Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series
3 Series / 4 Series
The 3 Series / 4 Series Forum. If you would like to see all new posts in all the forums, click here.
Old 07-21-2002, 06:10 PM
Steveww Steveww is offline
Mein Auto: 2007 328xi
Need help with V1 DIY Install
I have a2002 325xi (built 5/02). I'm doing the V1 install described at:
http://www.bmw330ci.com/DIY_V1.htm
When I removed the center panel, I found two wiring harnesses but they do not match up with the instructions: I found a 3-wire harness with a black (not white) connector, and the wire colors are not the same as those in the instructions. I also found a 5-wire harness which has a white (not black) connector; this harness did have a green-with-blue-stripe wire, which I tried, but it did not work. (I've previously wired my V1 into another vehicle, so I know how to use the connector tap.)
Is it possible I found the wrong harnesses? (How many unused harnesses can be up there?) The ones I found were easy to find-- I did not have to reach far to the right side of the car. Any suggestions at this point?
Btw, what are these two connectors used for?
Old 07-21-2002, 09:33 PM
The HACK's Avatar
The HACK The HACK is offline
Rest in peace, Coach
Mein Auto: '06 MZ4C, '09 WRX Wagon
Re: Need help with V1 DIY Install
The black harness is for the phone microphone. Keep digging in that general direction and you'll find the harness with the white plugs.
It sounds funny how the other harness isn't working. The wires in our cars are color coded.
"Bench racing" about track times driven by professionals are like a bunch of nerds arguing which Princess Leia is hotter, the slave Leia or the no-bra jail-bait Leia. No matter how compelling your argument is, the plain and simple fact is, none of you will EVER get to hit that.
Old 07-22-2002, 08:26 AM
FireFly FireFly is offline
Mein Auto: 330xi
Keep digging up on the passenger side and you'll find it. I also found the wrong harness but after looking and looking for the right one, finally found it and it works great.
330xi (sold)
1965 C2 Roadster
2005 X3 3.0
1997 TJ Sahara
2008 JK Unlimited Sahara
Old 09-08-2003, 01:25 PM
operknockity's Avatar
operknockity operknockity is offline
My TARDIS is a BMW
Mein Auto: '02 325i
Mine was nicely burried on the passenger side of the mirror. You might have to dig for it. Ignore any of the other harnesses (all the ones on the left side).
How many posts could a repost post if a repost could post posts?
Old 09-08-2003, 05:16 PM
remington's Avatar
remington remington is offline
Mein Auto: 05 545i
I also noted that the striping color in mine was slightly different than the description in the DIY instructions, I can't remember the details but it said green stripe and it was blue on mine or something like that. I just picked the wire that best fit the DIY description and it worked fine.
2006 E46 M3
Old 09-08-2003, 06:55 PM
My TARDIS is a BMW
Mein Auto: '02 325i
As long as it works and the power is switched on/off with the ignition switch you'll be fine. On mine the wires matched the described color scheme exactly. Though I believe the brown wire is actually ground (0 volts) rather than -12.
Old 09-16-2003, 05:39 PM
Scooter086 Scooter086 is offline
Mein Auto: 1995 BMW 325i
will this install be similar to a '95 325i? Is there a DIY article anyone knows aobut for older bimmers? Thanks.
Similar Threads
V1 install justcor E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) 10 04-30-2003 07:46 AM
DIY alarm install on wagon tenorGJ 3 Series / 4 Series 4 04-15-2003 04:20 PM
Xenon and V1 install today bmargolis E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) 3 03-28-2003 08:41 AM
where'd you install your v1? (..want pics) palooka666 3 Series / 4 Series 15 12-14-2002 01:25 PM
Just ordered my V1, how do I install it? Cowboy 3 Series / 4 Series 3 02-04-2002 09:08 AM
