E46 (1999 - 2006)
Old 05-20-2005, 08:57 PM
swchang's Avatar
swchang swchang is offline
Family Man User
Mein Auto: BMW, M-B
15k mile service
At ~10,000 miles, I brought my car in for service on some maintenance issues I had. Without asking me, the dealership to which I went did the annual oil change (or so they say) and then reset the service indicator. Now that I'm almost at 15k miles, I guess I should bring it in so they can do the full oil service, which IIRC, is as follows:
BMW Engine Oil Service
Change oil and oil filter while engine is at operating temperature. We recommend BMW High Performance 5W-30 Synthetic oil, p/n 07 51 0 017 866
Reset service interval indicator.
Replace microfilter.
Check overall thickness of front and rear disc brake pads using special tool. If replacement is necessary: Examine brake disc surfaces. Clean brake pad contact points in calipers. Grease wheel centering hubs. Check thickness of parking brake linings only when replacing rear pads.
Check parking brake actuation. Adjust if necessary.
Note: Do not reset Service Indicator when additional oil changes (between the normal intervals) are requested by the customer.
Does this sound right? Will they give me a hard time because they already reset the SI? Should they do another oil change for me, even though it's been only 5k miles since my last service?
TIA.
2004 BMW 330i 6MT Orient Blue Metallic Sand Leather Black Cube Trim ZHP ZCW
Old 05-20-2005, 09:33 PM
Double Vanos's Avatar
Double Vanos Double Vanos is offline
Former ZHP pilot
Mein Auto: 2011 135i M Sport
They are probably going to tell you that its to early for service. My dealer does that too but only if you have 2-3k miles to service on the odo.
2011 135i M-sport ,6 speed, coral red, HK and ipod.
Old 05-20-2005, 09:38 PM
swchang's Avatar
Family Man User
Mein Auto: BMW, M-B
Well, I'm like 10,000 miles too early for service then, since they reset my indicator... What should I do?
Old 05-20-2005, 09:55 PM
Ace Ace is offline
Mein Auto: '01 325Ci
what did they show on your invoice as the work done? do they show that the oil service was done, and the microfilter replaced? if not take it in, explain what happened and have them perform the remaining items other than the oil change....you could also check the microfilter to see if it's a new one...that may tell you if they did the full service or just an oil change...
Old 05-20-2005, 10:17 PM
swchang's Avatar
Family Man User
Mein Auto: BMW, M-B
Oh, good call. My service invoice says 0000250 BMW engine oil service including 36 WPM 0.06, oil filter insert, oil 5w30 synthetic, wind wash single bot, microfilter, 10333 oil ser, due wp perform oil ser. Doesn't mention checking brake pads, parking brake, etc., though... I wonder if they did that part.
Old 05-20-2005, 10:35 PM
LDV330i LDV330i is offline
Mein Auto: 2014 335i M-Sport EB
My receipts have never listed all the individual checks. Only lists the individual consummables. Only once did I get a signed report from the tech checking off all the individual tests/checking. This is in the 6 years that I have had my BMW's serviced by the same dealer.
Former ZHP pilot
Seems like they performed an oil change only, so they SHOULD do the service.
Old 05-20-2005, 10:37 PM
swchang's Avatar
Family Man User
Mein Auto: BMW, M-B
Hmm, if they checked the brake pads and parking brake and all that, I wonder if they'd have on file whether they were within spec and what the measurements actually were. I'm guessing not if it's not recorded on my invoice.
Old 05-20-2005, 10:40 PM
swchang's Avatar
Family Man User
Mein Auto: BMW, M-B
Isn't an annual oil change just oil and filter, though? I wouldn't think they'd have replaced the microfilter if it weren't the service. And if it were just annual oil change, they should not have reset the SI.
I'm not sure whether I'd prefer them to have done the oil service 5k miles early or to have just done the annual oil change. On the one hand, it gyps me out of another free oil change, but on the other hand, it's possible I can squeeze another maintenance service out of this (well, if they continue to do my 15k services at the year's mark instead of at the 15k mile mark).
Old 05-20-2005, 10:44 PM
Former ZHP pilot
I get my oil changed between services at my cost, but they dont reset the indicator.
Old 05-20-2005, 10:49 PM
swchang's Avatar
Family Man User
Mein Auto: BMW, M-B
Do you have a service invoice handy? If so, would you mind checking to see what they wrote?
I looked at an old one where I requested an oil change that I paid for at 6500 miles. Invoice says:
customer request oil and filter change
change oil and filter
(service lights do not get re-set)
(only for oil service and inspection services)
oil filter insert
oil 5w30 synthetic
Hmm, looks like evidence is mounting that they at least did part of the oil service, if not the full oil service...
Old 05-20-2005, 11:00 PM
You are correct about the difference about an Oil Change and Oil Service. The service includes the microfilter change.
I got my annual Oil Change done a 7,200 miles (SI not reset) and my Oil Service done at 12,500 miles per the SI. I would say you are really probably off (ahead of the game) by about 2,500-3,000 miles. The Inspection II normally happens in the low 50,000 miles. So it looks like you will be able get if free and save some bucks. I looks like I may be borderline to try to slide in under the 50,000 miles mark.
I am surprised that your SI was reset. Your invoice reflects the mileage correctly and if your dealer gets audited by BMWNA they will have some explanation to do.
Old 05-20-2005, 11:06 PM
swchang's Avatar
Family Man User
Mein Auto: BMW, M-B
It does seem strange...
Well, I don't mind losing out on a free oil change here and there if I can get a free Inspection II out of it. Even if I lose out on like 4 oil changes at $75 each = $300, isn't an Inspection II like $1000 or something ridiculous like that?
Similar Threads
VOB BMW of Maryland has the worst service cynicalwry BMW Dealer Ratings and Feedback Forum 68 09-29-2010 02:25 AM
1200 mile service. Is it ready to go? Lori 1M & M2 36 02-28-2004 10:14 PM
to do 60K mile service on '99 328i or not to? and some other maintenance questions neesheeth General BMW Questions 10 02-20-2004 01:02 PM
when should i get my oil changed? ///M3 Wes 1M & M2 13 04-28-2003 10:59 PM
1200 mile service today! Imola Ed 1M & M2 9 05-25-2002 06:46 AM
