Old 05-13-2005, 11:41 PM
Ron Stygar's Avatar
19,585 Miles
Lets do a valve clearance check/adjust on my '01 M coupe
Interesting job. I agree with QikSilver. Hard to believe a flat rate guy does this right.
Asked Jay about it. He said this is a job you have to take your time at and stay focused.
Took it apart and cleaned up things tonight.
Will attempt the valve check/adjust tomorrow.
If things go well, will put it back together Sunday or Monday, assuming that I will be finished polishing the spare cylinder head cover I purchased.
Awesome engine.
Old 05-13-2005, 11:44 PM
Ron Stygar's Avatar
19,585 Miles
parts
parts
Old 05-13-2005, 11:45 PM
Ron Stygar's Avatar
19,585 Miles
parts
x
Old 05-13-2005, 11:46 PM
Ron Stygar's Avatar
19,585 Miles
x
x
Old 05-13-2005, 11:48 PM
Ron Stygar's Avatar
19,585 Miles
x1
x
Old 05-13-2005, 11:49 PM
Ron Stygar's Avatar
19,585 Miles
x2
x
Old 05-13-2005, 11:51 PM
Ron Stygar's Avatar
19,585 Miles
x3
x
Old 05-13-2005, 11:52 PM
Ron Stygar's Avatar
19,585 Miles
x4
x
Old 05-13-2005, 11:53 PM
Ron Stygar's Avatar
19,585 Miles
x5
x
Old 05-13-2005, 11:55 PM
Ron Stygar's Avatar
19,585 Miles
x6
x
Old 05-14-2005, 06:13 AM
Randy Forbes's Avatar
Investigative Tinkerer
What dimension are you shooting for; split in the middle or maximum allowable loose/tight?
Considering your mileage (nearly same as mine) I'll be interested in your worksheet results (as found #'s).
Randy Forbes
2001///M Rdstr Steel Gray
Old 05-14-2005, 05:21 PM
Ron Stygar's Avatar
19,585 Miles
Will do.
The spec range is .05 mm. The shim increments are .04 mm.
Just measured cylinder one, intake #2. Spec. is .18 > .23 mm. The .15 mm feeler went in, The .20 mm feeler did not. A .007" (.178 mm) feeler went in.
I purchased some 12 inch stainless feelers from McMaster carr. .04 mm, .06 mm, .07 mm (on back order), .08 mm and a .09 mm. The .04 mm with the .15 mm doesn't go in.
So I'm calling this one .18 mm +.
The intakes are a pain to measure. Changing shims on cylinder six will be interesting too.
Have to come up with a way to cover the holes. The rag is just too risky.
Old 05-14-2005, 06:03 PM
01silber's Avatar
01silber 01silber is offline
Im here
Send a message via AIM to 01silber
Mein Auto: 2001 Z3 3.0i
Not that im as good as you guys are but , looking at the "hole of no return" It look like if you made a wedge out of delrin or whatever, like a wedge of cheese you coould set it in there and it would seal snug all around
Old 05-14-2005, 09:04 PM
QikSilver's Avatar
QikSilver QikSilver is offline
Too much is never enough
Mein Auto: 01 M roadster
Awesome engine.
Oh, yes.
Nice photos. Your engine looks great; you polished those parts, the oil filter cover, vanos covers and throttle vent pipe? (the pipe looks plated)
John
01 M roadster, F: GC/Koni short coilover struts, Eibach, Wilwood front brakes, GC tubular swaybar. R: TC Kline springs, short Bilsteins, IE sub & swingarm bushings & shock mounts, 3.23 gear, Rogue dual-ear cover, Eisenmann 4x83 pipes. MISC: Sport mode, Rogue pulleys, keyless, RG Motorsport intake, OZ Superleggera 18" 3 piece.
06 Hemi Durango
04 G35 Coupe
05 Scion xB
07 Scion tC
89 Reynard F2000
Old 05-14-2005, 09:21 PM
Ron Stygar's Avatar
19,585 Miles
The oil filter cover, air and fuel rail and exhaust heat shield are plated along with some other things. Vanos is polished but not finished. Cylinder head cover is almost done being polished.
Did you notice any sealant under the profile gasket at the half moons in back and the vanos head intersection. There is none on mine so I guess they no longer do this as mentioned in the TIS instructions.
Old 05-14-2005, 09:58 PM
Ron Stygar's Avatar
19,585 Miles
Randy:
Here is your worksheet. Numbers on the left are the sequence as you rotate the crank CW looking at it from the front. So if you start at cylinder three intake it then goes to cylinder two exhaust and then cylinder six intake etc.
