E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008)
Coupe and Roadster talk with our gurus here... |
Odyssey battery in M-coupe
As mentioned previously, the OEM battery in my '02 M-coupe had given up the ghost.
I was looking for a better option. Well I decided on the Odyssey battery. This is a sealed dry-electrolyte battery that is similar to the Optima series, but shaped more conventionally. No fumes. This is important to me when the battery is inside the car. This is not a cheap solution. The PC1700T that I chose is right about $200. OUCH! I hope it is money well-spent! Some modifications to the battery cover were needed. They are shown in the attached photos. The battery fits very well in the box without the foam spacer and needs no vent. The battery seems to have a lot of cranking power. Manufacturer's specs say 875 CCA, 3.5 milli-Ohms internal resistance, and 68 Amp-hours at a 20 Amp rate. Photos are attached. First pic is the battery in the box without the cover. Second pic is the modified cover. Third pic is the finished installation with modified cover in place.
Bob, Lord Helpus, KtR Monaco Blue 650i coupe; 6MT, HUD, ACC, ZCW, ZPS. Redelivered 20 July 2006 |
Were the cover mods needed because the Odyssey is taller than the stock battery?
Just don't try the lightweight hawker batteries. Hugo did at BFC, now he has to keep a trickle charger on at night to avaid no start mornings!
Well breathing 2.8. |
Xstatic Batcaps I originally heard about these batteries being used in Electric and DIY Hybrid projects. I don't have any experience with them myself. The size and weights savings seems interesting. |
You could probably avoid the cover modification by changing terminals, but I didn't want to do that.
Once the cover is modded the hatch floor fits fine, though?
In finding a replacement battery I found a vendor selling odyssey PC1700MJT for $149 + shipping. He's in the east coast so total shipped to the east coast is under $200.
He's sending me mine shipped to SF for $200. If anyone cares |
I don't know if it's helpful to you, but I've been running an Odyssey 680 in my Z4 MC for months now with no problems. Just don't leave you lights on with the car off
You put a motorcycle battery in you z4?
Got one in my Z3, as well. Same model of battery.
1999 Z3 Coupe Removed: spare/jack/tool kit/fog lights/A/C/knee bolsters/center cargo bulkhead/subwoofer housing/rear wiper/trunk floor TCK S/A coilovers BBS 3-piece magnesium racing rims Unorthodox crank & alternator pulleys MZ3 shifter Shift light Momo steering wheel Odyssey lightweight battery Corbeau seats M diff cover/swaybar links IE subframe bushings Supertrapp muffler HMS harness bar Current weight, 10-02-07: 2,700 lbs est. |
-It's not a motorycle battery, but is similar in size. It has plenty of cranking amps for an auto.
Although it does seem to have simular CCA's than that of a lead acid battery. Perhaps a PC1700 is an over kill... http://www.odysseybatteries.com/battery/pc680.htm Last edited by Badqarma; 05-18-2007 at 12:42 AM. |
As far as I know, they're originally intended for motorcycles, sure, but people use them in cars all the time. The PC680 just happens to be the smallest one with enough power to crank a normal car. I have the PC680MJ, myself.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Lets battery my '01 M coupe | Ron Stygar | E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) | 89 | 09-06-2010 02:59 AM |
| * M6 * - Press Release from BMW | Emission | E63 / E64 M6 (2006 - 2010) | 6 | 03-06-2007 07:20 AM |
| My first BMW service (please advise what you would do)? | shaftdrive | E39 (1997 - 2003) | 23 | 08-18-2006 07:51 PM |
| Question about battery maintenance on a 02 M Coupe | fpa1974 | E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) | 1 | 11-02-2003 02:18 PM |
| Wow! The G35 Coupe looks good! (link inside) | Sean | Off-Topic | 12 | 03-29-2002 11:48 AM |
