Old 04-22-2005, 01:10 PM
hades281 hades281 is offline
Mein Auto: E90 hopefully soon!
Reading the Engine Temperature??
Since the new E90 doesnt have a temperature gauge, what information does it provide to the driver? Say for instante there is a cooling problem with the engine (water pump quits, thermostat stuck, etc) -- with a gauge I would notice the engine running warmer than normal and pull over before the needle is in the RED.
If all we get is an idiot light, I'm afraid it woudlnt come on until the red area, which to me seems like too late a warning before you start running the risk of damaging the engine. Also, I wont be getting I-Drive.
I'm wondering if its anything like the oil level display, where we would get some sense of Normal Operating Temperature, Warmer-Approaching-Hot, and Overheat/Danger.
So does anyone know how it works?
Old 04-22-2005, 01:37 PM
whippet whippet is offline
Mein Auto: 06 330i ZPP, ZSP, 6M
I share your preference for gauges, but recent experience tells me idiot lights have come a long ways. In my 99 Ford, the battery light came on several days before the gauge started to show a reduced charge - the alternator quit a day later. I ignored the idiot light and went with the gauge - which cost me a new battery! I guess both would be great - esp. if the light doesn't tell you how severe the problem is.
undefinedundefined
John
86 635, red/tan , 5M
90 535, granite/gray, 5M
94 325i, Black/tan, 5M SP
97 M3 sedan, byzanz (copper)/Magma(brown), 5M
Old 04-23-2005, 08:14 PM
M3Mad M3Mad is offline
Mein Auto: M3
Post More Than Idiot Lights
The E90 3-series, like all other newer BMW models, has more than just the Engine Temperature Warning light that comes on when worse comes to worst. The rev-counter has a series of lights all the way around it, much like the M3, but the lights are much better executed and have no visible gaps. When the temperature of the engine is low, the lights will extend all the way to 4000rpm or so. As the engine comes to operating temperature, the light bar retreats back to the 7000rpm mark. The lights, therefore, provide you with all the information you need to determine whether you can use the engine to its full pontential yet or not.
The warning light is only needed to determine if the temperature is too high.
Old 04-23-2005, 09:10 PM
hmr's Avatar
hmr hmr is offline
.oo=||=oo.
Mein Auto: Bimmers
The E46 has hidden OBC functions which one can unlock to display the actual engine temperature. I expect the E90 to have the same capability. So don't fret. If you really need to access the engine temperature in the E90, you probably will be able to.
Old 04-24-2005, 02:57 AM
So, does anyone know what temperature will set off the warning lights?
Say if the thermostat is a 195 degree stat, and "red zone" on the usual analog gauges is 290*F, I want that light to come on around 260 or so... (just throwing out numbers, but you get the idea)... If the light only comes on after the engine is hot enough to start causing damage or warping, then whats the point of it?
Old 04-24-2005, 04:48 AM
jhbodle jhbodle is offline
Mein Auto: BMW 325i SE E90
I'm not sure about that. I wish it was true, but when I asked my dealer if the E90 had the variable tacho lights he said that only the M models had this feature. Other people who I have asked on other forums tell me that this feature does not exist on their E90s.
The cold-start warm up phase and the lack of an oil dipstick in the engine bay are the two things that are most worrying me when I pick up my 325i in June.
Old 04-24-2005, 01:38 PM
crazybones crazybones is offline
Mein Auto: 250CDI - 328 MSport onway
Picked up my 325 last week. Fantastic car! The level check is made whilst you're driving using the onboard computer - you just have to put your faith in the electronics.
I thought that the red line on the tacho dropped when the engine is cold therefore acting as a king of temp gauge. However, whilst I have a series of bars above the red line which look as if they should move in the same way that the new cruise control indicator moves around the speedo, they remain static. I'm going to drop into the dealer next week to check it out.
Old 04-24-2005, 02:59 PM
Good news about the oil level checking thing. I haven't ordered iDrive with my 325i - I take it it will still measure the oil level for me?
Let us know what the dealer says about your tacho lights - I for one am very interested about this feature. If this feature isn't on the E90, how are you supposed to know when the engine has warmed up enough to take the engine to the redline?
Old 07-11-2005, 07:23 AM
silverado silverado is offline
Mein Auto: E90 330i
Resurrecting this somewhat old thread with good news!!
