E36 (1991 - 1999)
Old 05-03-2005, 05:43 PM
94black325i 94black325i is offline
Mein Auto: 1994 325i
dash lite/R LIC PLATE lite stay on after switch is off
1994 325i
This is my fault but when I had to replace a fuse for the instrument panel lighting (FUSE #37) and I didn't have the correct amp fuse on me (10 AMP) i stuck a 30 AMP in there cuz that is all I had.
the car ran fine for a few days then started to smoke from behind the console and through the steering column inside the car. burnt rubber smell.
I replaced the fuses in the right places with the right AMP. But it seems that the burning caused a crossed wire somewhere or something. Here is what happens:
with all of the fuses in, the car seems fine and all the lights work everywhere but the computer says (LIC PLATE LIGHT FAIL, LOW BEAM LIGHT FAIL) while running with lights on. If you turn the car off and turn the light switch off, the console lites stay on and the R LIC plate late only stays on. the only way to turn them off is to remove FUSE #37.
is this a bad relay? A burnt and crossed wire? I've checked all fuses, all bulbs, everything OK.
where do I start to diagnose? any help would be great!
thanks!
Old 11-27-2006, 12:07 AM
pearl_iroc pearl_iroc is offline
Mein Auto: 1995 318i
i also have the same problem can some one plz post a reply and yes i have searched and found many people with the same questino but no reply
Old 11-27-2006, 07:33 AM
Pirate_copy's Avatar
Pirate_copy Pirate_copy is offline
Still here
Send a message via MSN to Pirate_copy
Mein Auto: M3
Sounds like a short to me buddy
The wires in the console are packed very tight together so when they got hot they would have melted together and that is what is probably causing the errors.
I have been guilty of putting too higher rated fuse in a 10amp slot too and almost blew the car up.
Easy to say with hindsight but always go with the rating they suggest. my old ford with a burned dashboard is proof hehehehe
2001 Mini Cooper R50
Edirty6 for life
Old 11-27-2006, 01:14 PM
hmm it could be a short but then all the park lights woulld be on..............on miine just the dash light are on no warning lights just the regualr lights that usually come on wen the parks lite are on also the switches for the windows illuminate and only the liscence plate lights are on outside ohh yea its a 318i 1995 by the way
Old 11-27-2006, 02:34 PM
Conehead Conehead is offline
Go you Good Thing
Mein Auto: e36 316I M
At the risk of being rude, this is why B.M.W. stipululate different AMPs for different fuses. Its like, you wouldnt put deisel in a petrol car, "because it the only fuel avaliable".
Take it to an auto-electrician, and get it sorted out properly, so your car dosnt burn out and bugger everything.!!
Old 11-28-2006, 04:10 PM
at the risk of sounding rude............if ur not gonna post any useful info plz dont post
Old 11-28-2006, 06:48 PM
Go you Good Thing
Well PEARL, I think my post is useful. If you dont like the reality sometimes, maybe you shouldnt be here. Go wrap yourself up in cotton wool.
The bottom line is that old mate knowingly put the wrong fuse in, and its buggered things up.
I think its a good bit of advice to tell him to take the car to an auto-electrician to fix it, because if he cant put the right fuse in, in the first place, what chance does old mate have to find a short or go playing any further with the electrics.
have a nice day, and dont chew the cotton wool wrapper.
The best predictor for future behaviour, is past behaviour. ALSO, IT SHOULD BE NOTED:......AMATURES BUILT THE ARK..AND PROFESSIONALS BUILT THE TITANIC..................QUOTE FOR THE DAY.. Good drivers know how to get out of trouble, and better drivers know how to avoid it.....The Cone 2006 & 2007
Old 11-30-2006, 09:03 PM
wow sumbody got there panties in a knot.......... an wut is this cotton wool wrapper u speak of......... ne how ............the dude asked how to fix it basically, not ur opinon on takin it to a garage Mate ohh an take it to a garage???????? um ne smuchk can tell sumone that
Old 11-30-2006, 10:10 PM
johnf's Avatar
johnf johnf is offline
John Firestone
Mein Auto: 1996 318is
These are common symptoms of broken and shorted wires inside the trunk to trunk lid cable. Push back the rubberized sleeve and examine the wiring where it bends most sharply approaching the trunk lid.
Old 02-11-2008, 08:17 PM
conehead sucks
the funny thing is I started this thread 3 yrs ago...
and yes it was my fault when I put the 30AMP in F37. I meant to replace it with the 10AMP later but I forgot, and it worked fine for a couple of days. it eventually fried my headlight switch and check control module when it became dark and I turned the headlights on. running that much juice through the F37 circuit fried my CCM and HL switch, naturally. it was summer time during the middle of the week so thats why I hadnt been driving with my Headlights on...
well, i replaced the CCM and headlight switch. Everything ok, CHECK CONTROL OK. This was 3 years ago.
dumb stuff happens, but yeah I agree with Pearl. if you're not going to help then dont post. any a$$hole can post "just take it to a mechanic." so conehead...you suck. go drive a honda.
Here's the best part. I've had no issues with this for almost 3 years. And sure enough...F37 is shorting again. Now Im not going to put a 30 AMP in it. But I think John F is probably right. I have a kink in the trunk wiring that is exposed to the metal, or perhaps another exposed wire touching something...and its been dormant for years and has now emerged once again!
....I figured it out once before, I will again!
Old 08-12-2011, 06:38 PM
stevyg13 stevyg13 is offline
I need to replace the Odometer light on a 325i 1994 any tips..would be greatly appreciated..StevyG
Old 08-12-2011, 08:16 PM
hornhospital's Avatar
D'oh, You Kids!
Props for searching, and welcome to the fest.
You need to bookmark this website:
http://www.pelicanparts.com/bmw/tech.../tech_main.htm
And here's your bulb replacement DIY:
http://pelicanparts.com/bmw/techarti...-90-Gauges.htm
Quotes to live by:
Similar Threads
Part # needed (removing front Lic Plate) sgran 5 Series 5 10-20-2004 11:12 AM
WTD: E46 Euro Dash Light Switch mchitiea Classifieds 0 08-19-2004 01:09 AM
Parking brake dash light switch ha123ppy 3 Series & 4 Series 1 06-01-2004 08:52 AM
Stay away from LAX if don't have a front license plate. SilverBmw Off-Topic 6 03-13-2004 11:34 PM
Math: Would you rather switch or stay? Mr Paddle.Shift Off-Topic 4 10-29-2002 12:22 PM
