E36 (1991 - 1999)
Old 04-28-2005, 11:02 AM
rick525 rick525 is offline
Mein Auto: 1995 325i
Question synthetic oil
just purchased a 95 325i .had a 1990 525 but had a little fender bender and insurance company wrote it off.(said there was too many miles on it)and it wasn't even my fault.
Question is the 325 has 200k and I would like to switch to a synthetic oil.Is it a good idea and what oil would you gentleman(or ladies ) recommend ?
Old 07-07-2005, 11:53 PM
BMW16 BMW16 is offline
Mein Auto: 1993 325i
Thumbs up
To be honest with you, I would just stick to regular conventional motor oil. The reason is because 200K miles is just a little bit to much to start using synthetics. Old engines (or engines with a lot of miles like yours for instant) tend to burn oil so I suggest you use thick oil (15W-50 or 20W-50 for the summer and 10W-40 for the winter) and make sure you change it every 2,500K to 3k miles. It's always good to run your old engine with new and fresh motor oil. Remember your engine has a lot of miles, so tread it like a baby!!!
Old 08-03-2005, 09:15 AM
paullfisher paullfisher is offline
Send a message via MSN to paullfisher
Mein Auto: VW Golf, E36/7, E30
Go for it! There is no down side! I personally use Amsoil 5W-40 oil in my cars.
Old 08-03-2005, 10:08 AM
Bonezilla's Avatar
Bonezilla Bonezilla is offline
Mein Auto: 2005 Imola Red 330Ci
Unless you had the motor rebuilt, what would be the point of changing to a more expensive synthetic. If anything it's a bit too late. If you rebuilt, definately go for it.
Old 08-03-2005, 07:16 PM
doulos4JC doulos4JC is offline
Mein Auto: 1999 328ic
If its still working after 200k, don't fix it! Stay with regular oil.
Similar Threads
DIY - 528i OIL Change (E39) 6 cyl GOKOOLJAPAN 5 Series DIY 56 12-18-2009 11:08 AM
Conversion to synthetic oil revisited... PeteG E36/7 Z3 (1996-2002) 6 11-03-2004 09:01 PM
Good Article on Synthetic Oils GSR13 General BMW Questions 21 05-07-2003 01:17 PM
Is the war about oil? nate Off-Topic 10 02-18-2003 06:06 AM