I discovered today that the tachometer DOES have a way of telling you if the car is cold or running at normal temerature. I don't know if this is new or it has been posted before, but I didn't find it when searching and it is not in the user's manual.
The red line in the tachometer in my 330i starts at 7000 rpm. However, there are a number of small lines that go from ~6750 to 7000.
When you first start the car, these series of lines are red. After a while, they turn white! I think this means that the temperature is now normal!! I'm psyched... now I will know when the engine is warmed up and can safely start stepping on it!
E90 330i | Sapphire Black | Black Dakota | Burl Walnut | 6 speed Manual | Sports | Premium | Cold Weather | PDC | iDrive | Sirius
Old 07-11-2005, 09:28 AM
ldpantoja ldpantoja is offline
Send a message via Yahoo to ldpantoja
Mein Auto: 2006 330i SG / SP / NAV
Does anybody have a pic of this????
Old 07-11-2005, 11:26 AM
ic's Avatar
ic ic is offline
Mein Auto: 06 325i SP
Good to know. May be the weather is too warm that I never notice it was red when I got it in early May? But still don't know when the oil/water temp getting hotter...
Old 07-11-2005, 11:29 AM
john4.4x5 john4.4x5 is offline
BMW addict!
Mein Auto: 06 330i & 07 CLS 63 AMG
The E90 does not have a variable engine redline , with regards to the lights extending to 4000rpm, the E90 does no such thing. At least in my 330i production 05/05.
Also, I haven't been able to see the red "lines" that are at approx. 6750 rpm. Did a cold-start today and the white lines between 6750 - 7000 rpm are, well, always white. I will double check this on another cold-start. That would be kewl if the "lines" do indeed go from red to white.
Daily Driver: 2006 BMW 330i Build: 05/05
SP, PP, DVD-NAV, Sirius, PDC, Rear Spoiler, Steptronic, TiAg/Blk
Former BMW: 2002 BMW X5 4.4i Build: 06/02
SP, PP, Xenon, 19", RCP, TiAg/Blk. Faultless.
Other German: 2007 M-B CLS 63 ///AMG Build: 09/06
P2, Elec. Trunk Closer, Distronic, Parktronic, Bluetooth adapter, Alcantara Anthracite Headliner, Chrome Door Handle Protectors, Wheel Locks, Iridium Silver/Blk Nappa
Old 07-11-2005, 11:32 AM
Mein Auto: E90 330i
I think I was fooled by the Auto lighting setting while I was in my garage this morning (and being half asleep). I'm beginning to think the "red" I was talking about might have been the VERY amber instrument panel lighting. It of course went away when I drove out of the garage.
I will double check again later while being more careful (read awake and caffeinated). But my enthusiasm is waning.
Where are those delete privileges when you need them?!
Old 07-11-2005, 02:25 PM
Wolf359's Avatar
Wolf359 Wolf359 is offline
Mein Auto: '06 325i
Just a question about the temp gauge on previous generations 3-Series... How often did you really need to consult them? Mine started cold, in the blue, and then moved on to the middle after a while, and it never moved from there afterwards, on any trip, for more than 5 years owning the car. I wasn't looking to it anymore - The engine has temp sensors all over the place and does a good job of managing it's heat.
So I don't think a warning light coming on when something wrong happens is such a bad thing... At least it'll get the driver's attention.
Old 07-11-2005, 03:09 PM
BMW addict!
I agree. No gauge is fine with me. I would use the gague to know when the coolant temp is hot enough to rev the enging. Although it was indeed a COOLANT temp gauge not an engine temp gauge, I would still use it as a reference. Now I suppose i can just keep track of distance traveled to gauge when i should rev it hard. No big deal.
Similar Threads
BMW develops lighter engine sp330i General BMW Questions 2 08-02-2004 07:43 AM
6th gear argument rehashed allaboutme 3 Series & 4 Series 135 06-25-2004 06:23 AM
Dr Mario Theissen chat WAM Motorsports, Racing & Track 1 08-14-2003 08:28 AM
Mag/Alum engine blocks in Bimmers (Long) in_d_haus General BMW Questions 13 07-18-2003 04:41 PM
Product review: Griot's Engine cleaner kit(m) The HACK The Detail Department 20 01-08-2002 07:56 PM
