E34 (1989 - 1995)
Old 04-30-2005, 04:29 PM
J.Clerihan J.Clerihan is offline
Mein Auto: BMW 5 series
Dash vents not working
Air conditioning working but not through dash vents, same with heat and defrost. Air flows through floor vents and back seat vents only. Could use help, mechanic not sure whats wrong.
Old 05-03-2005, 10:48 AM
CheapCheap1 CheapCheap1 is offline
Mein Auto: '95 540i & '89 YuGo
When did you replace the microfilter last time?
Pls check if your car has installed w/ microfilter...
- If it has one, try to replace it 1st & see if the airflow rate is improved. (It's cost around $20-30.)
- If replacing the microfilter doesn't solve the problem, then, start looking at the blower motor to see if it's working. (Check the fuse in the box & the blower motor itself.)
- lastly, check if the motor open the flaps (in the air-duct) is working or not.
Good lucks...
'95 540i (auto) w/ Original Nikasil Block.
(96+K miles & running strong )
Similar Threads
Dash pixels have been repaired Cabriolet E39 (1997 - 2003) 30 03-16-2009 12:41 AM
Nokia 6230 fully working with BMW BT car kit - FINALLY !! Freddywaters Car Navigation, Audio & Electronics by BAVSOUND 0 03-07-2005 07:55 AM
Keyless not working...? Thoughts pdxX5 X5 E53 (1999 - 2006) 7 02-23-2005 05:59 PM
91 850i Heater Core Removal Instructions Wanted nicko 7 Series & 8 Series 1 10-18-2004 10:56 PM
Speedometer and trip-meter not working, HELP OLd Shape! 5 Series DIY 5 09-14-2004 05:41 PM
