E46 (1999 - 2006)
Old 04-28-2005, 12:17 PM
es es is offline
Mein Auto: 325i
Should I go with OEM or Bosch +4's spakr plugs?
Any suggestion here...
And also do I really need to replace disks at the same time i change my brake pads?
I already had 2 sets of pads running on one set of disks.
Old 04-28-2005, 12:42 PM
bluskye bluskye is offline
Mein Auto: 2006 330i / 2007 X3
BMW recommends you swap out the rotors on every brake change. They are pretty thin compared to rotors that can be cut between pads.
Go with the OEM NGK plugs as well, why screw with it if it works good.
Old 04-28-2005, 03:43 PM
99flhr 99flhr is offline
Mein Auto: 00 Z3 2.8
If you have no brake pulsation and they`re above min. thickness I see no reason to replace rotors, your prior experience proves that it`s not ALWAYS required. Wonder how many sets have been trashed unnecessarily. BMW recommending replacement is not exactly an unbiased opinion. my .02
Old 04-28-2005, 05:11 PM
WAM's Avatar
WAM WAM is offline
ober-slacker
Send a message via AIM to WAM
Mein Auto: 325i Sport
I suggest go with the OEM NGK's too. If you really want Bosch, go with the OEM Bosch, which were certified after the NGK's. The NGK are 4 electrode plug, the Bosch should be too.
As for brake discs, I believe min thickness is 20.4 mm (front discs). Check your your brake disc thickness and see what amount has been 'consumed' by the current set of pads. Then extrapolate it to see if you will exceed the min thickness with the new set of pads.
Edit: Just noticed that you stated that you have used 2 sets of pads, I think you are pushing it to try for 3 sets of pads.
Similar Threads
Which spark plugs do I use, Bosch or NGK? WAM Do-It-Yourself H.Q. 23 05-18-2005 07:04 PM
Substitute Bosch o2 sensors for OEM Siemens HaqDeluxe E36 (1991 - 1999) 1 02-15-2005 05:07 PM
substitute Bosch o2 sensor for OEM Siemens HaqDeluxe 1M & M2 0 02-13-2005 02:56 PM
NGK vs. Bosch Plugs BryanLeo 3 Series & 4 Series 0 11-16-2003 03:45 PM
E 46 NON HK speaker upgrade (systems without Oem amplifier) Pmmeke 3 Series & 4 Series 0 10-17-2002 06:46 AM