There is a feeler gauge place 24 miles from me. Will try to get them to make some angled feelers in .01 mm increments around the spec values.
Will also look into plugging the holes.
Old 05-14-2005, 10:29 PM
Randy:
Here is your sheet. Numbers on the left are the sequence as you rotate the crank CW looking at it from the front. So if you start at cylinder three intake it then goes to cylinder two exhaust and then cylinder six intake etc.
Will also look in to plugging the holes.
Thanks! Your values are pretty much what I would expect mine to be (based on a couple of M3 guy's comments).
A line mechanic would pronounce that within specs (and rightly so). What's your call on it?
Before BMW made the "new" feeler gauges available, I had bought some 12" Starrett ones. I couldn't bend them without breaking them; I figure it must be done before they are tempered. If your source can provide them, I'll go in with on some if you're willing.
BTW, I thought you had the later worksheet that went by firing order. Seems that with each cylinder at tdc, you wouldn't have to skip around as much. Of course using a worksheet, it's not likely to miss anything. Were you just going on visual (lobes straight up)?
Randy Forbes
Old 05-14-2005, 10:36 PM
... Did you notice any sealant under the profile gasket at the half moons in back and the vanos head intersection. There is none on mine so I guess they no longer do this as mentioned in the TIS instructions.
My guy still uses the sealant at the half moons (and any other "joints"). He made that clear when we pulled the S-52 head. BTW, their soucre for the Drei Bond (equivalent) is from their Chrysler dealer (Daimler carryover?). We used black Permatex hi temp silicone.
Randy Forbes
Old 05-14-2005, 11:19 PM
Ron Stygar's Avatar
19,585 Miles
I'm happy with the results enough not to mess with it. Intakes are at the tight end and exhausts are in the middle. The problem is not knowing what they were new. So it's hard to say if there was any wear or not. Now that I have a reference, I will know the next time. Based on the intakes being on the tight end, my guess is no wear.
I broke one doing the same. Will see what the gauge place says Monday. Hoping their custom minimum is a few sets.
I have both sheets but grabbed the one I used. I went with the lobes up sequence which would be the minumum turns. Just turned until the next one came up. Intake, exhaust, intake, exhaust etc.
Old 05-14-2005, 11:34 PM
Ron Stygar's Avatar
19,585 Miles
Since it wasn't there, I'm leaning on leaving it out which will gaurantee a leak.
http://www.bimmerfest.com/forums/sho...ight=drei+bond
Old 05-15-2005, 03:53 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
I would be interested in a set of the special feelr guages also.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 05-15-2005, 08:20 AM
Razorbak Razorbak is offline
Ron, why do posts #2-10 on this thread contain only x's (no text or photos)?
Old 05-15-2005, 08:45 AM
Just a hunch, but had Ron needed to swap shims in valves 1-6, you'd see detailed pictures and text for each cylinder.
He "reserved" a block of posts to keep all the technical content together. A useful touch when you think about it.
Randy Forbes
Old 05-15-2005, 11:34 AM
dwm's Avatar
dwm dwm is offline
Send a message via AIM to dwm Send a message via Yahoo to dwm
Mein Auto: 2002 M roadster
Count me in for the custom feeler gauges too.
Daniel
2002 M roadster
Old 05-15-2005, 11:43 AM
QikSilver's Avatar
No, and I didn't add any. And I've got no leaks.
About the feeler gauges, if you have an angled set that go from say .005" to .015" in .001" increments, that will do the job nicely. Make sure the gauges have the thickness printed on them in inches and mm's. I like to work in inches from past experience, I simply cannot visualize or relate to .19 mm. Also make sure you have a digital vernier caliper that reads both inches and mm's. I picked up 2 of them on ebay for about 10 bucks each. They're Chinese, but dead-on accurate, I checked them against my Brown & Sharpe.
Pretty smart of Ron to "reserve" space in the thread, and smart of Randy to figure out what he was doing.
John
06 Hemi Durango
04 G35 Coupe
05 Scion xB
07 Scion tC
89 Reynard F2000
Similar Threads
Lets 3.46 differential my '01 M-Z3 coupe, part 1 Ron Stygar E36/7 Z3 (1996-2002) 82 11-28-2013 06:42 AM
Lets battery my '01 M coupe Ron Stygar E36/7 Z3 (1996-2002) 89 09-06-2010 02:59 AM
More 04 coupe facelift info jason330i 3 Series & 4 Series 13 01-12-2003 01:12 AM
To Coupe or to not to Coupe bmwguynj 3 Series & 4 Series 32 06-14-2002 06:23 PM
Wow! The G35 Coupe looks good! (link inside) Sean Off-Topic 12 03-29-2002 11:48 AM
