CDV on E90 or not - Bimmerfest - BMW Forums
Old 05-09-2005, 09:24 AM
tierfreund's Avatar
tierfreund tierfreund is offline
Mein Auto: E90 330i
CDV on E90 or not
Has somebody figured out wether the E90 has the dreaded CDV or not?
No, NOT that kind of Tierfreund...
Old 05-27-2005, 07:26 AM
DZeckhausen's Avatar
DZeckhausen DZeckhausen is offline
Send a message via AIM to DZeckhausen
Mein Auto: 2012 BMW F30 328i 8-Speed
It does appear to have a CDV. The BMW part number is 21-52-6-764-872. Unlike the other CDVs I've seen, this one has a plastic body and simply clicks into place. I ordered a couple of them to see if they could be modified. So far, I haven't figured out how to do it without breaking the valve.
E90 CDV
E46 CDV
Dave Zeckhausen
Owner, Zeckhausen Racing
2015 BMW X1 xDrive28i M Sport
2012 BMW F30 328i Luxury Line 8-Speed
StopTech 4-wheel big brake upgrade
2001 BMW E39 540i 6-Speed (Traded-in for F30)
CDV deleted
Old 05-27-2005, 08:06 AM
tierfreund's Avatar
Mein Auto: E90 330i
If itīs just clipped and input=output, canīt you just take it out and plug in the hydraulics line directly?
Old 06-13-2005, 07:41 PM
djerbaka djerbaka is offline
Mein Auto: bmw
Any more info
I am very interested to know if this can just be removed, also.
Old 06-14-2005, 11:46 AM
It can be removed.
Dave Zeckhausen
CDV deleted
Old 06-14-2005, 11:52 AM
bimmer4me bimmer4me is offline
Mein Auto: 2006 330i
Originally Posted by DZeckhausen
It can be removed.
How??
2006 330i Monaco Blue/Grey/Walnut
...Manual/Sports/Premium/Cold/Nav/Comfort Access/PDC/Sirius/Sunshade
...Performance Center Delivery on Oct 14, 2005
Old 06-14-2005, 12:03 PM
Originally Posted by bimmer4me
How??
  1. Use a screwdriver to pry loose the spring clip at the female (wide) end of the CDV and at the end of the fitting the CDV plugs into.
  2. Remove the CDV.
  3. Connect the two loose fittings together.
  4. Push the spring clip on the fitting into place to secure the connection.
  5. Bleed the clutch slave cylinder.
Dave Zeckhausen
CDV deleted
Old 06-14-2005, 12:14 PM
  2. Remove the CDV.
Can a dealer or independent mechanic do this?
I have no idea what "Bleed the clutch slave cylinder" means (but it does sound cool ).
Old 06-14-2005, 01:09 PM
bjacques bjacques is offline
Mein Auto: ED (fun!) E90 330i
  2. Remove the CDV.
So you're saying that it will not be neccesary to modify the CDV? The device can just be removed, the lines have enough slack to reach, and the fittings are compatible, etc?
Old 06-14-2005, 05:50 PM
cwsqbm's Avatar
cwsqbm cwsqbm is offline
I do'nt make mistakes.
Mein Auto: Quadricycle
I maybe wrong, but the purpose of a modified CDV is not to have any warranty issues. Dealer sees missing CDV, makes a note, and later down the road maybe your clutch issue isn't covered under warranty.
.................................................. ...............................So long, Photobucket. .................................................. ..........................................
Old 06-14-2005, 05:58 PM
On some platforms, the modified CDV installation is easier than just removing the old CDV becuase some steel lines have to be bent otherwise. On the E46 and E90, you can just move the rubber line over. However, as cwsqbm pointed out, you won't retain the stock appearance if you just take it out and throw it away.
Dave Zeckhausen
CDV deleted
Old 06-14-2005, 06:08 PM
LarryN LarryN is offline
Mein Auto: '16 F82 M4, '97 332ti
I would guess that the e90 CDV is much less restrictive though (but I wouldn't mind experimenting with the bypass for a few weeks). Having both a e46 and e90 330i, I can say the clutch is much better in the e90.
