E34 (1989 - 1995)
Old 04-24-2005, 01:56 PM
hagen hagen is offline
Mein Auto: e34,525i, 24V, M50, `91
Central locking problem
Hello! First i have to apologise for my English because it`s not my native language! I have a problem with locking/unlocking doors on my bmw e34,525,
`91. Everything was fine some time ago but suddenly one day it just
happened, i could`nt lock/unlock my cars doors with remote, but i can do it
with my key and manually all doors work fine. I have a mongoose base 475
alarm system on my car which is controlling central locking system. I would
be thankful if anybody could give me any advice or tip what i should check
first and also if anybody has an electrical diagrams about related system.
Best regards!
Tom
Old 07-05-2015, 12:57 PM
keronplaza keronplaza is offline
Mein Auto: BMW 98 318TI & 97 528I
Always check your fuses first. If the key locks all door with one turn then it most likely IS NOT a fuse. BUT if your key only locks the door you use it in then it is most likely the fuse that controls the central locking system. The easy test is to sit in the car and close the doors. then hit the door lock button if there is one inside of the car to lock all the doors. If that works then your native central locking system should be fine and the problem could the be mongoose systems connection.
Good Luck! and check your fob batteries!
Similar Threads
M5 problem... dbrook007 1M & M2 2 08-27-2004 11:54 AM
Hot car CD problem cowgit General BMW Questions 3 08-04-2004 01:37 PM
Central locking problem '94 525i Touring CapeBimmer General BMW Questions 1 07-21-2004 04:40 PM
Central Lock- Gas Lid Latch E46 Sedan HiMiles 3 Series & 4 Series 5 12-02-2003 12:53 PM
Anyone with the same problem? danpop 3 Series & 4 Series 3 12-31-2002 07:40 AM
