Old 05-19-2005, 01:02 AM
Ahem Ahem is offline
Mein Auto: BMW
Shut the air conditioner off with a single click
Can the a/c be shut off with a single click on the E39?
The only way I know how to shut the air conditioner off is to press the down button (-) as many times as needed until there is only one LED lit on the orange electronic ramp - and then one more click of the (-) button finally shuts off the ac.
That could be as much as a dozen clicks.
I can use the one-click "MAX" button to turn ON the ac - but is there a way to turn the ac off with a single click that I missed?
Old 05-19-2005, 06:55 AM
SRFast's Avatar
SRFast SRFast is offline
Mein Auto: 2003 BMW 530i
The "snowflake" button is the AC on/off swtich. Why aren't you using that? The -/+ button is used to control fan speed aqnd the MAX button just sets the fan speed to the highest level when activated.
Hope this helps....JL
2003 530i 5spd/SP/PP/CWP/PDC/RSAB/Xenons
Old 05-19-2005, 08:28 AM
Ågent99's Avatar
Ågent99 Ågent99 is offline
Moderator, 5-Series
Mein Auto: Trek 6500 MTB
Well, as pointed out above, you are talking about two separate functions:
(1) A/C
(2) Fan speed
I'm going to assume you'd like to shut down the fan speed with one click (because, if fan speed is zero, essentially you've shut off the A/C/heater). Well, you can't. However, if you hold the - button down on the fan speed, it will go a bit faster I think.
One thing that has always annoyed me about the climate control in the car is that it won't remember that you've shut the fan speed down to zero. When you re-start the car, the fan speed comes on at the lowest speed setting. Well, at least *I* could never get it to come on with zero fan speed.
Old 05-19-2005, 10:50 AM
vexed's Avatar
vexed vexed is offline
Senior Slacker
Mein Auto: 9A1
(1) A/C
(2) Fan speed
I have noticed that if I shut the fun off before shutting off the car and then restart it within a certain time frame (and don't ask me what it is ) the fan remains at 0. Otherwise I usually push the - once before I crank the engine so the a/c does not come on. It is an annoyance but better than I-drive.
vexed
Old 05-19-2005, 04:24 PM
rost12's Avatar
rost12 rost12 is offline
round -n- shiney
Send a message via ICQ to rost12 Send a message via MSN to rost12
Mein Auto: m5, 911
On i-Drive'd 7 there's a simple "OFF" button for all of the HVAC system
Old 05-19-2005, 11:01 PM
Mein Auto: BMW
Originally Posted by SRFast
The "snowflake" button is the AC on/off swtich. Why aren't you using that? The -/+ button is used to control fan speed and the MAX button just sets the fan speed to the highest level when activated.
Ughh. I did not realize that. I went back to the owners manual today and reaffirmed that you are correct. So is Agent99 in that I had confused the fan operation with the ac operation. They are separate entities when it comes to a cabin comfort strategy.
... The snowflake button turns the AC on or off (whether or not the fan is turning)
... The -/+ button sets the fan speed (whether or not the AC is running)
I guess that leaves open the question of what happens if I do one but not the other. That is, if I turn on the fan without the AC obviously it just blows ambient air but if I turn on the AC without the fan ... what happens?
Old 05-20-2005, 03:52 AM
rost12's Avatar
round -n- shiney
Mein Auto: m5, 911
When the fan is off, everything HVVAC related is off.
Old 05-20-2005, 05:08 AM
toastednuts toastednuts is offline
Mein Auto: BMW 528i E39
If you leave the a/c on and put the system in 'auto' mode with the temp set to 18.0 I find it keeps the car cool and comfy. Only time I need to press a button is if the window mists up, and the a/c is a definate bonus for clearing the windscreen.
Old 05-20-2005, 08:56 AM
Ågent99's Avatar
Moderator, 5-Series
Yes, the A/C button will cool and DRY the air so it works great for clearing up fogging windows.
2001 530i/5 (E39), Topaz Blue/Stone Green/Black (sold) *very rare interior/exterior color combo*
2005 545i/SMG (E60), ED Order, Titanium Grey/Grey (lease over)
2014 335i/8-spd, Mineral Grey/Black (lease take over)
Similar Threads
Air Conditioner Odor Radfahrer Do-It-Yourself H.Q. 7 10-31-2008 03:41 AM
air conditioner condensation sarastro 3 Series & 4 Series 1 06-19-2003 02:20 PM
ESIS (modified stock air box) mini update 31st330i 3 Series & 4 Series 6 05-16-2002 11:55 AM
