E60 (2004 - 2010)
Old 04-18-2005, 01:35 PM
vern vern is offline
Send a message via AIM to vern
Mein Auto: 01 330ci 05 530i 06 X3
Motion sensor
Do you check the motion sensor by lowering the windows,setting the alarm and then passing your arm through the open window?If so my alarm doesn't go off.What could be wromg?Software again? TIA
vern
Old 04-18-2005, 01:47 PM
Ågent99's Avatar
Ågent99 Ågent99 is offline
Moderator 5-Series
Mein Auto: Trek 6500 MTB
Yeah, that works quite well on my E39 and I imagine it should work on the E60 as well.
Just to be sure, you can also turn off the motion sensor after you normally arm the car by pressing the roundel for about 2 seconds. You'll see the big red nose hold steady for a second and then go back to blinking. This is your indication that you just turned off the motion sensor.
Now, open a window, arm the car as usual. Now wait a few minutes and toss a tennis ball inside or put your arm through the window. You should trip the motion sensor.
If not, I would wait a bit longer and try again...you get 3 tennis balls per can!
Otherwise, I would guess you are correct and the s/w is suspect or it could be a h/w problem...dealer time as you surmise....
Old 04-18-2005, 03:14 PM
I tried your suggestion and every thing worked fine.I guess I didn't wait long enough,( a few minutes),Before passing my arm through the open window.THANKS
vern
Old 04-18-2005, 03:18 PM
Ågent99's Avatar
Moderator 5-Series
Excellent...glad you are a-okay!
Old 04-18-2005, 04:26 PM
TGray5's Avatar
TGray5 TGray5 is offline
Ultimate Driving Machine
Mein Auto: '13 F10 550i; '11 R1200GS
vern
Yes, there is a delay before it arms itself....30 seconds or so I believe.
Similar Threads
The same old code again!!!! kenkorsak E36 (1991 - 1999) 5 04-04-2008 07:31 AM
