E46 (1999 - 2006)
Old 05-02-2005, 09:52 PM
icemanjs4's Avatar
icemanjs4 icemanjs4 is offline
Grinning from ear to ear
Mein Auto: is way too fast
Gas Mileage experiment
Recently I found myself eyeing the mpg guage a little too often. The results was I found myself driving the BMW like a Camry in order to keep the needle as close to 30 as I could get it. After a week or two I realized I wasn't having as much fun with my car and couldn't figure out why . So finally I decided to perform an experiment with the next two tanks of gas.
The first tank of gas, I always kept the needle close to 30 mpg (within reason). I tried to keep the car in overdrive as much as possible (6 spd manual so I spent a lot of time in 5th and 6th gears). I also used cruise control a lot. It was excruciating!
The 2nd tank of gas I drove without ever looking at the mpg guage. I accelerated hard on the on ramps. I spent more time in 4th on the highway (I even pulled 80 in 3rd a few times - 3rd gear rocks at 5K rpms!). I tried to keep the car within 15 mph of the speed limit, but that was my only sort of restriction.
End result: No difference. I actually got .2 mpg better results on the 2nd tank of gas. The upside is, I had a whole lot more fun in round 2. The bad news is I was getting about 22.2 miles per gallon in a mix of city and highway driving.
Moral of the story? Drive it like you stole it and forget about the gas guage!
Proud owner of an '05 Silver Gray 330i ZHP with Natural Brown interior
Old 05-02-2005, 09:55 PM
Nick325xiT 5spd's Avatar
Nick325xiT 5spd Nick325xiT 5spd is offline
Send a message via ICQ to Nick325xiT 5spd Send a message via AIM to Nick325xiT 5spd Send a message via Yahoo to Nick325xiT 5spd
Mein Auto: M3 & 323i/999 KP
My fuel efficiency in the M3 isn't that much worse than my 325xiT.
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison 6-speed
2002 BMW M3 Alpinweiß/Black
1999 323i KP/GTS2 Alpinweiß
1990 325is Brilliantrot/Tan
1989 325is S50B30US Alpinweiß/Black
1989 M3 Alpinweiß/Black S50B32 (321hp, ITBs)
Old 05-02-2005, 11:03 PM
Matthew330Ci's Avatar
Matthew330Ci Matthew330Ci is offline
Mein Auto: E46 M3
that's interesting. i too sometimes find myself looking at the fun meter way too much and trying to keep it up there. but i never noticed much of a difference either way, i didn't do a formal test like you though, thanks for the info.
i think i'll just tape off the fun meter someday.
-Matt, Nor Cal
02 M3 6MT - a bunch of mods | No V-CSL | No carbon fiber anywhere
Sold: 03 330Ci - No Leather | No Moonroof | No Step | European delivered
Old 05-02-2005, 11:11 PM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP
Someone needs to make something that converts it to oil temp.
Old 05-03-2005, 08:39 AM
Moderato's Avatar
Moderato Moderato is offline
VIII
Mein Auto: 07 E92 335i 6MT
I did the same experiment with my car when I first got it. How do you handle 1st gear though? For the first tank did you shift into 2nd easy and at low rpms, and for the second tank did you rev out 1st all the time?
Old 05-03-2005, 08:54 AM
BBBMW's Avatar
BBBMW BBBMW is offline
Banned
Mein Auto: 02 325Ci
I have been driving my 02 325Ci for a year now and can't believe how good the gas mileage is. This is the first vehicle that I can drive from Edmonton to Calgary which is about 650 km's (400 miles) on a tank of gas. I usually cruise at 75 mph and notice an extreme difference from my old Acura. It makes having to run premium gasoline a little more tolerable.
Old 05-03-2005, 09:21 AM
icemanjs4's Avatar
Actually I very rarely ever redline it in first. I just don't feel the power in 1st gear at all. So I'll shift out at about 3-4K into 2nd. From 2nd on is where I changed my driving style. (I wasn't doing 0-60 runs during the experiment, rather checking out differences in daily driving styles).
Old 05-03-2005, 10:27 AM
Moderato's Avatar
VIII
I've noticed that I can save about 1 - 2 mpg by watching the mpg gauge for a whole tank of gas, but like you said what fun is that? I've found that what really eats into my gas mileage is a lot of trips to 6K rpms , regardless of what gear I'm in. It's so fun to wind out the gears in this car.
Old 05-03-2005, 10:58 AM
TEV/// TEV/// is offline
Mein Auto: cars
I once drove an 88 honda accord which had a couple rubber engine mounts broken.
The engine would lift itself and try to twist out of position if I accelerated medium hard, so for about a year I drove it with very soft acceleration in 1st and 2nd... - I am talking about feather touch on the gas.
