Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M Series > E36 M3 (1995-1999)
E36 M3 (1995-1999)
Old 05-14-2005, 03:28 PM
Jon Shafer's Avatar
Admin • Owner • Enthusiast
Bimmerfest Founder
Mein Auto: E92 M3 Cp
Under panel flew off on hwy...
Is this a common problem?
What do the OEM replacement parts run?
Old 05-14-2005, 05:05 PM
Josh (PA)'s Avatar
Josh (PA) Josh (PA) is offline
superwagon pilot
Send a message via Yahoo to Josh (PA)
Mein Auto: 99 M3c, 04 MDX
Happened to me at 90mph on the PA turnpike last year. OEM replacement panels ( I needed the under panel, vertical piece and the two "porkchops") installed ran about $300 installed at my non-dealer BMW mechanic. I don't think it's a common problem if the panel is replaced correctly after services, but I expect that a shop i took my car to before finding the guy I used now skipped a few of the fasteners.
Sorry Jon, welcome to the e36 club. At least you already have two of the biggies down (underpanel, and brakelight) now all you need is the thermostat and airbag light...
Old 05-14-2005, 05:22 PM
Jon Shafer's Avatar
Bimmerfest Founder
What a bummer...
Yeah, I was going sort of fast (3 digits) when it came undone...
Thanks for the info Josh.
Okay, so I have heard about the radiator/H20 pump/thermostat, but not the
airbag light...
What's the deal with the airbag light?
Old 05-15-2005, 03:47 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
If it is the forwad underpanel, JT designs does a nice aluminum one.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 05-15-2005, 11:20 AM
Jon Shafer's Avatar
Bimmerfest Founder
Thanks Pinecone.
Do you know if the JT Designs panel is simple to install?
Anyone here done this? I suppose that I'll need access to a lift?
Old 05-15-2005, 12:06 PM
·clyde·'s Avatar
·clyde· ·clyde· is offline
OMGWTFBBQ
Mein Auto:
It's a pretty common problem on E36s that see much autocrossing. Actually, it's not exactly uncommon on any car with a similar underpanel secured by crappy fasteners that sees much autocrossing. Running over cones (not hitting them, but running them down) tends to rip the fasteners right out.
OH NOES!!!!!1 MY CAR HAS T3H UND3R5T33R5555!!!!!!1oneone!!!!11
Team WTF?!
What are you gonna do?
Old 05-15-2005, 12:32 PM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
Mein Auto: 01 325iT, 88 M6
I've helped install the JT one, and I don't know if I'd exactly call it 'nice.'
2001 325i Touring Alpinweiss/Anthracite cloth, Alpina Softline
1988 M6 Royalblau/Silbergrau Nappa
Old 05-15-2005, 12:50 PM
BahnBaum's Avatar
BahnBaum BahnBaum is offline
Empowered Consumer
Mein Auto: 1 - 4.20hp, 1 - 420hp
Thanks Pinecone.
I can't imagine needing a lift to do this. Jackstands are fine.
Alex
Interrobanged.
My Flickr
TeamWTF?!
Old 05-15-2005, 12:56 PM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
A lift? Probably easier to hold the pieces up with the car close to the ground.
Old 05-15-2005, 05:48 PM
Jon Shafer's Avatar
Bimmerfest Founder
Thanks for the feedback...
Sounds like the aluminum panel may be unnecessary?
Old 05-15-2005, 05:55 PM
Nick325xiT 5spd's Avatar
Nick325xiT 5spd Nick325xiT 5spd is offline
Send a message via ICQ to Nick325xiT 5spd Send a message via AIM to Nick325xiT 5spd Send a message via Yahoo to Nick325xiT 5spd
Mein Auto: M3 & 323i/999 KP
The consensus that I've seen is that whether the JTD undertray is nice or not, it doesn't seem to fall off randomly.
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison 6-speed
2002 BMW M3 Alpinweiß/Black
1999 323i KP/GTS2 Alpinweiß
1990 325is Brilliantrot/Tan
1989 325is S50B30US Alpinweiß/Black
1989 M3 Alpinweiß/Black S50B32 (321hp, ITBs)
Old 05-15-2005, 06:06 PM
Pinecone's Avatar
M Mad
And THAT is the big point.
I have mostly good things about them, but have no first hand knowledge. The LTW uses the splitter as the underpan.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 05-15-2005, 06:09 PM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
Yeah, it uses a bunch of screws so it shouldn't fall off.
Old 05-15-2005, 09:14 PM
Jon Shafer's Avatar
Bimmerfest Founder
I guess what I'm trying to say is that if I don't plan on running over any
cones or scraping over anything else, sounds like I probably won't need
to go as extreme as the aluminum panel -- especially if the installation
is not clean (read: pita)? Will the (OE) fasteners hold secure under normal
(sic) driving conditions? The one that came off looked like it had been
banged up previously on curb stops or something.
Old 05-15-2005, 09:35 PM
Josh (PA)'s Avatar
superwagon pilot
What a bummer...
airbag light...
I think the airbag light is caused by crappy front seat belt sensors. If the sensor doesn't work, even for a brief time (seconds), the airbag check light will illuminate and stay on until it's reset. I know it's very common on z3s, do a quick search on that board I think Ron had a thread about it.
Old 05-16-2005, 12:32 PM
seanramey63 seanramey63 is offline
Mein Auto: E36 Dakar II M3 Sedan
JT designs plate is relatively simple, lots of fastening to do, if your wheel wells are messed up(missing or busted screw holes) you will need to replace them
Old 05-16-2005, 12:38 PM
Jon Shafer's Avatar
Bimmerfest Founder
Thanks for all of your input. I decided to go with OEM - the price was too good to pass
up from BMW Santa Barbara; "Internet/Bimmerfest Special" was about half of the price
of the aftermarket. If I can get get another 6 years out of it that'll be great...
Similar Threads
LeatherZ E46 Gauge Panel Install w/photos Scott ZHP E46 (1999 - 2006) 40 07-06-2010 02:48 PM
1996 318is drive panel lights don't work Das Chimney E36 (1991 - 1999) 2 03-27-2008 04:04 PM
e60 Instrument Panel Blanked quad 5 Series 0 12-31-2004 11:51 AM
2003 and 2004 M3 Coupe left inside Trunk Panel Zappo M Series 2 10-15-2003 04:44 PM
