E46 M3 (2001-2006)
Old 05-16-2005, 05:56 AM
bren's Avatar
bren bren is offline
///Mpty pockets
Mein Auto: wankermatic
Originally Posted by Incendiary
- initial turn in seems slightly more vague...
Have you tried varying the tire pressures? You'd be suprised what a few pounds of air can do.....
Old 05-16-2005, 08:35 AM
Incendiary Incendiary is offline
Mein Auto: BMW
No, not a whole lot. I'm currently running about the same pressure as I ran in the Contis... about 34lbs up front, and about 36lbs in back. Any suggestions?
Cheers,
Incendiary
Old 05-16-2005, 08:37 AM
TD330ci TD330ci is offline
Lost
Mein Auto: 2003 M5
Originally Posted by Technic
Technic,
Can you tell me where I can pick up a set of those spacers?
I would like to have them ready with the 245/275 tire set up with the car comes in.
Thanks!!
Old 05-16-2005, 08:47 AM
Nick325xiT 5spd's Avatar
Nick325xiT 5spd Nick325xiT 5spd is offline
Send a message via ICQ to Nick325xiT 5spd Send a message via AIM to Nick325xiT 5spd Send a message via Yahoo to Nick325xiT 5spd
Mein Auto: M3 & 323i/999 KP
Cheers,
Incendiary
38-40 up front would make a huge difference.
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison 6-speed
2002 BMW M3 Alpinweiß/Black
1999 323i KP/GTS2 Alpinweiß
1990 325is Brilliantrot/Tan
1989 325is S50B30US Alpinweiß/Black
1989 M3 Alpinweiß/Black S50B32 (321hp, ITBs)
Old 05-16-2005, 08:50 AM
bren's Avatar
///Mpty pockets
Cheers,
Incendiary
I don't have experience with the PS2 but the same pressure might not be ideal for 2 different tires. So just because that worked with the Conti's doesn't necessarily mean it will for the Michelins.
If it were me, I would swap those pressures....36 up front and 34 in the rear, or play with going up and down a couple pounds to see what happens.
And before you say it...yes I know BMW says to put more air up front but they are also the same people who put that tiny 225 front tire on there to begin with.
Old 05-16-2005, 08:53 AM
bren's Avatar
///Mpty pockets
Originally Posted by TD330ci
Technic,
Thanks!!
http://www.rogueengineering.com
Old 05-16-2005, 12:27 PM
Technic's Avatar
Technic Technic is offline
OEM Audio PnP Integration
Mein Auto: 2017 M3
Technic,
Thanks!!
I bought both sets (15mm front, 12 mm rear) at TurnerMotorsport: http://www.turnermotorsport.com/html...6&subcat_id=93
... one caution, though: there is a possibility of rubbing the rear fenders when used with a brand of tire other than the Potenzas RE750 that I have. The same wheels/springs/spacers and tire sizes where used in a M3Forum member ride and he told me that in his car it rubs the rear fenders. I have no rubbing at all in my setup; I cannot remember what brand of tire he was using, but that was the only clearly evident difference between my car set up and his.
Old 05-16-2005, 05:41 PM
Lost
Mein Auto: 2003 M5
Thanks Bren.
Old 05-16-2005, 05:42 PM
Lost
Mein Auto: 2003 M5
Thanks for the info Technic. Not going to do anything to the suspension right away, just the tire set up. I will keep it in mind for future referance.
Old 05-17-2005, 02:41 PM
moneydumper's Avatar
moneydumper moneydumper is offline
Motor Head
Mein Auto: 2002 M3
Cowboy...those rims are tight Are those from the competition package?
Old 05-17-2005, 08:34 PM
Cowboy Bebop's Avatar
Cowboy Bebop Cowboy Bebop is offline
Mein Auto: M3
nope, they are the RG4's from RAC monolites.
lighter and stronger than the ZCP or CSL wheels, with a more agressive offset, and they are a bit wider... 10/19r 9/19f.
thanks though, I like them.
Life is like a B Movie, you wouldn't want to sit through it twice, but you'd hate to leave it in the middle!
Old 05-22-2005, 08:20 AM
HUMMM 3 HUMMM 3 is offline
Send a message via AIM to HUMMM 3
Mein Auto: 02 M3 Coupe, Topaz/Black
Originally Posted by Gary@Tirerack
E46M3 of course
Unfortunately, after the sale we sometimes get very little feedback on how certain setups are working out. Rather than search, I thought it would be helpful for future reference to have them all in one thread.
Anyone care to post their own specific experiences in going from the stock 225/40R19 front, 255/35R19 rear to the wider 245/35R19 front and 275/30R19 rear? Did you find that the wider tires were mostly a cosmetic issue, did the tires tramline more, etc?
