Old 04-20-2005, 06:53 PM
ChinuSFO ChinuSFO is offline
Mein Auto: 2002 530I & MB 200 E320
Help! CD Changer installation in 2002 530i
I have a 2002 530i. I do not have a CD changer in the car. I have a "Business CD" player. It plays 1 CD at a time. How do I go about installing a CD changer by myself. What model and make of changer should it be. Where do I install it in the car and is it already factory prewired to the Harmon Kardon system? How long will it take you think? Thanks for the help
Old 04-20-2005, 08:08 PM
franzdom franzdom is offline
Unregistered User
Mein Auto: '03 330i
It should take about 20 minutes. It's SUPER easy. BTW, you don't have HK sound, that's for 3 series. Check http://www.bmwcdchanger.com/ for info as well as http://www.realoem.com for installation kit part numbers. Get the install kit from a BMW dealer for under $20, I got a CD changer used from a roadfly.org member for $209 delivered. If you buy used, confirm it's the new part number, 82 11 0 028 760
If you have DSP I believe you also need another (optic?) cable. The car is prewired, you can plug it in in like a minute, the bracket kit is just to hold it down. Your dash CD will still work fine too.
Old 04-20-2005, 08:09 PM
markseven markseven is offline
an audience of One
Mein Auto: Go Kart with AC
ChinuSFO,
If you want to use a changer other than an OEM unit, you'll need an interface (check soundgate.com). I have an Alpine 6 disc changer and a Soundgate interface, and they work well together. Some folks contend that in order for the newly installed changer to function properly, you must have the dealer "initialize" the changer (I didn't take this step, mine was plug n play). Your car should be prewired for a changer. Should take a only few minutes to install.
-Mark
I Timothy 2:1-2
Old 04-20-2005, 10:19 PM
540 M-Sport's Avatar
Mein Auto: 01' 540 M-Sport, Scuderia
More infor here too:
http://www.bmwtips.com/
Click on "tips and tricks", then scroll down on the right of the page. You will find links to installing a cd changer. Good luck.
Old 04-21-2005, 07:50 PM
Thanks for the tips folks. Would anyone know how to find out if my Bimmer has DSp or not. Is there some label in the car which tells me that.
Thanks for the help.
Old 04-22-2005, 05:59 AM
jaguar_wsc jaguar_wsc is offline
WSC-MOB
Send a message via AIM to jaguar_wsc
Mein Auto: 1998 528i
might be a long shot but... ill trade you a stock tape player that goes in that slot for your buisness cd player.... plus a lil cash?
Old 04-22-2005, 09:03 AM
Ågent99's Avatar
Ågent99 Ågent99 is offline
Moderator, 5-Series
Mein Auto: Trek 6500 MTB
Look in the trunk for BMW "subwoofer" (in quotes because you'll laugh when you see BMW's definition of a subwoofer).
It will be covered in a formed/molded piece covered in grey cloth/fabric and mounted just under the rear package tray under the rear window of the car. It kind of sticks out and quite often gets in the way when you try to cram too much luggage in the trunk! You can't miss it and I can't find a convenient pic to show you.
Similar Threads
'05 E46 330i with Sirius Radio Option & Factory Cd Changer? EricSteinman E46 (1999 - 2006) 22 09-17-2005 10:17 AM
Z4 Audio Over CD Changer Input pocilja Car Navigation, Audio & Electronics by BAVSOUND 0 03-31-2005 10:12 AM
FS: XM Radio setup for (almost) ALL BMW models (incl XM tuner, CD changer & adapter) TD Classifieds 1 07-11-2004 08:32 AM
cd changer install help needed!!! punkman79 3 Series & 4 Series 19 04-25-2002 07:28 AM
Desperately need help! CD changer installation JB330Ci 3 Series & 4 Series 4 04-20-2002 05:49 PM
