Old 04-30-2005, 07:19 PM
abqhudson abqhudson is offline
Mein Auto: Mercedes Clk550 and c300
OK - So where is the brake fluid on 530?
I was going to open my brake fluid while I changed brake pads to a no-dust type and can't determine where this is on my 2004 530i. Manual says under the micro filter. I don't see it there. Help please.
Caliper assembly looks very different from the ones on my three series cars - is there anything that I need to be particularly careful about when changing pads on the 530?
Thanks for any help.
Jim
Old 05-02-2005, 12:40 PM
WAM's Avatar
WAM WAM is offline
ober-slacker
Send a message via AIM to WAM
Mein Auto: 325i Sport
Without reference to the engine compartment, I would imagine it is in the same location as the E39. On an E39, there were dual microfilters. You have to remove the microfilter housing, on the driver side, to gain access to the brake fluid reservoir. It is not difficult to remove that, I think there are Torx T30 or T40 screws holding the housing in place.
Old 05-02-2005, 02:35 PM
Ågent99's Avatar
Ågent99 Ågent99 is offline
Moderator, 5-Series
Mein Auto: Trek 6500 MTB
On the E39, you just undo one little metal "wire ring/clip" thingy, pull out a sensor, and then unsnap the large plastic "hose" and kinda jimmy out the microfilter housing. You'll find the master cylinder right there, driver's side as stated above.
I dunno how different the E60 is...no clue in fact. I managed to NOT look at that while putting 1250 miles on in Europe at the end of March!
Similar Threads
Rotora Brake System Performance on BMW M3 Racer Car ralphwarren Motorsports, Racing & Track 6 03-13-2009 06:00 PM
First mod... SS brake lines, question on brake fluid? jderry 1M & M2 14 03-09-2004 07:00 AM
brake fluid & clutch slave cylinder Q- 3C 3 Series & 4 Series 6 09-25-2003 01:21 PM
How do you pevent brake fluid from boiling? JonW Motorsports, Racing & Track 10 09-22-2003 09:01 PM
OEM brake fluid / track days PhilH 3 Series & 4 Series 7 04-23-2003 03:02 PM
