Old 07-22-2002, 08:04 PM
Ron Stygar's Avatar
19,585 Miles
S54 valve adjust update
Received some valve adjusting plates today. Ordered six each of the six smallest sizes (thickness wise). Smaller than I thought.
Pic of adjusting plate as shown in the parts data.
Pic of tool 88 88 6 113 160 showing the individual components.
The S54 stuff 88 88 6 113 163 didn't come with mine. Will call on this tomorrow.
Original post that was made on the other board.
Old 07-22-2002, 08:05 PM
Ron Stygar's Avatar
19,585 Miles
rest of original post pics
Old 07-22-2002, 08:13 PM
Ron Stygar's Avatar
19,585 Miles
S54 cylinder head cover removal part
Old 07-22-2002, 09:37 PM
Randy Forbes's Avatar
Investigative Tinkerer
Oh boy! I can't wait until I have to do this...
As mine sits in the garage tonight, it has 12002 miles on it.
Probably right after HC I'll be due.
Wish that you had a couple more thousand miles on yours!
Randy Forbes
2001///M Rdstr Steel Gray
Old 07-22-2002, 09:44 PM
scottn2retro's Avatar
scottn2retro scottn2retro is offline
into things retro
Mein Auto: '02 M3 SMG & '08 135i
What's the valve adjustment interval on the S54s?
Old 07-22-2002, 09:55 PM
Ron Stygar's Avatar
19,585 Miles
I have 10,500 on mine. The valve check/adjust is scheduled to be done at Inspection I according to my service manual. Based on the way my lights are going (10072 miles = one green light left) it would be around 25K.
Oil service, Inspection I, Oil service etc.
Old 08-03-2003, 06:34 PM
Mr. The Edge's Avatar
Mr. The Edge Mr. The Edge is offline
Mein Auto: .
Ron, I'm wondering if you might have an idea about something I found under my hood today. (I have a 2002 M3 if you recall).
I'm including it in this old thread because I thought it might be related to my recent Inspection I service.
http://www.bimmerfest.com/forums/showthread.php?t=37072
anyone else with an idea chime in too
Old 08-03-2003, 07:33 PM
Ron Stygar's Avatar
19,585 Miles
Check out the cylinder head cover pics in this post.
Old 08-03-2003, 07:54 PM
Mein Auto: .
yep, got it now...thanks
Old 01-07-2009, 02:25 PM
pal's Avatar
pal pal is offline
S54=Living on the Edge
Mein Auto: 2007 M Coupe, 2004 Audi T
Bumping up this post with some updated part numbers and prices since I called around today. Looks like below are the 4 part numbers we need to order for an S54 valve adjustment job. Additionally, we will need to get a box of shims and I dont have a part # for that.
88 88 6 113 160 (superceded by 83 30 0 490 942) Holder with feeler guages
5 or 6 blades .25, .30, .35, .40, .45 (all in mm)
$31.06 at mileoneparts.com
88 88 6 113 163 (superceded by 83 30 0 493 754)
1 or 2 blade set .15 and .20 mm
$5.42 at mileoneparts.com
90 88 6 115 100 (superceded by 83 30 0 491 056) Tool for vibration damper on crank
$62.81 at mileoneparts.com
90 88 6 114 400 (superceded by 83 30 0 493 743) Magnetic plate removal/install tool
$29.62 at mileoneparts.com
[Edit- Thanks Ron]
Box of shims: 11 34 0 031 525 $346.40 @ mileoneparts.com
Old 01-07-2009, 03:00 PM
Ron Stygar's Avatar
19,585 Miles
http://www.bimmerfest.com/forums/sho...7&postcount=23
Old 01-07-2009, 03:01 PM
Ron Stygar's Avatar
19,585 Miles
Parts
Ordered some valve parts to see how the shims fit and how the retaining clips come out, which wasn't clear (to me) in the instructions. It is now.
