Bimmertools and Eurosport Design present: Peake Tool School
by tim330i on May 19, 2009, 5:41 pm
Welcome to Peake Tool School, where our goal is to familiarize you with the basic functions of your car's diagnostic systems, and with what we believe is the best scan tool for most BMW owners.
The Basics:
A "Peake Tool" is the common name for a scan tool made by Peake Research Corporation. Peake Tools are hand-held, Non-OBDII, BMW-Specific (this is explained below) code readers. They are affordable, accurate, and extremely easy to use. Peake Tools read the same diagnostic codes that the dealership and technicians rely on. The tools are available in versions for engine and airbag codes, and work on BMWs and Minis only.
Peake Research Corp. designates these tools as "R5 Tools", as all their scan tool model names begin with R5:
R5-FCX3 reads BMW engine codes
R5-SRS reads BMW airbag codes
R5-EMX reads Mini engine codes
Peake Research has been a trusted manufacturer of BMW-specific scan tools for the do-it-yourselfer for twenty years.
Why a Peake Tool is a great choice for BMW owners:
Very simply, when your BMW detects a problem, it warns you with a "Check Engine" or "Service Engine Soon" light. You can determine what the problem is by plugging in a scan tool and reading the trouble codes your car is reporting.
For any given problem, your BMW generates two different types of fault codes. One type was programmed by BMW to specifically coordinate with your particular car. The other type is a "generic" version of the code that is vague enough to apply to any vehicle built after 1996. This generic code, called OBDII, is intended to allow state inspection facilities to monitor emissions-related problems present on any type of car they are certifying. The BMW-Specific code is what dealers and technicians use for actual diagnosis.
Scan tools from Peake Research read the BMW-Specific codes, not the generic OBDII codes, giving you the ability to see the same trouble codes the dealer relies on for diagnosis. Generic codes and code readers can yield less accurate and potentially misleading information. Additionally, many BMW Specific codes are simply not represented at all by the generic language. Therefore, basing your diagnostic decisions on the factory-programmed codes is the best option for BMW owners.
It is important not to confuse these factory-programmed codes with the 'manufacturer specific' OBDII codes that generic tools read. Many generic tools claim to read 'manufacturer specific' codes, which are simply an extended range of codes that are beyond the basic set used for inspection. These are completely different than the BMW factory codes as described above.
How a Peak Tool is used:
Peake Tools are extremely easy to operate and require no special training or understanding of auto mechanics. The tool is 100% self-contained in a very small cylinder. There are no external interfaces, computers, or additional software. You simply plug the tool into the appropriate port (one of two possible locations that vary by model year), turn the car's key to the 'on' position, and begin your scan or reset. There are only two buttons on the tool – one to select the function (labeled 'Select'), one to operate within that function (labeled 'Go'). The instructions are so basic that they are printed directly on the tool.
The included instruction manual contains a number of 'code tables' that correspond to specific vehicles. When you use the Peake Tool, it begins by reporting to you which table corresponds to your car. It will then give you any current, historical, or 'pending' codes the car is storing or reporting. Open the manual, find your table, and then find your codes. You can then erase the codes, thereby resetting the warning light.
Peake Tool FAQ:
Simple Yes or No answers – Do Peake Tools:
  • Read OBDII codes: No
  • Read factory-programmed, BMW Specific codes: Yes
  • Read the same codes the dealer sees: Yes
  • Reset oil service and inspection reminders: Yes
  • Include everything you need to read and reset codes: Yes
  • Include a code manual with definitions: Yes
  • Include instructions detailing how to repair a problem: No
  • Come with a 90 day warranty: Yes
  • Work with non-BMWs: No
  • Provide vague, generic fault codes: No
  • Fit in your glove box: Yes
  • Program or otherwise provide 2-way communication with your car: No
  • Come from a company with twenty years of trusted service: Yes
  • Have the honor of being featured in Bentley manuals: Yes
  • Connect to my laptop: No
  • Sometimes require research to determine how to properly repair my car: Yes
  • Instantly tell me what part to replace: No
  • Give the most accurate clues to start repairs with: Yes
  • Cost about what you'd pay a dealer to run one diagnostic test: Yes
  • Work better for BMWs than a generic tool: Yes
  • Work with Non-U.S. spec BMWs: Yes
  • Work with Diesel BMWs: Yes
  • Work with Mins: Yes
  • Reset other lights such as Transmission, DSC and ABS: No
  • Read fault codes from systems other than the ECU and Airbag: No
  • Require software, interface boxes, boot-up, or networking: No
  • Just plug in and read codes without any hassles: Yes
Where to go for more information or to order:
This article was brought to you by the very helpful folks at Bimmertools and Eurosport Design. Both companies have extensive experience with these products, and keep a complete selection in stock. Their pricing is set well below MSRP, and both companies offer FREE Shipping (domestically) for Peake Tool orders. Do not hesitate to contact either of them with questions or to order your own Peake Tool.
BimmerTools
Website: www.bimmertools.com
Email: info@bimmertools.com
Eurosport Design
Website: http://www.eurosportdesign.com
Email: info@eurosportdesign.com
Class dismissed!
5 responses to Bimmertools and Eurosport Design present: Peake Tool School
basar13 said:
July 22, 2009, 8:44 am
will it work on 2005 z4 m roadster and also what if there is more than one engine fault can we see more than one fault ?
i had deleted my cats there is engine light on... i want to see if there is an other problem without going to service time to time
ken@bimmertools said:
July 22, 2009, 8:50 am
Yes and yes. It is compatible with your Z4 and will read as many codes as the diagnostic system is storing.
Ken
basar13 said:
September 2, 2009, 6:54 am
i received the good its very good....
Thanks Ken,
September 2, 2009, 8:07 am
Thanks, Basar - I appreciate the order and support.
Ken
e39 m5 said:
October 23, 2009, 11:03 am
The Peake Code reader is okay...but there are easier tools to use out there that don't require the use of tables to figure out what's going on. For example the Mac Tools ET-50 Reader is good and for those with the iPhone - there's a really cool App by Rev Technologies that combines with a wireless OBD II dongle from PLX.
Popular Photos
more
