X5 35i with 101K mileage, just got car and have no service history.
Very rough idle--Code 28A0 Throttle valve opening angle-intake pipe absolute pressure, comparision pressure too high.
Just replaced a filthy air filter-looks like original, cleaned charge pipe an throttle body. I did reconnect vacuum to back of TB with (new gasket) and electrical connector.
I understand what the computer is trying to compare, just not sure what else to check??
I checked all vacuum lines, pressure switchs, and MAF sensors. Nothing looks out of place. The Plugs and coil look original, which i will replace.
I also found a two pin connector directly below Throttle Body that isn't connected to anything? 2-BMW mechanic's at local dealership said it just an extra wire?? Pic attached
