Old 01-10-2017, 09:45 PM
Crawl74 Crawl74 is offline
Mein Auto: 2008 BMW 335i Coupe
Grinding/rubbing noise at low speeds
Hello,
Wondering if anyone has experienced this. I am still hearing and fealing a grinding or rubbing noise from the front end suspension, brakes, etc. At low speeds and i have replaced the pads, rotors, wheel hubs and rebuilt the calipers. This has not solved the problem and it is driving me crazy! Not sure what else it could be so any help would be much appreciated.
2008 335i coupe e92/n54
Sent from my SAMSUNG-SM-G928A using Bimmerfest mobile app_a__a2_
Old 01-13-2017, 03:18 PM
SunDogBC SunDogBC is offline
Mein Auto: 2008 335i Sedan
Check your tires for rubber damage, e.g. cracking/splitting, along the rim, particularly on the inside where it's not as obvious.
That's what my "driving me crazy" was.
2008 335i Sedan
Old 01-13-2017, 03:54 PM
Oulixes's Avatar
Oulixes Oulixes is offline
Mein Auto: 330xi, 335i
Check if the protection plate (e.g. 34106780216) is rubbing against the disc. If it did you would hear rubbing noise, most noticeable when the car moves with engine off.
