winkfp MSV70 ZB switching branch update advices - Bimmerfest - BMW Forums
Old 06-19-2017, 05:31 AM
yeukfung yeukfung is offline
Mein Auto: BMW 330i 2005
Hi all,
I am newbie here as just bought a E90 330i 2005 N52 and unfortunately the car got MSV70 DME failure
(2AB2 DME Internal RAM ERROR, crank but no start when car is hot, crank and start and runs well when it take a rest over 30 minutes or more and then symptom starts again...)
So I have done so many hardware fixes (crank position sensor, vacuum leak, O2 sensor, voltage drop test etc) before it comes to DME replacement.
Since DME replacement is out of my ability before I dig deeper in this forum, thanks guy this forum is super informative.
One of the local auto-shop has helped me to replace the RMFD DME and do coding afterward as i was told that the old DME is unable to read the data out, so they need to do a coding instead of cloning.
After the DME replacement, car can start no matter hot or code, it's great, however, the gas mileage drops from 10km/L to 8km/L, which is quite a lot i think.
Also I found that the exhaust sound is far louder than before, and I suspect that the exhaust butterfly valve does not close when under 3000rpm, so making it so "noisy"(actually i love the sound), but i understand it ruin my back pressure and making my low-end torque very very bad at the moment, now like a granny's car.
Then I shifted my focus to the DME software loaded in my replaced DME as there is no hardware change during the DME replacement(or i will check if vacuum leak on the exhaust valve solenoid later).
Before my DME got replaced, lucky I have done some scanning via INPA and got the original file(at least the configuration I feel good)
ZB:7568990
and checking the KMM and MSV70.HIS,
in line 394: 7568990,7581300,01,34 <-- which means this file can be upgraded to 7581300 (please correct me if i am wrong)
and inside SP_DATEN_v53.3 the e89/kmmData/kmm_SG.txt i found a row with
+G;1;373097;A;DME_2K0_N52__6Z_MSV70_B30
and contains 7581300, and good that it's indicating N52 B30 engine with probably _2K0_ variant(i guess...)
then i try to read the current zb via INPA after DME replacement, i got:
ZB#: 7581278
Name:	Screen Shot 2017-06-16 at 9.44.23 AM.png
and there is no upgrade path using winkfp to check:
and strange that this ZB is located inside E65/kmmData/ (E65 is for 7-series) folder instead of E89 folder, and it's also for B30 engine probably different variant, while I have no idea how to identify which version i should use if I lose my original INPA scanned result.
so my plan is to flash the DME to a more "suitable" ZB version 7581300 via winkfp with Comfort mode -> Choose ZB myself, and the enter VIN.
and since it's the first time I ever touch with winkfp, and also doing DME branch switching, instead of normally the update DME ZB approach, highly appreciate if someone could give me confident to do this, while i have been researching the net quite a bit time with following procedure:
1) will get a 13.8V 70A battery maintainer for coding use and connect to car before doing any coding/flashing
2) plugin the K+DCAN cable and open winkfp, turn on ignition,
3) import all the files inside e89 folder (sgdata, ecu, data)
4) my winkfp configuration:
5) comfort mode + choose ZUSB and find MSV70 -> 7581300, then the screen will shown
====== the following step is uncertain as I didn't click any afterward.
6) click program and then click OK to do,
7) do a ERROR CODE CLEAR, and then adaptation reset.
so my question is,
- is the above procedure proper enough?
- since I am switching the branch of DME ZB, will that I require to do also CAS+EWS realignment job?
- is that still able to flash back to the old one if the DME is bricked?
Thanks all for the time, and really appreciate if someone can leave me some advices.
I love this car, just don't want to brick it with any of my careless mistakes.
Cheers
Old 06-19-2017, 06:10 AM
Mein Auto: '06 AW 330xi
Originally Posted by yeukfung View Post
so my question is,
Process looks right. You'll need to enter the VIN after selecting your flash #.
I don't believe do but I'd be prepared to just in case.
If the DME is really bricked (ie power loss during flash, cable disconnected during flash, etc) then it's hard to recover. You may be able to do it via NFS but its a slim chance.
Old 06-19-2017, 06:56 AM
Thanks a lot for your comment and notice on VIN#, I will start working on it once my battery maintainer arrives and update any result on this "scary" project :-)
For the CAS+EWS realignment job, just want to double confirm it can be done in INPA, right?
so the situation is, when crank but no start, and reading error code says EWS error with CAS, then go to use INPA to do alignment, am I correct? and any chance that it cannot align correctly?
Thanks in advance.
Old 06-19-2017, 10:15 AM
Thanks in advance.
Yes in INPA. I would also have a copy of ISTA ready to use because your version of INPA may not have the correct scripts to run the alignment job.
Old 06-19-2017, 03:40 PM
Thanks a lot for the direction, I am downloading the ISTA 4.0.x via BT, over 120Gb, which takes some time, while I found that ISTA support many different types of interface,
e.g.
ICOM A2, A3, Next
K+DCAN
ENET
I have no experience on ISTA, i only have K+DCAN cable, is that enough to do the EWS/CAS alignment for my current situation?
Old 06-19-2017, 06:19 PM
e.g.
ICOM A2, A3, Next
K+DCAN
ENET
Yes if you have the proper INPA setup. Your cable will work with ISTA as well but you need an emulator
Old 06-21-2017, 05:17 AM
Thanks for your info, I believe you are referring to this emulator, right?
Name:	Screen Shot 2017-06-21 at 8.13.03 PM.jpg
wondering if there is any limitation/difference on the ICOM emulator than using a physical ICOM device?
dme problem, dme/ews, msv70