Driving normally I would get about 24 MPG, with the feather touch I was getting about 30 MPG (320miles per tank vs 370 miles per tank)
Tony E
2005/330Ci/ZHP/ZPP/Leather/Xenon/Weather
1993/318i/5sp/H&R/Bilstein/17"/ShortShift/JimC chip /Xbrace/StrutBrace/Scroths
Old 05-30-2005, 07:21 PM
Adventure Rider Adventure Rider is offline
Mein Auto: 2004 325Ci
I just bought a 325 Ci, and from watching the gas mileage guage, I would guess that it isn't anything fancy, just an intake vacuum guage and therefore loosely related to gas mileage (the more load and more throttle opening you give a car, the lower the vacuum).
Sorry if this has been discussed here before (I am new) or this is obvious, but that is my guess as to that guage.
Again, stating the obvious, but the reason cars get better fuel mileage on the highway is the lack of stop and go traffic - so steady speed and a light foot on the gas pedal is what gets you fuel mileage.
Follow with a good 2 second or more distance and use the throttle to gently modulate your speed instead of following closely and using brakes.
You don't necessarily want to run at the lowest RPMs, but rather at whatever gear and RPM gives you the least throttle while still maintaining the speed you desire. I.E., Lugging it in top gear at 20 MPH is not going to get you good fuel mileage, although coasting down a hill in top gear will.
Old 05-30-2005, 09:33 PM
icemanjs4's Avatar
Yeah I actually find that its better to keep the car hovering around 3K RPMS. that way if you slow down, you can get back up to speed quickyl with a minum of gas. If your in too high of a gear, you have to burn a lot of fuel for a longer period of time to get back up to speed.
My biggest example is that I have a 2 mile drive every day down a road with a 45 mph speed limit. Naturally I drive at 45 (I'd go faster but I've been bulled over twice for going 50 on this road). Anyway it's often a big tossup as to whether i should stay in 3rd or 4th gear for this cruise. If I use cruise control, 3rd gear is more efficient on this stretch.
Old 05-30-2005, 10:46 PM
startover startover is offline
Mein Auto: 2003 BMW 330i ZSP Silver
Hmm are you sure? I think my zsp really pulls at 5-5.5k in first gear if I floor it. I guess the zhp might be somewhat different on the torque/hp range.
Old 05-31-2005, 02:46 AM
andy_thomas andy_thomas is offline
Mein Auto: 318i
It uses a (buffered) signal from the bit of the DME which opens and closes the fuel injectors. BMW's throttle-less, and therefore vacuum-less, cars (all the Valvetronics and diesels) have exactly the same type of gauge. Mine is pretty accurate, and at over 7 USD a gallon, quite useful.
Old 05-31-2005, 06:12 AM
Moderato's Avatar
VIII
Mine too, the ZSP with the 2.93 rear is gear very tall and if I really want to get going away from traffic I will take 1st up to 6.5K and then shift to second without slipping the clutch, i.e. waiting for the rpms to fall close to 4K before letting the clutch out quickly, but smoothly and that gets me moving away from "normal" cars pretty well without much wear on the driveline.
Old 05-31-2005, 09:15 AM
LmtdSlip's Avatar
LmtdSlip LmtdSlip is offline
Do the interns get Glocks
Send a message via AIM to LmtdSlip
Mein Auto: 325iC
My unscientific observations seems to show that its all in your first and second gear starts.
If you get on the gas hard from a stop that seems to have the biggest effect on MPG.
highway roll ons are pretty quickly overcome once you let up on the gas or upshift.
Photobucket
Old 05-31-2005, 03:39 PM
nv nv is offline
Mein Auto: '02 325xiT
I’ve compared the instantaneous fuel consumption gauge to the OBC over short (1km) runs and there is no difference. They read the same. I’ve checked the actual fuel consumption at fill-up and noticed that the OBC is about 0.5 litres/100km low, about 5% optimistic.
With regard someone else’s comments about fuel consumption and cruise control - In most cases the cruise will give you the best fuel consumption. Note that the cruise control will do what’s necessary to maintain the speed. You can see the increase on an incline. Slowing down a little on the incline would have the best fuel economy.
Fuel consumption gauge - Sometimes I use it. Other times I ignore it. (And have some fun.)
-nv
Old 05-31-2005, 04:12 PM
bmw330pp's Avatar
bmw330pp bmw330pp is offline
bmw330pp
Mein Auto: 04 330Ci ZHP, 06 CBR600RR
I put a tornado in mine and went from 280 miles a tank to 300. Thats considering I drive my car hard most of the time. So I'm pretty sure I can get it to get better mileage if I drive more conservative.
2004 330ci, Silver ZHP, Xenons, Sunroof
Old 06-01-2005, 08:16 PM
Okay. I noticed that it acted a lot like a vacuum guage, but I was wondering how it worked - I guess I am just used to simpler tech in cars.
Sometimes it blips up (to the right) about halfway when I coast to a stop at a stop light which I assume is some kind of glitch or maybe some logic for the FI to keep the engine from dying after letting off the throttle (I know EFI used to have problems in this area).
Anyway, I don't pay a whole lot of attention to it - the way I normally drive on commutes and in town is fairly efficient anyway from what it says, although I am sure there is no way my car will ever get an actual 12 MPG or worse even though it says it would if I kept driving like that.
