Hi All,
This is my first post here and my first ever BMW so please be gentle
I acquired a late 2011 E90 325i 6speed manual., done 84k miles. The car looks very well and drives well, but has a few strange issues I've never experienced with another car.
1. When in gear ( apart from 1st ) and below 900 rpm when I accelerate the car stutters at around 1100 rpm for 2,3 seconds , then all is good and it continues as normal. This happens in 2nd , 3rd , 4th, I haven't tried it in 5th or 6th.
2. When coasting in gear , there is a mechanical whine ( grind metal on metal ) coming from the engine compartment. Could it be a flywheel or a clutch issue ? It is pretty consistent in all gears. If I put the clutch down , the noise goes away.
3. When in 4th and accelerating a strong vibration is coming though the gear stick. Doesn't happen in any other gear.
4. When idling the engine sounds like a diesel, I read on the forum that it's normal, but not too sure about that.
5. What is the best way to get the code to update the satnav ?
6. There is quite a bit of carbon build up in the exhaust pipes, should I worry about it ?
7. I attached the Bcables cable to the odb port and got these two errors, I cleared them but not sure if they are important or not.
8. My car seems to have BMW Online , but the internet browser does not connect, if my phone is connected via Blutooth it seems to get internet from it, but not sure how it works.
Nick
Nick
