3 Series / 4 Series
The 3 Series / 4 Series Forum. If you would like to see all new posts in all the forums, click here. |
Tire Pressure Advice - Take 245
Ok, I know this is a common subject. I have searched the forum for posts on tire pressure and read everyone's advice. What I've taken is that the only way to know for sure is to experiment and see what you like.
I have a 2002 330ci with Sports Package (Conti Sports tires). 225/45R-17 front and 245/40R-17 rear. I commute 22 miles thru some twisty roads daily to work and about 150miles of highway driving on the weekends. What I wanted to know is more of a safety concern. I have a bad habit of speeding on open areas of the highway, not uncommon to be over 110-120mph. And I like to really push it thru the twisties on the way to work. Any concerns over the tire pressures below that I'm going to experiment with? With high highway speeds what tire pressure is best. Thanks all for the advice. Read about having significantly higher pressures in the front than the back to eliminate understeer and may try that as well after I test the ones below. Going to experiment with: 34f/35r 35f/38r 36f/38r 37 all around
Current: 2012 550I xDrive GT 2010 Volkswagen Golf TDI Gone but not forgotten: 2009 X5 35d 2007 335i European Delivery with Performance Center Re-Delivery * ED May 4, 2007 Link to ED Trip Report / PCD July 5th, 2007 Link to Performance Center Re-Delivery Trip Report 2007 X3 European Delivery with Performance Center Re-Delivery 2002 330ci, 1997 328i, 1990 325i |
The pressures look a bit low.
If you're REALLY pushing hard, your sidewalls will likely roll. Personally, I wouldn't go below 40 up front. 35 in the rears would allow for some rolling and increase oversteer. At the moment, I'm running 44PSI all around simply because it gives the least buick-like ride. It makes the car FEEL better, although it handled better at 42F/37R.
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison 6-speed 2002 BMW M3 Alpinweiß/Black 1999 323i KP/GTS2 Alpinweiß 1990 325is Brilliantrot/Tan 1989 325is S50B30US Alpinweiß/Black 1989 M3 Alpinweiß/Black S50B32 (321hp, ITBs)
Try 44 front and 40 rear, just see how you like it.
There is going to be no perfect PSI, it would change with temp, road camber, your personal likes, ... etc.
How's the tire wear at that 44 psi all around?
Can't really say... I've only been running it for a few weeks. Frankly, I don't really care about tire wear, though.
My next set of tires may very well be S-03s simply for the stiffer sidewalls. ![]() I will say, though, that for long distance highway cruising, 42F/37R is simply awesome on my tires. Almost no wander, smooth, quiet ride... When I'm going almost 500 miles in a day, I DO appreciate that.
Tire Pressure Advice from Tire Rack.com
So I was reading this post by "Eddie" at tire rack which was in the Tire Rack forum over at E46Fanatics. Based on the advice he gives here I readjusted my pressures this morning before I went anywhere.
I started with the recommended pressures per the plate on the door jam. 30psi front 35 rear. I tried it and the "floaty" feeling I was having the past couple of weeks when I was running at 35f and 40r was all but gone. Now the question is how much will the sidewalls roll under hard cornering. Here is Eddie's advice if anyone hasn't read it. Okay gang- seeing some questions on best pressures, here is a quick rundown that is worth a read to make sure you are getting the best handling & ride & most even wear.. read up & go check your tires! Your tires support the weight of your vehicle, right? Well, they don't! It's the air pressure inside them that actually supports the weight. Maintaining sufficient air pressure is required if your tires are to provide all of the handling, traction and durability of which they are capable. However, you can't set tire pressure...and then forget about it! Tire pressure has to be checked periodically to assure that the influences of time, changes in ambient temperatures or that a small tread puncture has caused it to change. The tire pressure recommended in your vehicle's owner's manual or tire information placard is the vehicle's recommended "cold" tire inflation pressure. This means that it should be checked in the morning before you drive more than a few miles, or before rising ambient temperatures or the sun's radiant heat affects it. Since air is a gas, it expands when heated and contracts when cooled. In most parts of North America, this makes fall and early winter months the most critical times to check inflation pressures...days are getting shorter...ambient temperatures are getting colder...and your tires' inflation pressure is going down! The rule of thumb is for every 10° Fahrenheit change in air temperature, your tire's inflation pressure will change by about 1 psi (up with higher temperatures and down with lower). In most parts of North America, the difference between average summer and winter temperatures is about -50° Fahrenheit...which results in a potential "loss" of about 5 psi as winter's temperatures set in. And a 5 psi "loss" is enough to sacrifice handling, traction, and durability! Additionally, the difference between cold nighttime temperatures and hot daytime temperatures in most parts of the country is about 20° Fahrenheit. This means that after setting tire pressures first thing in the morning, the vehicle's tire pressures will be almost 2 psi higher when measured in the afternoon (if the vehicle was parked in the shade). While that is expected, the problem is when you set your vehicle's tire pressures in the heat of the day, their cold pressures will probably be 2 psi low the following morning. And finally, if the vehicle is parked in the sun, the sun's radiant heat will artificially and temporarily increase tire pressures. We put some of these theories to the test at The Tire Rack. First, we mounted two tires on wheels. We let them sit overnight to equalize and stabilize their temperatures and pressures. The following morning we set them both to 35 psi. One tire and wheel was placed in the shade while the other was placed directly in the sun. We then monitored the ambient temperatures, tire temperatures and tire pressures through the day. As the day's temperatures went from 67° to 85° Fahrenheit, the tire that was kept in the shade went from our starting pressure of 35 psi to a high of 36.5 psi. The tire that was placed in the sun and subject to the increase in ambient temperature plus the sun's radiant heat went from our starting pressure