E30 (1982 - 1993)
Old 05-20-2005, 08:14 PM
escaped101 escaped101 is offline
-=ESCAPED101=-
Send a message via ICQ to escaped101 Send a message via AIM to escaped101 Send a message via MSN to escaped101 Send a message via Yahoo to escaped101
Mein Auto: 318i
Exclamation 85' 318i has too FAST an Idle. 2500-3000 RPMS!!
Hello, I got this 85' 318i that now has too FAST an Idle. 2500-3000 RPMS, a high, steady idle. It just started doing it last week.
It starts fine, idles OK, but once the car warms up the idle jumps way up!
I checked the linkage, & it has no intake leaks . . . . . just a high, steady idle.
I tried changing the Air Stabilizer off another BMW I have sitting around and still the same. Exactly! Now after I messed with it awhile, it seems it's high no matter what!
The Air Conditioner is turned off
Anyhow, does anyone have any ideas? I seen a post on idles that surge, but nothing on if its a high, steady idle.
Any ideas would be appreciated!!
Dave
Escaped101@yahoo.com
Old 05-20-2005, 08:18 PM
Lanc3r Lanc3r is offline
Banned
Mein Auto:
air/fuel mixture.
Fuel pressure?
oxygen sensor?
Old 06-03-2005, 03:23 PM
SurlySam SurlySam is offline
Mein Auto: People Crazy and 325i
Talking Think inside the box!!! The Glove Box!!!
My second and most beloved Bmw was a 1984 318i (Mach Turtle) . Mach Turtle was hurting some time ago just as yours is now. I remember coming home with the engine revving and people looking at me wondering if I was trying to race them. I did some tracing and found that the bosch system has the air idler in the engine bay, but it is controlled by a little green (sometimes black-approx. 4x3) box next to your ECU on the glove box ceiling. You can limp home by putting a rag in the air line from the MAF sensor to the idler and adjusting the throttle cable to bring the rpms to some decent range. I didnt develop a good method for testing this but unplugging the stabilizer usually ended the revving so I went from there. I think you can find a replacement at bavarianauto or BMP for around $90. I hope this helps and good luck to you.
Samantha
Old 06-03-2005, 08:17 PM
-=ESCAPED101=-
Mein Auto: 318i
Thumbs up THANX! I'm Fixed! THANK YOU VERY MUCH!!!
RE: it is controlled by a little green (sometimes black-approx. 4x3) box next to your ECU on the glove box ceiling.
Yep that fixed the problem!! Thank You Very Much!!!!! It's called the Idle Control Unit I think. . .
WoW! It Worked!
Little Green Box, just like you said!
I got the car a few years back, first BMW I ever had and now I'm a BMW fan. Somehow I like the way it handles.
I'm fixing it up for my son who just got over a Kidney Transplant at Stanford! He just turned 16 and he's a great kid and seems to like to work on cars. (When he's not playing games)
Best Wishes,
Dave
Escaped101@Yahoo.com
Thanx for all the help to everyone!
Old 04-13-2014, 07:20 PM
hem1944 hem1944 is offline
Mein Auto: 85 318i
temporary high idle fix 85 318
get a piece of dowel rod size of inside diameter of idle air valve outlet hose. drill a 3/16 hole through it and insert it into hose and reattach to the idle air valve. you may have to try smaller or larger holes to get idle to 800 rpm.
Similar Threads
318i rough idle at start kioneo 3 Series & 4 Series 5 08-13-2004 08:45 AM
NJ BMWCCA Round 2 Elwood Motorsports, Racing & Track 75 07-06-2004 05:45 AM
