The BMW M3 GTS
by Tim Jones on November 5, 2009, 10:35 am
BMW M3 GTS - a lightweight E92 M3 race car
BMW M GmbH now offers a truly outstanding performer based on the BMW M3 Coupe also ideal for Clubsport events - exactly the right car for the truly discerning customer demanding the very utmost in terms of power and performance. The BMW M3 GTS is largely hand-built by the most skilled craftsmen at BMW M GmbH as a perfectly harmonized package of outstanding modifications, with production exclusively to the customer's personal order. Focused on motorsport, the modifications comprise both the drivetrain, the suspension and the body of the car, as well as its interior. Market launch of the
BMW M3 GTS will be available spring 2010
Offering this truly exclusive model for the genuine motorsport enthusiast, BMW M GmbH is continuing a great tradition introduced on former generations of the BMW M3. Once again, the outstanding sports potential of the BMW M3 is being consistently enhanced and upgraded to an even higher level, the customer benefiting from the Company's wide range of know-how in the development and production of racing cars. Through its race-oriented modifications enhancing both performance and safety, the BMW M3 GTS is ready to go in Clubsport events on the track and comes with the option for homogenization on the road. So that the driver is able to make his way to the race track in the very same car he will use for racing.
Consistent lightweight technology
Consistent lightweight construction, adjustable aerodynamic units, an increase in engine size and output on the V8 high-speed power unit and suspension technology meeting all the requirements of motorsport – all this gives the BMW M3 GTS a top position among high-performance cars built for Clubsport racing. Unladen weight according to the DIN standard is less than 1,500 kg (3,300 lb), the lightweight body comes with special mounts for six-point seat belts and a roll cage fitted behind the B-pillar.
Through its design and construction, the materials used and its special equipment, the BMW M3 GTS is a lightweight performer all the way, offering a genuine motorsport driving experience in every respect. In addition to the carbon fiber roof already featured as standard on the BMW M3, weight is consistently optimized by features such as silencers made of titanium, the extra-light centre console and door linings, the omission of rear seats, automatic air conditioning and an audio system, as well as sound insulation tailored specifically to this very special model.
V8 high-speed power unit: derived from motorsport, optimized for motorsport
The eight-cylinder power unit of the BMW M3 GTS enlarged in size to 4.4 litres and boosted in output to some 450 hp boasts construction principles and technical details carried over directly from motorsport. A supreme surge of ongoing power throughout a wide range of engine speed characterizes the outstanding performance of the V8 with its high-speed concept. The features typical of a motorsport engine include the crankcase made of a special aluminum-silicon alloy and constructed in bedplate design, individual throttle butterflies, anti-knock sensors with ion flow technology, and, wet sump oil supply optimized for supreme driving dynamics.
Seven-speed M DKG Drivelogic with race-bred gearshift
Power is transmitted in the BMW M3 GTS by the M double-clutch gearbox with Drivelogic also available as an option on the regular production model. This seven-speed M DKG Drivelogic gearbox follows a principle also developed for motorsport, shifting gears without the slightest interruption of engine power. The transmission was developed specifically for a particularly powerful high-speed engine and offers ideal qualities for truly dynamic acceleration at all times. The gearshift characteristics on the seven-speed M DKG Drivelogic have been tailored specifically to the modified power unit of the BMW M3 GTS and the driver is able to shift gears both through the selector lever on the center console and through special M shift paddles on the steering wheel.
High-performance suspension with purpose-built brakes
To convey the supreme power of the engine to the road in equally supreme style even under the most extreme conditions, the BMW M3 GTS comes with suspension technology likewise derived from the highest realms of motorsport. While the suspension is based on the front and rear axle of the BMW M3 Coupé, the rear axle subframe is bolted firmly in position and the suspension features adjustment threads on the dampers for individual variation of the inbound and rebound strokes.
The high-performance brake system of the BMW M3 GTS features fixed calipers with six pistons up front and four pistons on the rear wheels. The race-oriented set-up of DSC Dynamic Stability Control naturally considers the supreme dynamic potential of the BMW M3 GTS. Different-sized tires front and rear running on 19-inch M light-alloy Competition rims in double-spoke design ensure optimum transmission of acceleration and brake forces to the road.
Aerodynamics: optimized components with variable geometry
To optimise the flow of air and adjust the car's down force as required, the BMW M3 GTS comes with a race-oriented front air dam and rear wing. This allows appropriate adjustment of the car's aerodynamic qualities in motorsport and for other purposes, tailored to the specific profile of the respective track. The air guidance units on the front air dam, for example, may be varied in their geometry, just like the position of the rear wing based on the wing already featured on the BMW 320si raced in the WTCC World Touring Car Championship.
Exterior features such as the BMW kidney grille and the gills at the side finished in chrome on the regular BMW M3 come in special dark epoxy-plated chrome on the BMW M3 GTS.
Special interior for supreme performance and safety
The interior of the BMW M3 GTS clearly reflects the focus on supreme performance and safety on the race track. The interior features include classic bucket seats, interior trim in carbon and an M steering wheel finished in alcantara. The door and side panels at the rear also come in alcantara, while six-point seat belts delivered with the car for subsequent use, a fire extinguisher and preparation for an emergency-off switch in motorsport round off the wide range of special features inside the car.
*Information only; This model is not currently planned for the North American market
Video -
Pictures -
Leave a Comment
29 responses to The BMW M3 GTS
Ryan... commented:
November 5, 2009, 12:08 pm
OMFG, I want that soooooo bad
gmlav8r commented:
November 5, 2009, 10:12 pm
Sweet
thebmw commented:
November 5, 2009, 11:55 pm
They failed to mention the estimated price: $150,000!!!
mfumbesi commented:
November 6, 2009, 2:43 am
I came, I saw, I drooled.
