X3? Apparently this is a very inexpensive way to get XM Radio in your BMW and control it with the sterring wheels controls. Here is some more information:
http://www.xm411.com/phpbb/viewtopic.php?t=1804 & http://www.myradiostore.us/ I read through the forum and on the product site but I still have some questions. Do I need the Satelie pre-wiring in order to make this happen? Also, I've read that you HAVE to use the supplied antenna and can't use the shark fin antena on the X3. If that's the case then what antenna is used on the factory installed satelie radios? My X3 is still on order so I can add the pre-wiring if I need to but I think I'd only do this if I could use the existing shark fin and not have to add another antenna. Any ideas? |
No takers! No one has any advice on this product?
XM Direct is currently incompatible with navigation. BlitzSafe says they're working on it, but they've been saying that for quite some time. The XM Direct kit comes with the adapter, receiver, and antenna. So at least some of the stuff you'd get with Sat Radio Prep isn't useful / necessary. In cars where the CD changer doesn't mount in the trunk / hatch area, Prep gets you the wires you need back there. You'll almost definitely have to install the antenna you got with the XM Direct kit (or another XM antenna) in order to pull in a signal. I haven't run into any Sirius antennas that work for XM (or vice versa). Depending on what you want to listen to, you might want to consider using Sirius instead of XM. My first experience with Sirius was when I got "stuck" with it in the wagon, since XM Direct doesn't work with NAV. I discovered that I like the programming on Sirius much better. Sirius provides a 3-day "test drive" pass to listen to their music channels over the Internet if you want to see what they offer. I don't know if XM does the same. BTW, I have a new-in-the-box XM Direct kit for BMWs (with the CD changer passthru) if you (or anyone else) is interested. |
xm411.com site are accurate. It took 35 minutes to put in car and have preview channel. about 15-20 minutes to hide the antenna wire. still have to tie the xmdirect box to the passenger seat so it isn't on the floor. activated online, and xm satellite!!!! I am blown away by the ease of using this through the factory head. when you "mode" around it comes up SIRRIUS...then says XM...then channel info. Everything works as advertised. stores 18 presets (sat1, sat2, sat3--each with 6) scans work. holds its own EQ for satellite. I find the quality excellent on the factory installed speakers, better than FM or CD's. only complaint is the "audio level" of xm is all over the place. channel to channel and xm cut-ins. Just drove over to Tampa and it was a joy. fllbmw |
The antenna is very small, fits between sharkfin and hatch. Not very noticeable. all wiring is in center console, at cd changer location. order version for cd changer if you plan to add one....or not, same price. I lease, so the cost of prewire and the sirrius receiver was too much. xmdirect/blitzsafe was reasonable for 3 years and removeable.
fllbmw Quote:
Shark Fin Antenna will work with XM Direct
You want to connect the black antenna wire with the blue connector to the XM box. < -T 2004 X3 with Sat Ready Radio Last edited by Sonoman707; 06-16-2005 at 10:09 AM. |
Jeff
2005 X3 3.0, Mystic Blue Metallic, Sand Beige Leather Interior, Birch Grain Light Wood Trim, Steptronic Transmission, Premium Package, Heated Seats, Privacy Glass, Satellite Radio Prep, Xenon Adaptive Headlights, Heated Steering Wheel, Premium Sound, Power Folding Mirrors and NAVIGATION RETROFIT |
Not exactly "pretty" I suppose... but it is all hidden behind the removable panel and is secure with no rattles. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| FS: XM Radio setup for (almost) ALL BMW models (incl XM tuner, CD changer & adapter) | TD | Classifieds | 1 | 07-11-2004 08:32 AM |
| Blitzsafe Interface and XM Delphi Roady??? | wooldogg | Car Audio & Electronics Forum | 3 | 06-03-2004 06:16 AM |
| Blitzsafe Adapter for XM radio to BMW 96-03 | tthomasjr | Classifieds | 0 | 04-28-2004 06:47 AM |
| 96-present Blitzsafe adapter w/Pioneer XM radio recevier and antenna | E46CollegePunk | Classifieds | 0 | 03-11-2004 08:17 AM |
| XM Radio installed | skyehill | 3 Series / 4 Series | 43 | 03-19-2003 05:17 PM |
