265/35/18 on stock rim ? - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E46 M3 (2001-2006)
E46 M3 (2001-2006)
Old 04-23-2005, 04:20 AM
batmanm3 batmanm3 is offline
Mein Auto: 02 m3
I have noticed a couple of people running 265/35/18 on stock 18" rims...are you guys running at the track or street with those sizes?
I would like to do the same with Mich. PSC, but am worried re rubbing issues or handling with a tire that is sl. too wide for the 8" rim up front.
I also noticed that Nick runs stock 18X9 rear rim on the front...any issues with that? Do you need a spacer or is the extra camber enough?
Old 04-23-2005, 04:21 AM
Nick325xiT 5spd's Avatar
Nick325xiT 5spd Nick325xiT 5spd is offline
Send a message via ICQ to Nick325xiT 5spd Send a message via AIM to Nick325xiT 5spd Send a message via Yahoo to Nick325xiT 5spd
Mein Auto: M3 & 323i/999 KP
A spacer would make clearance problems worse. The camber is needed to keep the rim off of the fender, and a spacer would shove it right in there.
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison 6-speed
2002 BMW M3 Alpinweiß/Black
1999 323i KP/GTS2 Alpinweiß
1990 325is Brilliantrot/Tan
1989 325is S50B30US Alpinweiß/Black
1989 M3 Alpinweiß/Black S50B32 (321hp, ITBs)
Old 04-23-2005, 04:33 AM
BahnBaum's Avatar
BahnBaum BahnBaum is offline
Empowered Consumer
Mein Auto: 1 - 4.20hp, 1 - 420hp
The fit fine on stock 18's with stock camber. No problems at all.
Alex
Interrobanged.
My Flickr
TeamWTF?!
Old 04-23-2005, 05:02 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
Did you have stock camber when you put the Dunlops on the first time? I thought you had at least pulled the pin for the extra 0.5 degrees.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 04-23-2005, 05:42 AM
BahnBaum's Avatar
Empowered Consumer
Oh yeah. Forgot about that.
Alex
Interrobanged.
My Flickr
TeamWTF?!
Old 04-23-2005, 05:53 AM
bren's Avatar
bren bren is offline
///Mpty pockets
Mein Auto: wankermatic
Running a 265 on an 8" rim is certainly not optimal. I think most folks will tell you that on the track there is a good chance you'll get some tread squirm. For autox our primary focus is on mechanical grip at pretty much all costs (wider = better in nearly all situations.)
I don't recall trying those sizes without at least pulling the strut-pin first but I seriously doubt there will be any rubbing on the 8" wheel.
To run the rear 9" wheel up front requires something like -2.5 deg camber and more would be better. At -2.5 it just barely rubs on the fender liner at full lock when the suspension is loaded, which is to say not very often.
Old 04-24-2005, 08:28 PM
Mein Auto: 02 m3
Good info, thanks.
Any of you run with the stock susp. mounts (?) swapped left to right? Is that enough camber to run the rear wheel up front or are camber plates a must?
For track use then would you say 245/275 on stock rims would be better than the 265 all round (ie. the excess tread squirm offsetting the extra grip)?
Old 04-24-2005, 08:36 PM
BahnBaum's Avatar
Empowered Consumer
Good info, thanks.
I did the hat swap that you're talking about, and it allows me to run the rear wheels up front with 265's with no problem.
Alex
Interrobanged.
My Flickr
TeamWTF?!
Old 04-25-2005, 02:35 AM
Pinecone's Avatar
M Mad
Yes, and Yes. I get about 2.5 degrees of negative camber with swapped hats and the pins pulled. I actually get 3.1 degrees on one side.
No, I would run 265 all around.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 04-25-2005, 02:58 PM
Mein Auto: 02 m3
Pinecone or BahnBaum
Do you leave your suspension like that for street use as well? What kind of tire wear do you get or are your cars primarily track/weekend cars?
Any idea if all of this would also work with a Stoptech BBK (which requires a 10mm spacer up front with the stock front rims)...ie. would you have to use the spacer as well with the rear rims and if so would it probably hit the fender on the outside?
I'd go and try it but I haven't done the hat swap bit and my stock 18 have winter tires on them still...
Thanks for your patience
Old 04-26-2005, 02:26 AM
Pinecone's Avatar
M Mad
Yes, all of us run them this way all the time. Too much trouble to swap back and forth.
I haven't seen any abnormal tire wear, but haven't put that many miles on it. And I haven't had the toe set properly since the swap either.
Why would you have to run a spacer in the rear? The spacer is to clear the larger caliper used on the fronts. Call StopTech and ask.
As for spacing in the front, not sure if you can get by with a spacer at a set of rears.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 04-27-2005, 05:58 PM
Mein Auto: 02 m3
Sorry, I didn't make it clear enough...what I meant was if I were to use the rear stock 18 up front, would I still need the 10 mm spacer which I need with the stock front rims.
My concern would be I would need the spacer for clearance for the caliper but it would cause problems with the fender by making the offset worse...
(actually, the rear wheel clears the rear caliper...assuming they are the same then I would not need a spacer for using the rear wheel up front)
I definately need to swap hats and try this out.
Old 04-27-2005, 06:01 PM
bren's Avatar
///Mpty pockets
Why do you need a spacer?
Old 04-28-2005, 01:55 PM
Pinecone's Avatar
M Mad
BIG front caliper. No way of knowing without trying it, os using the template on the StopTech site and pulling a rear wheel to check it out. Rear calipers are smaller, so you may not need a spacer in the rear, but still may need one in the front.
And do you NEED a 10mm, or will 8 or even 5 do?
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 04-29-2005, 11:59 PM
Mein Auto: 02 m3
not sure if you can get away with thinner spacer...10mm is what stoptech recommends with the stock 18" front wheel...
Similar Threads
Which snow tires should I get? SizzlerMA Tire Rack's Tires, Wheels, Brakes & Suspension 25 01-30-2004 05:12 AM
Changes to OEM E46 M3 rim, or a replica? David Keogh 1M & M2 1 06-21-2003 02:42 PM
New Rim Scratched (LONG) Ack 3 Series & 4 Series 22 06-18-2003 12:47 PM
Need answer quick (PLEASE) 235/45/17 fitment on 17x7.5 rim? AlexM520 3 Series & 4 Series 6 11-08-2002 07:15 PM
#@$%&!! curb damaged my rim - need some advice... Scotes 3 Series & 4 Series 6 01-16-2002 12:35 PM
