E34 (1989 - 1995)
hope somebody may be able to help.my car has been parked up outside the house for approx 18mths,due to having company vehicle.in this time whilst not being used it has developed an overheating problem.have renewed thermostat,all heating and ventilation working fine.there is no sign of oil emulsification,has any body had asimilar problem or does anybody have any suggestions.
rad cap
ps or your water pump might be kaput ! Last edited by markusamigos; 05-14-2005 at 02:08 AM. |
Ihad same problem it was the thermostat
When does it overheat?
If it overheats at idle, or stopped in traffic you most likely have an airflow problem. Fan clutch is likely and possibly aux electric fans though less likely in the winter. If overheating at road speed, there is plenty of airflow, you have a coolant pumping issue. Water pump is likely, some sort of blockage is possible. I wouldn't always assume a headgasket on a 535, the big six is wonderfully durable, just don't overheat it badly, or often. So if the coolant level is good, the thermostat is new, the system is filled and giving cabin heat, and the cooling system has been drained and filled, I think it is one of the above suggestions depending on symptoms. Good Luck
Winter Rules
#superoldthread Sent from Joe's Galaxy SIII via BimmerApp
![]() 1995 525iA 250k mi Shifted Performance E34 2006 325i/6 48k mi 2003 350Z 87k mi Shifted Performance 350Z Garden State Euros |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 7 Series Sport Package is coming... | Jon Shafer | General BMW | 6 | 03-03-2003 05:29 AM |
| Sport seats without the sport package for ED? | dlloyd1975 | Regional Forums | 12 | 01-16-2003 05:04 AM |
| BMW Sport Compact a Mercedes-killer? | ChrisTO | General BMW | 2 | 10-14-2002 10:04 AM |
| Toying with the idea of an E34 M5... | Mr Paddle.Shift | General BMW | 12 | 05-13-2002 12:24 PM |
| Wow! The G35 Coupe looks good! (link inside) | Sean | Off-Topic | 12 | 03-29-2002 11:48 AM |