Thanks in advance for any feedback
Don't know if you are still following this thread, but I have Dinan's 19" wheels (9.5F and 10R) with 275/30F and 285/30R S03's. No interference issues at all. Turn in was improved enormously. After nearly 20K miles (no track) the tires have become noisier and tramline more. I'm going to put PS2's on next week. (Nothing against the Bridgestones, but I'm looking for a softer ride with the Michelins.) BTW I also have Dinan's complete suspension set up including the camber plates. The air pressure discussion raised on this thread will have me experimenting with more air in the front.
2002 E46 M3 Dinan S3-R
Old 05-22-2005, 10:52 PM
FlyingDutchMan FlyingDutchMan is offline
Mein Auto: 02' M3
On a properly built set of custom wheels, like CCW's that are machined specifically for the E46, you can fit a 275/30 on the front with a 19x10 rim like I have right now, no fender rolling needed if you run some negative camber. You could also go to a 295 tire on a 19x11 on rear, but you'll need to roll fenders
For the track a 275/285 hoosier combo workes nicely on my CCW race classics 18x9,5 and 18sx10.5. A better set up would be to get 4 - 18x9.5 or 10 inch wide rims and with 275 tires the whole way around so you can rotate them. WIth the right back spacing you should be albe to pull this off with no spacer or a very small 5-10mm.
Old 11-21-2007, 08:21 AM
michael clark michael clark is offline
hammertime550
Mein Auto: 07 550i 06 M3 ZCP
larger tires
I went to the 2753019 Pilots on the rear and have experenced no ill effects handling in the corners is noticelably better Only problem is now I want wider thiking about rolling the fenders or body kit to get to at least 2952520 or even 3052520
Hammertime
07 550i sport Mtech body/Black/Tan/Maya 20
06 M3 ZCP White/Cinnamon/IForged 19
Old 11-21-2007, 03:31 PM
anmeyman anmeyman is offline
Mein Auto: 2003 M3
Hey Technik, I have the same dillema as TD330ci. I currently have stock 225/40/19 and 255/35/19 on my m3, but would like to switch to 245s and 275s. What I am concerned about is that if i go with 275/30 the overall diameter of the wheel will come down to 25.5" as compared to 26" stock. If I go for 275/35 it will be bumped to 26.5" and am told that I will most likely need to roll the fenders. Do you know if reducing the OD to 25.5" can be a
problem, especially since my fronts will stay at 26" (ABS, DSC ???). I assume the odometer will be slightly off but I am not concerned with this at all. Thanks in advance.
Hella nice black M you got there!
Old 11-21-2007, 05:13 PM
sanhonda22's Avatar
sanhonda22 sanhonda22 is offline
Sleek Sam
Mein Auto: AC Schnitzer 745Li
XIX Type 05 - Front is a 19x8.5 with 235-35-19 Rear is 20x10 with 285-25-20 Tires. Lowered with h&r springs. Drives awesome. Gain in traction and handling.
Old 11-21-2007, 06:49 PM
bren's Avatar
///Mpty pockets
Originally Posted by sanhonda22 View Post
BLING
Oh, wait you're serious aren't you?
Old 11-21-2007, 07:01 PM
sanhonda22's Avatar
Sleek Sam
I dont think its blingy. Anyways, when the customer first wanted 20s in the rear, I was also thinking why, but when everything was all done and lowered, it looks pretty awesome in person
Old 11-22-2007, 12:04 AM
Mein Auto: M3
why?
to increace underateer, which the car has too much of already?
I am running 265f/275r and the steeering is so neutral that it is almost perfect.
I would want to decrease understeer- rather than increase it!
Old 11-22-2007, 04:35 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
That's why serious track and autocross people are running same size tires front and rear.
20" are pure bling, overall the combos are heavier and the lack of sidewall height reduces the ability to get the tread flat on the ground. Look at F1 cars, or pretty much any other race car, there needs to be some sidewall height to make the tire work best.
And there is a dearth of GOOD tires for thoses sizes.
If you are doing it for looks, fine. But for performance, you are doing the wrong thing.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Similar Threads
Question for the guys Mr. Sparkle Off-Topic 83 03-26-2003 01:58 PM
question for you guys & gals too. PMR55 Off-Topic 7 02-19-2003 03:15 PM
E46 guys, have a question for ya chukiechz 3 Series & 4 Series 1 06-27-2002 01:21 PM
Guys, this is probably the 1000th time this question is asked, but... ALEX325i General BMW Questions 3 01-17-2002 08:39 AM
Hey guys, another computer question: Is SDRAM the same as Ram AF Off-Topic 6 12-28-2001 10:36 AM
