Old 04-16-2005, 07:36 AM
qmac qmac is offline
Mein Auto: 1999 523
Removing E39 head unit
Would someone be so kind as to guide me through removing a non-DSP head unit on a 1999 523 in order to install an ICElink.
Many thanks
Old 05-11-2005, 01:38 PM
pimpwagon pimpwagon is offline
PimpWagon
Mein Auto: 525 Sport Wagon
Head Unit Removal
This worked for my 2001 525T (blitzsafe/logjam conversion for iPod). Remove volume knob (pull straight out). You'll then see a small torx or allen head, turn 1/4 to left, not too hard though. That's it, lift from the side and pops right out. There's nothing to that head unit.
(send me a pm if you need more help)
Why Brag When You Can Show Off?!?
Old 05-12-2005, 03:24 PM
Charlutz Charlutz is offline
Mein Auto: 1998 540i6
One you release that first torx, the MID will pop out and reveal two more torx. Unscrew those and it will release the tape deck/in dash CD/radio unit. Sorry, just nitpicking about the term "head unit" since the radio/amp is separate from the MID.
Old 01-25-2008, 08:00 PM
ablack3d ablack3d is offline
Mein Auto: St. Louis
Pimpwagon,
What happens when you push the torx screw too hard? When I did it I may have and it got pushed back. Now it seems there is nothing I can do to get that torx screw forward and therefore I am unable to pull the head unit out.
Please help!
Old 01-25-2008, 08:26 PM
cn90 cn90 is offline
I wrote this DICE install recently and here it is:
http://www.bimmerfest.com/forums/sho...ight=cn90+dice
Old 11-06-2009, 04:29 PM
Ron Stygar's Avatar
19,585 Miles
Many thanks
Try a 2.5 mm Allen hex key.
http://www.unofficialbmw.com/all/ste...oval_tool.html
Old 11-06-2009, 04:53 PM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Mein Auto: 99 528iA
January, 2008?
'99 528i ('98/12 build). 282,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals, increasing amounts of duct tape and glue
'99 540i (grandfather's)
Old 11-06-2009, 10:10 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
See this and that ...
Old 05-12-2010, 05:20 PM
abhipong abhipong is offline
Mein Auto: London
Help - cannot remove the head unit
I am trying to install a Dension Gateway on my e39 1997 Business unit.
I followed the instruction and failed at the first step. I tried turning the first Torx screw under the volume control 90 degree CCW. There was a bit of resistance so I put a bit more force in and felt something snapped.
There is now just a bigger hole where the screw used to be and I can't seem to pry open the unit.
Any idea please?
Old 08-03-2010, 11:30 AM
Dimson Dimson is offline
Mein Auto: BMW X5
Hi. I have exactly the same problem. The screw fell out and I cannot pull out the MID. Anybody knows a way around?
Old 08-03-2010, 12:15 PM
AnotherGeezer's Avatar
AnotherGeezer AnotherGeezer is offline
Entwicklung 39
Mein Auto: 2003 530i/5
Knowing exactly what you're doing before you break expensive parts helps immeasurably.
Old 08-03-2010, 02:14 PM
Gian's Avatar
Gian Gian is offline
Mein Auto: '14 535d, '02 530i
I may have done this too. I can still see the screw when I remove the volume knob. However, when I try to loosen it, it just spins and spins. I took it to my local dealer to see if they could help. They called their main guy from the back and he had no idea how to remove the unit in the e39. What the...?
It seems easy, but I think I screwed it up.
Old 08-03-2010, 03:53 PM
chiefwej's Avatar
chiefwej chiefwej is offline
Freude am Fahren
Mein Auto: 2003 540i/6 //m-tech
It is a spring catch. It is not screwed in. You just have to turn it less than 90 degrees to release it, then the MID just swings out. To put it back, you just push it in, and it snaps right in. If you turned the "screw" more than 1/4 turn (90 degrees) you have broken it. Don't blame the excellent engineered design for your mistake.
chiefwej 2003 540i ///m-tech 6-speed
Black Sapphire Metallic w/gray
Old 09-21-2010, 12:25 PM
tordy tordy is offline
Mein Auto: E39 525iM M-sport -02
I've done the same mistake. Did you managed to get it out somehow?
It cant be impossible
Old 12-10-2010, 01:29 PM
davidbridgman davidbridgman is offline
Mein Auto: 2005 BMW X5
I have the same problem. Has anyone found a solution to get the head unit out if the screw is broken?
Old 12-10-2010, 09:41 PM
bluebee's Avatar
I think the referenced threads have had folks post how they solved this problem.
- DICE Silverline radio-mount instructions (1) (2) (3) & how to remove just the MID (1)
BTW, the screw only has to be turned 90 degrees counterclockwise, so, it's actually hard to break it.
I guess people turn it more than a 1/4 turn for some reason.
Old 12-12-2013, 10:35 AM
karlman karlman is offline
Mein Auto: BMW E39 523i
Hi,
Old 10-06-2015, 07:40 PM
rbelton rbelton is offline
Mein Auto: E39
Here's a quick DIY video on removing the radio face and cd player:
Similar Threads
Does my '00 e39 head unit have aux inpt? smuniak Car Navigation, Audio & Electronics by BAVSOUND 2 10-04-2005 01:09 AM
FS: OEM E46 Coupe Head light Unit with projector lens and Xenon System Hamann330i Classifieds 0 04-26-2002 09:15 AM
BMW's 3 channel diversity FM reception with aftermarket head unit? jaisonline 3 Series & 4 Series 5 03-26-2002 11:59 PM
FS - ALPINE CDA 7965 Head Unit ((MINT)) Clem Classifieds 0 03-05-2002 08:39 AM
Head unit replacement Mr. E General BMW Questions 20 01-03-2002 11:11 PM
