E30 (1982 - 1993)
Old 06-01-2005, 09:11 AM
ajmcauley ajmcauley is offline
Mein Auto: 1987 325is 1999 540i
E30 hood lever problem...
Hello, I have an 87' 325is and found that the hood release lever was broken. the lever and wire inside the car seem to be fine, so the problem is on the other end. Does anyone know how to open the hood manually? Any help would be much appreciated...
A
Old 06-01-2005, 09:28 AM
Chris325i Chris325i is offline
Mein Auto: 325i/325i/325/323ic
There should be a hole in the front grille right by the driver's side headlight; poke a screwdriver in there to release the hood.
Old 06-01-2005, 09:50 AM
I have looked at the area that you are talking about and have found 3 such holes. two on the upper part of the grille and one towards the lower part( all on the drivers side). i have poked in all three with now success. can you identify which one of the three you are talking about. as with all older cars, i dont want to force anything. thanks again for your help...
A
Old 06-01-2005, 10:35 AM
Mission accomplished...
Old 06-01-2005, 10:50 AM
Lanc3r Lanc3r is offline
Banned
Mein Auto:
Cool.
Old 02-20-2007, 06:24 PM
325i1990guy 325i1990guy is offline
Mein Auto: 1990 325i
Does this apply to 1990 325i?
Hi, I have the same problem with my 1990 325i... the hood won't open, the lever from inside is pulling the wire but the hood won't budge... if this manual release applies to my model car, can you please tell me where exactly the opening is where I need to jam the screwdriver? don't want to poke a whole in the rad
Thanks.
Old 07-05-2008, 02:20 PM
bslacker bslacker is offline
Mein Auto: 86 325e
Smile thank you
thank you so much, your a (car) life saver.
Oh and i took a pic incase anyone needs to know the exact location
Old 11-02-2008, 09:36 AM
Kelly325I Kelly325I is offline
Mein Auto: bmw 325i
Great!!!! But...
Hey I just bought a 325I so am new to this and obviously need help. Hood was stuck and was able to insert screwdriver (thanks millions!!!!) but what can I do to prevent this from happening again?
Kelly325i
Old 11-02-2008, 04:36 PM
omw41's Avatar
omw41 omw41 is offline
Mein Auto: 1986 BMW 325 E
Kelly325i
Here is what happened in my car. The cable was not busted or anything. The handle under the dash was loose. Not so loose that you would see it hanging, but loose. There are only two bolts that hold it in, and over time, they loosen so there is so much play, the lever really does not do anything. So, maybe stick your head up under there and check it out. It worked for me.
Old 01-06-2010, 04:04 AM
kitchenmama kitchenmama is offline
Mein Auto: 1994 318i tourer
does this apply to bonnets that open from the window screen end too ?
Old 01-06-2010, 02:50 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
yes they all do on E30s. that pops the hood up and out like when you pull the lever under the dash
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
Old 10-21-2011, 10:00 AM
krzton krzton is offline
Mein Auto: 1988 BMW 325
Thanks God for these forums
Old 05-08-2015, 04:57 PM
Grampa Snail Grampa Snail is offline
Mein Auto: BMW 325
Thanks so much for the pic and info. It saved me a lot of time and $.
Old 05-11-2015, 06:18 AM
BMWFatherFigure's Avatar
Old School
Once it is open LUBRICATE EVERYTHING!! Don't forget the little wheels on the outer edges at the windscreen end!!
Current:
E38 Parts Car
Previous:
Old 06-24-2015, 12:44 PM
Darkboomer94 Darkboomer94 is offline
Mein Auto: e30 3.20i
Okay bonnet guys please help me out. I have a 3.20i 1987. The bonnet giving me he'll. I worked on the car and when I disconnected my battery the bonnet did not want to close. I even replaced the lock and bonnet rack and still did not want to closed. Took out all the rubbers and still same problem. I. Realy do not know what to do
Old 06-26-2015, 04:38 PM
Old School
Take the battery cable out of the bonnet (hood) track.
Current:
E38 Parts Car
Previous:
Old 06-26-2015, 09:38 PM
Going to do so to day
Similar Threads
opening hood problem 97 740iL kto 7 Series & 8 Series 5 03-13-2006 12:13 PM
The forgotten Hero... E30 M3 Fifty_Cent 1M & M2 10 11-09-2005 08:32 AM
E30 Parts + Trailer: M3 & 325: GC Camber, Seats, M3 brake parts, M3 valve cover victorhall Classifieds 0 12-22-2004 07:31 AM
So I drove an E30 M3 tonight... Jetfire 1M & M2 47 03-27-2003 06:18 PM