I find the engine very smooth at low RPMs and low loads - which lets me creep along in 1st and second in rush hour tie-ups - in first it will pull the car along at idle at a walking pace, where most other cars would buck and stall or at best idle along too fast. Almost as nice as an auto in that regard (and a lot more fun out of traffic).
This is my first tank of gas so I will be interested to see how close the actual fuel mileage is to what the computer thinks I am getting - so far it is 27.5 in mixed driving (25 miles each way to work, about 20 miles of freeway that is often stop and go in the morning and about 5 miles of city driving) and getting better each day I drive it.
I find myself taking my time when driving this car whereas with my old beater Toyota I would rush home - this car is of course a lot more comfortable and enjoyable to spend time in.
I will take on a longer trip in a few weeks when I go out of town for Fathers Day and then see what it does with a lot of highway miles at about 80 MPH. So far I have gotten the impression that at about 65-70 MPH is probably the best for fuel mileage.
Old 06-01-2005, 09:01 PM
icemanjs4's Avatar
ACtually I think 80-85 would give better gas mileage - Just a guess tho.
Old 06-01-2005, 09:16 PM
sunnykk's Avatar
sunnykk sunnykk is offline
24/7 Bimmer Addict
Send a message via MSN to sunnykk Send a message via Yahoo to sunnykk
Mein Auto: 05 330i ZHP
Read a lot about those. Are they easy to install and what's your experience been so far. They claim HP increase. Is that true
Sunny Khatkhate
2005 Silver Grey 330i ZHP, ZCW, 6MT, Blk Lthr, Xenons,
66 K Miles (Mar05 - Jan12)
OEM: Alarm, Universal Trainsmitter, I-Pod, Mud Flaps; After Market: Clear Bra, 3M-Tint-27%, Passport 8500X-Hard Wired
DIY: Euro Tray, Al Foot-pedals & Foot-rest, ULO Front & Rear Clears, Clutch Stop, De-badged
Old 06-01-2005, 09:23 PM
cwsqbm's Avatar
cwsqbm cwsqbm is offline
I do'nt make mistakes.
Mein Auto: Quadricycle
Actually, speed quickly kills fuel economy (aero drag per distance increased with square of speed). For example, I did the following experiments on level ground, no wind, over a 50 mile trip segments on same day at roughly the same temp.
Constant 55 mph: 37.5mpg!!! (but painfully slow, but range indicated at 500 miles, with 50 miles already on the tank.)
Constant 65 mph: 34.1 mpg
Constant 75 mph: 28.0 mpg
Constant 132 mph: didn't do long enough for valid reading, but it dropped entire 150 mile trip average almost 2 mpg for a 3 mile foot-to-floor fun.
.................................................. ................................Garrison-Jenner 2016 .................................................. ..........................................
Old 06-01-2005, 10:33 PM
FenPhen's Avatar
FenPhen FenPhen is offline
It's Highly Addictive!
Mein Auto: 2004 330i ZHP
When you come to a stop, clutch in, your instantaneous distance traveled decreases but your fuel consumption is constant (at idle), and so the instantaneous fuel economy goes toward 0. When you're actually at 0, the computer stops calculating the instantaneous economy and lets the needle go back to infinity.
2004 330i 6MT · performance package · silver gray · alcantara/cloth · black cube · xenons · pdc · aux audio
Old 06-01-2005, 10:50 PM
bmw330pp's Avatar
bmw330pp
They are very easy to install. You just open up your intake pipe and put it in(Remember to take it off if you go in for service, to avoid any bull$hit if you're still under warranty). I filled up yesterday and got 340 (I usually get 300) on the trip odo from 280 w/o tornado. As for HP, I think you loose it in the low end for some reason, but there is no noticeable gain. I had one on my civic with a CAI and I did notice more pull out of corners. I hope I notice a slight gain when I put a CAI in my 330.
Old 06-02-2005, 06:33 AM
Yes - but I meant it that the meter goes to the zero end of the scale (left) and then sometimes it blips up to about 30 MPG for a few seconds before it falls back to zero.
Old 06-02-2005, 06:48 PM
nv nv is offline
The blip is this.
There is a continuous and instantaneous calculation of your gas mileage. At a stop the calculation should produce 0 mpg (far right indication) because that is what you are getting. Just before the stop the needle is in transition to that far right position. BMW choose to display infinite mpg at stop (a far left indication) instead of the true 0 mpg. So as you stop the needle swing to the right (as it should) and then back to the left (by design) when stopped.
-Neil
Similar Threads
Replace car's grounding system improves gas mileage and horse power?? jaisonline Do-It-Yourself H.Q. 11 10-19-2012 10:01 PM
Gas mileage on 2004 325ci jklevine E46 (1999 - 2006) 27 03-26-2007 08:26 PM
Gas mileage for SMG vs Auto vs manual drbmw General BMW Questions 24 04-30-2004 04:29 AM
Thermostat question about gas mileage mseals 5 Series 2 01-25-2004 05:58 AM
Final drive ratio for 3-series and gas mileage rumratt 3 Series & 4 Series 9 11-02-2003 08:02 PM
