The X5 SAV Forum
Old 05-28-2005, 05:01 PM
bmw2805 bmw2805 is offline
Mein Auto: 2001 530i
Bluetooth Pairing problem
Hi All,
I installed the bluetooth kit from advancedautovations today. I do get the message aysing Bluetooth pairing but then nothing happens. I did the following :
1. Press the bleutooth console button for about a second
2. while holding down that button turn ignition to position 1
3. I get the message "Bluetooth Pairing" displayed on my nav screen
4. Then I turn on Bluetooth with" Find me" Option on my Motorola V3 Razor.
But then nothing happens.
It is that my ULF needs to be recoded. Any suggestions.
I own a 2001 X5 4.6is with prod date of 02/02.
Thanks.
JD
Old 05-28-2005, 05:35 PM
UCrewX5's Avatar
UCrewX5 UCrewX5 is offline
Member of the club
Mein Auto: BMW X5
From your description it sounds to me like the vehicle BT is working properly. A couple questions/suggestions.
First, where did you mount the BT antenna? That's what talks to the phone, so if it's not mounted properly then you won't get a good signal to do this.
Second, have you tried any other phones? I'd first check to see if I could pair a different phone to help isolate if you possibly may have a phone issue.
Old 05-28-2005, 05:39 PM
Terry Kennedy's Avatar
Terry Kennedy Terry Kennedy is offline
There and back again
Mein Auto: 2003 325xiT, 2006 Atom
On the V3, it is under Settings / Connection / Bluetooth Link / Handsfree / [Look for Devices]. The Find Me (another menu option in Bluetooth Link / Setup) won't do anything. The phone has to initiate pairing with the car via [Look for Devices].
Edit: BTW, all coding does is change the device ID string the car sends from "ULF serial-number" to "BMW vin-number".
Old 05-28-2005, 06:04 PM
Exclamation Connects and then disconnects immediately
Theank you Teryy for the instruction. It did the "Look For devices" on my phone, It found "BMW ULF" ans asked me for teh passcode. Which I entered. Then it connects and then immediately disconnects. I tried it several times but still the same probelm - Connecta and in less than a second it disconnects.
Please advice.
Old 05-28-2005, 06:16 PM
Try turning off the car (all the way to key-out), wait 10 seconds or so, and re-start the car. Does the problem still happen?
If so, post your phone's firmware version and flex version (found in Settings / Phone Status / Other Information), as well as your carrier (for reference, I'm using a Cingular-branded RAZR w/ R374_G_0E.40.57R_A1 / GSMV3xxCIN02NA088 / Cingular as well as an OEM Black RAZR w/ R374_G_0E.40.9DR / GSMV3xxT674TA09E / various with no problems on a 387 ULF.
Old 05-28-2005, 08:53 PM
V3 Razor software version
I have an OEM Black Razor Cingular RAZR
Flex Version : SE607AXXT1088
S/W Version : R374_G_0E.40.79R
DSP S/W Version : 62222200
My wife's V3 Razor with AT&T details (Same problem)
Flex Version : GSMV3xxCIN01NA04E
S/W Version : R374_G_0E.40.57R
DSP S/W Version : 62212100
Thanks for the help.
Old 05-28-2005, 09:03 PM
Um, that second one is the Cingular one. Anyway, I had the same software revision on my Cingular RAZR before I upgraded the firmware and it worked fine (and still does, after upgrading to the latest Cingular firmware / flex).
Did you try shutting off the car, waiting, and then seeing if the phone stopped the connect / disconnect cycle?
Old 05-28-2005, 09:07 PM
Yes I actullay tried to connect a few minutes ago and still the same problem. The last I tried was about 2 hours ago and the car was not driven, I would suppose the blutooth system should ave recycled.
Similar Threads
Confirmation Of Bluetooth Availability For My05 SARAFIL General BMW Questions 78 08-20-2006 09:11 AM
Bluetooth pairing difficulty captana 7 Series & 8 Series 0 04-21-2005 06:46 AM
Bluetooth Retrofit - Audio Problem doubledge E39 (1997 - 2003) 10 04-15-2005 03:24 PM
Pairing a BlueTooth phone with a laptop JetBlack330i Off-Topic 2 10-06-2004 06:41 PM
Installed Bluetooth phone ....finally!(long) 03BMW330 Car Navigation, Audio & Electronics by BAVSOUND 15 05-30-2003 10:26 AM