I certainly wouldn't mind a drilled out replacement, if you figure out how to do it, Dave. The installation would be even easier than the e46.
Old 06-22-2005, 05:32 AM
The E90 CDV is more restrictive than the traditional metal CDVs. The opening is smaller.
The good news is that I have just perfected a technique for removing the valve mechanism without damaging the plastic body. A few valves had to be sacrificed for the cause, but it works now. I can provide modified E90 CDVs to anyone who wants them.
I only have two now, but I'll be ordering about 30 new valves from Pacific BMW today, so I'll be stocked up in about a week. That's assuming, of course, that there are a large number of E90 CDVs available for purchase. This order may take them by surprise.
Dave Zeckhausen
CDV deleted
Old 06-22-2005, 09:52 AM
Donnalee Donnalee is offline
Mein Auto: 760Li + 330i
D Zeckhausen for you and RHD E90 owners please note that RHD cars have a Different CDV valve, and they are NOT interchangeable
Old 06-22-2005, 10:17 AM
Thanks! I'll look into this and sort it all out.
Dave Zeckhausen
CDV deleted
Old 07-21-2005, 03:29 PM
I've confirmed that there are three different CDVs used on the various E90 platforms sold throughout the world. The good news for us Yanks is that both models sold here (325i and 330i) use the 21-52-6-764-872 valve pictured below. The 325i sold overseas in either left or right hand drive also uses this valve.
I tried to order the other two valves, p/n 21-52-6-764-876 and 21-52-6-765-120, but they are not available for sale in the USA. So I still don't know how they differ from the valve pictured above.
Here is the list of E90 models associated with each CDV type:
21-52-6-764-872
  • EU 325i LHD & RHD
  • EU 330i LHD
  • USA 325i LHD
  • USA 330i LHD
21-52-6-764-876
  • EU 320d LHD & RHD
  • EU 330i RHD
21-52-6-765-120
  • EU 320i LHD & RHD
Dave Zeckhausen
CDV deleted
Old 07-22-2005, 12:57 PM
speeedr speeedr is offline
Mein Auto: 2006 750i
Cdv
What purpose does the CDV serve?
Old 07-22-2005, 01:29 PM
It's there to ruin your driving experience.
But seriously, BMW put it there to reduce the potential for driveline shock if the car is driven by someone without the skill to feather the clutch the way it should be. It's one of those least common denominator things where the rest of us are paying for a few bad eggs out there. Sort of like the stupid bolstered lower dash of the USA model of the E39 5-Series that looks bad and steals lots of knee room, all because we tend to have lower setabelt usage than the rest of the world.
See: http://www.zeckhausen.com/CDV.htm for lots of CDV details
Dave Zeckhausen
CDV deleted
Old 07-22-2005, 06:37 PM
TigerNY's Avatar
TigerNY TigerNY is offline
Jai Ram Ji Ki :-)
Send a message via AIM to TigerNY Send a message via Yahoo to TigerNY
Mein Auto: Benz SL 500 & 06-325xi
LOL, honestly, i have no idea what a CDV is! And now,I do wanna know .. a total illitrate here when it comes to cars, even tho i have driven the best and the worst cars of the universe ..
So someone please put a lil light on, what it is , what its purpose is, and why it shoud be removed/broken ...
thanks much!
Old 07-22-2005, 06:45 PM
thanks much!
If you click on the link I provided in the post you quoted, I think you'll find the answers to just about any question you can think of about the CDV!
Dave Zeckhausen
CDV deleted
Similar Threads
Clutch Delay Valve (CDV) on E46 M3 DZeckhausen 1M & M2 26 11-27-2005 06:51 AM
3.15 rear diff in E90 330 Moderato E90/E91/E92/E93 (2006 - 2013) 5 02-23-2005 01:09 PM
E90 expectations and rumored components Andm99 General BMW Questions 0 02-26-2004 07:33 PM
June 14, Bay Area CDV Clinic, E39 (MORE! 6/2/03) Ågent99 5 Series 18 06-09-2003 08:41 AM
Clutch Delay Valve (CDV) Information Karl 3 Series & 4 Series 8 11-18-2002 11:46 AM