Old 01-07-2009, 03:47 PM
Ron Stygar's Avatar
19,585 Miles
[Edit- Thanks Ron]
84 30 0 490 942 $38.83 retail $29.12 from http://www.trademotion.com/partlocat...?siteid=214760
83 30 0 493 754 $6.72 retail $5.08 from "
83 30 0 491 056 #78.51 retail $58.88 from "
83 30 0 493 743 $37.03 $27.77 from "
11 34 0 031 525 $457.05 retail $342.79 from "
Old 01-07-2009, 07:47 PM
Originally Posted by Ron Stygar View Post
For the sake of convenience:
Randy Forbes
Old 01-07-2009, 07:51 PM
Ron Stygar's Avatar
19,585 Miles
Price went up a little.
Old 01-07-2009, 07:54 PM
Seems I paid right around $225.00 back then.
Randy Forbes
Old 01-25-2010, 03:04 PM
scansp7 scansp7 is offline
Mein Auto: 02 m3
Does anyone know what the torques specs were for the valve cover nuts?
Old 01-25-2010, 03:40 PM
Ron Stygar's Avatar
19,585 Miles
10Nm.
Do you have a BMW TIS repair disk?
Old 01-25-2010, 03:54 PM
Starscream88 Starscream88 is offline
Mein Auto: Imola Red ///M Roadster
So you can't buy the individual shims anymore? Only the entire set?
Imola Red Roadster
Old 01-25-2010, 07:04 PM
jmillet's Avatar
jmillet jmillet is offline
Mein Auto: E86 Z4 M Coupe 7LM08376
Not sure what you mean by "valve cover". The S54 engine has a black plastic cover called the ignition coil cover. It is secured with chromed interference fit cap nuts. Just snug them down; 10N*m sounds about right
Underneath the ignition coil cover resides the cylinder head cover again secured with interference fit cap nuts and rubber grommets. Just snug these down too; 10N*m sounds about right.
Take Ron's advice and get yourself the TIS DVD.
Jim Millet
2007 Imola Red Z4 M Coupe'
Premium Package, Nav, HD Radio, Heated Seats, CDV Delete, RPI Scoop, Strong-Strut fire wall braces, TCK DA Coil Over Suspension with Camber/Caster plates.
Old 01-25-2010, 07:06 PM
jmillet's Avatar
I recently purchased individual shims from North Haven.
Jim Millet
Old 01-25-2010, 07:10 PM
Ron Stygar's Avatar
19,585 Miles
It's in the TIS torque area 11 12 as 10Nm.
Couldn't find anything on the chrome ones but the same M6 thread.
Old 01-25-2010, 07:25 PM
jmillet's Avatar
Or 7.38 ft/Lbs or 88.56 in/Lbs. In any event it ain't much
Jim Millet
Old 04-24-2010, 06:42 PM
Steveo Steveo is offline
Mein Auto: E46 M3 Convertible - SMG
New to Me M3 Needs Valves Checked/Adjusted
I'm ready to tackle this job on my 2003 E46 convertible. Seem to have all I need except maybe the nerve to get to it! Is there a particular trick to using the special magnetic tool, or is that small hole in the handle just for kicks? If I need to make a shim change, should I target a measurement somewhere in the middle of the tolerance, or closer to one end? What I mean is, since the intake range is .18 - .23 mm, is it better to go for .20 or .21 for instance? Safer to be on the high side (.23) or low (.18)? Thanks!
Old 04-25-2010, 10:40 AM
I prefer to leave them on the looser side of tolerance; .18-.23, so I shoot for .20-.22.
Loose valves will not cost you money, but tight ones will. The ONLY cooling the exhaust valve gets is while it is in contact with the seat; tightening the clearance shortens the time spent closed.
The performance difference is negligble, so unless you have a $100,00.00 cash prize for arriving at the next stop sign 1st, don't even worry about it.
Randy Forbes
Similar Threads
Update on S54 EML light and Service engine soon light gbrown E36/7 Z3 (1996-2002) 6 10-17-2012 10:17 PM
Valve adjust feeler gauge kit (S54 pieces) Ron Stygar E36/7 Z3 (1996-2002) 5 04-03-2008 09:13 PM
BMW Update for S54 Engines BMWNA 1M & M2 2 08-13-2003 06:55 PM
S54 M coupe 3.73 diff impression Edwin Huang E36/7 Z3 (1996-2002) 20 06-15-2003 06:04 PM
RE: M3 S54 Service Action Jon Shafer General BMW Questions 1 04-29-2003 10:52 AM
