SW update from 15.x to 16.x - Bimmerfest - BMW Forums
Old 04-28-2005, 12:53 PM
directcj directcj is offline
Mein Auto: 05 ED 5er
I brought my car ('05 525 w NAV) in to the dealer for a couple of gripes. I asked the service advison for a sw upgrade and he told me that he'll check to see if can be done by request. In other words he said that he didn't know if can be upgraded unless I mention an issue that can be resolved by an update. He initially told me that I have the latest 16.2 but I told him that I know I don't have that since I don't have the perspective view.
So, some help here from you guys. What are some issues that are resolved by going to 16.2 from 15.x
BTW, here's what I brought it in for:
1. During fill-up, gas nozzle keeps shutting off after only 1-2 gallons
2. AC stinks
3. Front passenger window- while trying to close window, window will go up halfway then go back down
Item 1 was fixed by changing the gas tank? SA told me this is a known issue (I should probably post this in a separate thread/subject so others can chime in). Something to do with the filler neck being too small and having a kink or wrong bend in it.
Item 2 was fixed by deodorizing
Item 3 - BMW is aware of the issue and is still investigating a fix.
Old 04-28-2005, 06:59 PM
stream's Avatar
stream stream is offline
Mein Auto: '05 545i
2. AC stinks
I have the a/c smell issue, and also the front passenger window issue. On the window, I assumed it was a faulty sensor for the anti-trap feature. I've had the car 3 months and it's happened maybe a dozen times. Did they try replacing the anti-trap sensor?
2005 545i - sold
Old 04-28-2005, 11:34 PM
anti-trap not fixed
Nope.
SA told me that initially BMW advised the dealers to replace the motors which didn't work (problem apparently came back). Now BMW is advising them that the problem is still under investigation and that a resolution is coming.
Similar Threads
Got the 40.1 Software Update (ZHP Related) MJTSUB E46 (1999 - 2006) 17 04-01-2005 05:16 PM
Software update?? david2u Ask-A-BMW-Dealer 1 06-24-2004 08:45 PM
BMW Update for S54 Engines BMWNA 1M & M2 2 08-13-2003 06:55 PM
Dinan SW / Throttle response issue (attn: PunchIT/Paul330ci palooka666 3 Series & 4 Series 1 03-17-2003 07:34 AM
Anyone guess the price of a NATIONWIDE NAV DVD update? CD-55 3 Series & 4 Series 15 01-02-2003 11:29 AM
