E34 (1989 - 1995)
Old 05-11-2005, 05:35 AM
sim5556 sim5556 is offline
Mein Auto: 530i
How to remove door panel ?
My driver side window is off track. How do I remove the door panel?
Old 09-08-2010, 10:38 AM
jltran jltran is offline
Mein Auto: bmw x5
same problem!!! if someone would post a reponse that would greatly help
Old 09-08-2010, 01:28 PM
CarDriver's Avatar
CarDriver CarDriver is offline
Mein Auto: 1992 525it /2004 ML350
Pry out the mirror control switch, there is a torx screw in there. behind the interior door handle, there will be one more screw. Look carefully for that one as it has a plastic cap covering it. Once you have the two screws removed you can begin pulling the door panel out from the door. Begin at a bottom corner and work your way across then up each side. It is held on by plastic snaps. Once you have all the snaps unfastened, lay on your back under the door with a flashlight. behind the door panel just about center is a clip that you need to release with a screw driver. You will see what I mean when you get to that point.
After all that is done, unscrew the door lock knob and wiggle the panel upward and out. A few of your plastic snaps will break but they are about a buck each from the dealer or can be ordered on line.
Or LOL... (Just found this after I typed all the crap above.)
http://www.bmwe34.net/Wiki/tiki-inde...ge=Door+panels
Old 09-08-2010, 03:53 PM
CarDriver's Avatar
Man, as of this reading 4,609 people read this post and only one guy (me) responded??? Time to find a better forum LOL...???
Old 08-10-2012, 10:04 AM
Selbo Selbo is offline
Mein Auto: 1995 e34, 2006 e46
Panel
After reading your comment, I couldn't help but sign up so I could say thanks. :-)
My driver's side window just fell forwards in its guide, so I'll be going in the door panel tonight to fix it. I'm assuming that the forward guide nut fell off because I heard what sounded like a quarter falling through a gumball machine.
Old 08-10-2012, 04:04 PM
goosefoot33's Avatar
goosefoot33 goosefoot33 is offline
Manualaholic
Mein Auto: 01 330Ci/02 525iT
I think because it has a title that a lot of people search for (in Google or Yahoo or whatever kids are using nowadays), and it also contains a link to e34.net with a detailed DIY of it. I can't imagine how many views his site gets in a day. I know I've used it at least 20 or 30 times.
BMWCCA Member# 451235
(Summer) 2001 330Ci - ZSP
(Winter) 1994 530i "Greenie" - PARTING OUT! (PM for details)
(Grocery Getter) 2002 525iT
Old 08-10-2012, 04:18 PM
Manualaholic
EDIT: Your link does not seem to work any more... as of 8/10/2012, this link works: http://www.bmwe34.net/E34main/Mainte...oorRemoval.htm
Old 11-06-2012, 11:43 AM
steve rob steve rob is offline
Mein Auto: bmw x3 2.0d
how do i remove drivers door panel
Old 11-06-2012, 11:47 AM
Monsignor's Avatar
Monsignor Monsignor is offline
BMW CCA Memeber #445389
Mein Auto: Sig
Read the 3rd post.
PLEASE READ THREAD BEFORE POSTING. did you read any of it?
EDIT: I see your "mein auto" says a 2.0L diesel X3. you, sir, are not in the right forum. this if for 1989-1995 5 series.
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
Old 11-17-2012, 07:04 PM
linklaterdavid linklaterdavid is offline
Mein Auto: 1991 525i
thank you for the link cardriver!
Old 02-15-2013, 03:06 PM
mj1955 mj1955 is offline
Mein Auto: 1995bmw 525i
great to be onboard need to remove my door panel on drivers side window is of its track
Old 02-15-2013, 03:12 PM
south26 south26 is offline
Mein Auto: 535i 1989
if you do not read, I would suggest cutting the door panel off. or read the first 3 posts.
Old 02-25-2017, 03:03 PM
BetterNot BetterNot is offline
Mein Auto: 760Li
Here is the link to the video of showing the process of removing the rear doors. For front ones, you will just have to pry open the power mirror switch.
Similar Threads
Shock & Spring Write-up Ågent99 5 Series DIY 14 10-13-2007 08:28 PM
How to remove this part? "Stop switch" on back of sport seats.. TurnAround E36/7 Z3 (1996-2002) 8 04-02-2005 04:32 AM
91 850i Heater Core Removal Instructions Wanted nicko 7 Series & 8 Series 1 10-18-2004 10:56 PM
3.46 installed JonM E36/7 Z3 (1996-2002) 15 12-11-2003 10:54 AM