of 35 psi to a high of 40 psi. In both cases, if we had set our tire pressures in the afternoon under the conditions of our evaluation, they would have been between 2 and 5 psi low the following morning. Next we evaluated the effects of heat generated by the tire's flexing during use. We tried to eliminate the variable conditions we might encounter on the road by conducting this test using our "competition tire heat cycling service" that rolls the tires under load against the machine's rollers to simulate real world driving. We monitored the changes in tire pressure in 5-minute intervals. The test tires were inflated to 15 psi, 20 psi, 25 psi and 30 psi. Running them all under the same load, the air pressure in all of the tires went up about 1 psi during every 5 minutes of use for the first 20 minutes of operation. Then the air pressures stabilized, typically gaining no more than 1 psi of additional pressure during the next 20 minutes. This means that even a short drive to inflate your tires will result in tires that will probably be "underinflated" by a few psi the following morning. Add all of these together, and you can understand why the conditions in which you set your vehicle's tire pressures are almost as important as the fact that you do set it. It's important to remember that your vehicle's recommended tire pressure is its "cold" tire inflation pressure. It should be checked in the morning before you drive more than a few miles, or rising ambient temperatures or sun's radiant heat affects it. And by the way, if you live in the North and park in an attached or heated garage you will "lose" pressure when you leave its warmth and venture into the real world outside during winter. Add 1 psi "cold" pressure tire pressure to compensate for each 10° Fahrenheit temperature difference between the temperature in the garage and outside
"Now go get your own car, we'll see how you do in a crowd." |
Re: Tire Pressure Advice - Take 245
B. Your front pressure needs to be HIGHER than your rear pressure if you want to offset the understeer inherent in the staggered tire setup. Personally, I'd run 40F 38R or 42F 39R. CD-55's advice might be a bit radical for most. But I've run the pressures I listed here on my daily driver 330i w/SP and on my M3 sedan (same tire sizes as the 330s w/SP). |
I'm very happy with 40psi all the way around... over/understeer seems perfectly balanced that way, with the upgraded UUC sways (full stiff front and back).
Maybe 42/40 with stock sways would yield the same effect.
2011 1M 2008 MCS 2002 325iT |
I think you're getting a lot of advice from track junkies here...
I run 38psi all around for street use on my 18" 225/40/18 tires, and 41-44 psi all around for track use. I find that 38psi gives better comfort and has better wear characteristics, gives ample protection to the larger rims and enough sidewall support for some fairly aggressive driving. If you don't drive at or near the max all the time, you might want to take their advice and back off ~5 psi for best all around comfort and wear.
By the way, when I was at Willow Springs last Friday, I initially set the pressures at 35, figuring they would rise to 39 hot after a session - WRONG! They were at 44 psi after 30 minutes on the track!!! It was, after all, 100 in the shade!!! Soooo, check your pressures after each session. Have you signed up for the Buttonwillow school? Did you convince the missus? Later.
'01 330ci |
Thanks all for the advice. When I went to put air in my tires to try out new pressures they were at the recommended 30f and 35r. I changed them to 35f and 37r. I love the difference this makes for local driving but at very high highway speeds 80+ the car doesnt seem as solid as it did before. Does this make sense?
Also, I would like to experiment with the higher pressures you recommend but dont these exceed the manufacturers recommended tire pressures? My door jam pressure for 2002 330ci sp package states max pressure: light load: 30F/35R heavy load: 35F/42R That is the reason I didnt inflate the front over 35. Are you saying it is ok to inflate over the maximum pressure BMW recommends. Thanks all for your advice.
I've also been through this debate with my own 2001 330CI with SP. The dealer (Center BMW) recommends 36 psi in all four tires. Their "M" specialist says he sets all M3s at that for maximum balance, and even wear. An indepedent BMW speciality garage also told me to set my tires at 36 all around. I have about 6800 miles on my car and have been experimenting with differerent settings as well. For street driving I seem to have settled on 36R, 33-32F cold. Though most of my driving is stop 'n go city stuff, I do occasional canyon carving and some freeway (70-80 MPH) driving. I've found that this setup maintains a comfortable ride, (apparently) good even wear, not much tire noise, and crisp handling.
Edit: I keep the fronts at 44F because it contributes to an overall feel of precision. I drive a WRX very frequently, and it makes the E46 feel like an absolute pig in comparison. I suggest that you try 40F, 35R and see how you like it.37 is the absolute minimum I can go without really rolling the sidewalls, but your driving habits and tire pressures are likely different. I DID go through my first set of tires in under 11K. ![]() The ONLY maximum pressure you need to observe is the one written on the tire's sidewall. BMW's recommendations are guidelines only, and intended to generate lots of understeer which makes the car "easier" to drive. hth
keep in mind that Nick is giving advice based on his xi... wouldn't pressure settings generally be different for a ci?
kurt
Kurt: Yes and they would also vary depending on the tires, too. However, lower pressures up front contribute greatly to the sloppy, imprecise feel of current generation bimmers. (Certainly not the cause. It's really a fundamental design issue, however...)
Nonetheless, my recommendation to try 40F/35R still stands.
Nick: I see.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Tire Pressure Monitoring System | jaspar | M Series | 6 | 05-14-2003 08:05 PM |
| Tire pressure question | Terry Kennedy | General BMW | 16 | 01-19-2003 04:18 PM |
| Tire pressure - Anyone know why the 2003 has different tire pressure then my 2001 | AF | 3 Series / 4 Series | 21 | 11-15-2002 08:32 AM |
| Tire Pressure Gauges - Article by consumer reports. | JSJAMALA | 3 Series / 4 Series | 0 | 07-20-2002 11:24 PM |
| What tire pressure to use? | Nat Brown | 3 Series / 4 Series | 55 | 04-22-2002 08:48 PM |