MikeCoupe commented:
November 6, 2009, 3:31 am
Going after the GT3, are we??
gmlav8r commented:
November 6, 2009, 11:51 am
thebmw commented:
November 6, 2009, 12:53 pm
Originally Posted by gmlav8r View Post
For that price, there are a lot of other cars I'd want to have other than a souped up, skinnied down 3 series (no offense to BMW fanboys).
Double-S commented:
November 6, 2009, 5:51 pm
+1
It's nice but not 150k nice.
BIMMERUSAM5 commented:
November 6, 2009, 6:14 pm
Originally Posted by Double-S View Post
+1
Agreed. I can buy a nice p-car with that mula.
Double-S commented:
November 6, 2009, 6:19 pm
Exactamundo.
thebmw commented:
November 6, 2009, 6:25 pm
Actually, you can skinny down a 335 or M3 quite easily and strip it of all non essentials (dashboard, seats, etc). Then, just spend a small amount on mods for suspension, different seats, engine, exhaust, carbonfiber this and that, etc and you'd save yourself a quite of $$ and I'd imagine performance would be stellar.
smudgeman commented:
November 8, 2009, 1:07 am
Oh my god... I can't even tell you how happy this made me. BMW has been needing to make a barebones Race car for EVER!!!! And now they have. Thank god. Back to focus on the driving
thebmw commented:
November 8, 2009, 1:18 am
Sure...back to the basics for $150K!
thebmw commented:
November 8, 2009, 1:22 am
http://jalopnik.com/5397062/bmw-m3-g...ore-m/gallery/
"The new BMW M3 GTS, which many expected to be called the CSL, debuted today with a new name and a new look. With power expected to be close to 500 HP, a fire extinguisher is included.
We're still expecting the limited edition BMW M3 GTS to come in at around $150K. For all those greenbacks M buyers will get a more extreme, track-ready M3 sans stereo and A/C with a new body kit and power boosted to 470 HP. More details as we get them."
November 8, 2009, 1:39 am
thats why you wait for it to be used later
thebmw commented:
November 8, 2009, 1:40 am
I think this car will sell and be limited in production #'s. Hence, the depreciation will be limited. So you might pick it up many years from now for $100K!
bmwadam commented:
November 9, 2009, 1:04 pm
This looks like it would be one heck of a club car, is it is designed to be. Racing is not cheap by any means. I heard it said once that when you race, only run in the class that you can afford to be competitive in. I
That being said it really depends on the depth of your pockets, and what type of envents you want to run it. BMW track cars are generally reliable as far as track cars are concerned, and 150k is not bad for what is for all intents and purposes a street legal race car. But it will be interesting to see how well they hold up at club events. It is still too early to tell. You have to also think in terms of maintenance. BMW's as race cars are not that costly to keep going when compared with others.
I'm glad they put this together. It was needed! As for deprication, if you run the heck out of it, it will depreciate. If you make it a garage queen, I do not suspect it will. Limited production BMW's tend to hold there value well. Look at the M1, Z1, 850csi, Z8 etc.
thebmw commented:
November 9, 2009, 2:40 pm
The M1, Z8, etc were not 3 series. Garage Queens don't depreciate like beaten down track cars, not matter what car it is (obviously). I still think that since it is a souped up, skinnied down 3 series, it will depreciate slower than a traditional 3 series/M3, but faster than some here may think.
finally330i commented:
November 12, 2009, 12:46 am
Why do you think this isnt as nice as a P-car? Didnt the Rahal Letterman M3 win the ALMS race at Road America, the largest track in North America.
2001 BMW 300ci commented:
November 18, 2009, 2:02 pm
I wish i had a spare $100k
thebmw commented:
November 18, 2009, 2:35 pm
Even if you did, you'd still be short $50,000!!
BMW_GAL commented:
November 18, 2009, 5:39 pm
Gorgeous color
tim330i commented:
November 20, 2009, 4:31 pm
Rossi samples BMW M3 GTS
Valentino Rossi gave the lightweight BMW M3 GTS its public debut in Valencia last weekend.
The nine-time Moto GP world champion took to the track after winning BMW's 'M Award' for being the fastest qualifier on average during the season.
The lightweight M3 GTS coupe, due to go on sale in the UK in early 2010 for 115,000 euro (£102,000), has been conceived as a limited edition model primarily for club based racing in much the same way Porsche produces the 911 GT3 Clubsport.
"It was amazing in the GTS. Just amazing. It was great, especially under braking with the light weight that it has," said Rossi, who is reported to have enquired about ordering one of the cars following his run.
As part of his prize for being the fastest driver in qualifying Rossi also won a standard M3 saloon - the fifth car he has received for scooping the award.
However, the Italian whas vowed to push for more records. He said: "Stoner has won more BMWs than me so maybe I have a target still next year!"
Pictures -
CR67 commented:
December 21, 2009, 9:57 pm
Sweet ride!!! The only thing I don't like is the way they "riced" it out with that ridiculous wing on the back! ugh!
dalekressin commented:
December 21, 2009, 10:08 pm
I like it M3gts.
but, ... it's M3 for me.
Shannon325i commented:
January 5, 2010, 3:17 pm
I could really use a car like this!!
Corey Milne commented:
January 6, 2010, 4:16 pm
Just like how all of those ALMS cars are all riced out with their wings eh..
QuoteWarz Insurance commented:
January 18, 2010, 6:49 pm
Great pictures. I love the orange color and CF accents.
Billd104 commented:
May 16, 2010, 3:05 pm
http://www.youtube.com/watch?v=DR_noVwr-58
