The new second generation BMW X3 builds on the success of the original by developing its core competencies while adding new technology to establish new benchmarks for agility, efficiency and comfort. The new BMW X3 will be produced in an expansion of the BMW Spartanburg, South Carolina plant and is expected to arrive in US BMW Centers by the end of 2010.
Design: Exterior
The profile of the new BMW X3 is also characterized by a unique interpretation of typical BMW X design features. Powerfully flared wheel arches and the short front and rear overhangs emphasize the robust character of a BMW Sports Activity Vehicle. The dynamic appearance of the silhouette is accentuated by three characteristic lines. The new BMW X3's brand-typical upper contour line at door handle level rises steeply at first within the front wheel arch area, then flows gently to the rear. Two additional subtle lines follow this contour line above the wheel arches.
The rear is characterized by horizontal lines, underlining the new BMW X3's robust character. Precise lines and expressively modeled surfaces create attractive light and shadow effects. The taillights, which are located far to the outside, have a distinctive T-shape that is characteristic of the BMW X3. LED light bars create a distinctive BMW night-time design signature.
Dimensionally, compared to its predecessor the new X3 is a half-inch (12mm) taller, 3.36-inches (83mm) longer, 1.1-inches (28mm) wider, and features a half-inch (12mm) more ground clearance. It rides on a wheelbase which is 0.6-inches (15mm) longer, at 110.6 inches (2810mm).
Interior: First-class ambience, intelligent functionality
The raised seating position facilitates egress and ingress, while providing outstanding outward visibility. The three rear seats offer outstanding comfort for travelling long distances and significantly more leg and elbow room than its predecessor. With EU-measured cargo volume between 19 and 56.6 cu.ft. (550 and 1,600 liters), the luggage compartment of the new BMW X3 is the largest in its segment. At the same time, the versatility with which available space can be adapted to suit each personal requirement is also unrivalled. The rear seat backrests can be split at a ratio 60 : 40 and can be folded down either individually or together. The optional rear seats with ski pass-through has three segments of 40 : 20 : 40 can be folded down individually or in combination making it possible to adapt the luggage compartment in varying degrees according to need.
The X3 xDrive28i: 6-cylinder power for the entry model
For the US, the entry-level X3 xDrive28i will feature BMW's award-winning magnesium/aluminum 3.0-liter inline-6. In 2006 and 2007, the "N52" was awarded the distinction of being one of Wards 10 Best Engines of the Year. Its magnesium/aluminum construction, Valvetronic variable valve lift and Double-VANOS are features found only on BMW engines, and it is currently the lightest six cylinder engine for its size class in the world. The N52 in the X3 is rated at 240 horsepower at 6,600 rpm and 230 lb-ft of torque between 2,600 and 3,000 rpm.
That's good enough to accelerate from 0 -60 mph in 6.7 seconds (preliminary). That's nearly a half-second quicker than the previous X3 xDrive30i equipped with an automatic transmission.
The X3 xDrive35i: Class leading performance and efficiency
This engine enables the X3 xDrive35i to sprint from 0 to 60mph in just 5.5 seconds (preliminary). Top speed is electronically limited to 150mph when fitted with the optional Sport Package.
Both the BMW X3 xDrive28i and the X3 xDrive35i will offer not only the most dynamic driving characteristics in their categories, but also by far the most favorable fuel consumption and emission levels within their class. EPA fuel efficiency estimates will be provided closer to the on-sale date in the United States.
Playing a supporting role: The innovative new 8-speed automatic transmission
Like many new BMW models, the new X3 features an 8-speed automatic transmission which brings smooth shifting, sportiness and efficiency to new levels of perfection. Compared to the exemplary 6-speed automatic offered previously, the 8-speed has "taller" cruising gears that make a significant contribution to reduced fuel consumption and emissions, as well as quietness. Its wider spread of ratios from lowest to highest gear enhances acceleration and response across the range of driving speeds. The revolutionary design even allows for direct shifts from 8th gear to 2nd gear for maximum acceleration.
This new automatic's attributes have been achieved via an innovative concept that provides the two additional ratios (7 and 8) with no increase in bulk or weight. In a ground-breaking arrangement, four planetary gearsets and five clutch packs are controlled in a way that no more than two of the five clutch packs are freewheeling at any given time. The modest increase in the number of mechanical elements allows the new transmission to achieve unusually high efficiency. The so-called "gearing efficiency" is higher than 98% in all eight gears. . In 6th, gearing efficiency is at its optimum because that is a direct drive. Combine this with reduced friction and the ability to keep the torque converter "locked up" more of the total driving time, and the transmission becomes very much a part of the overall BMW EfficientDynamics concept.
Two additional gears mean threefold progress: quicker shifts, greater smoothness, enhanced efficiency
The wider spread of ratios allows the engine to run at lower speeds, often in the "tallest" gear, 8th. Yet even with this wider spread, the steps between adjacent gears are reduced; in turn this means a stronger, smoother flow of power during acceleration.
Faster shifts are a further benefit because only one clutch pack is disengaged to shift up or down by one or two gears. On the other hand, downshifting more than two gears is accomplished as a direct shift. For example, a downshift from 8th to 2nd gear is made with only one clutch pack disengagement, and thus occurs without stepping down through the intermediate gears. So, at one instant the driver can be enjoying the quiet, fuel-efficient low rpm of 8th gear, and in the next instant getting maximum acceleration.
New suspension, xDrive intelligent all-wheel drive, and made-to-measure dynamics
BMW xDrive is unique in design and construction. In normal conditions, driving torque is always transmitted to the rear wheels, and most of the time to all four wheels. Normal torque split is 40% front/60% rear. The portion of torque transmitted to the front wheels is controlled by a multi-disc clutch that can be fully open (100% to the rear), fully engaged or at any level of partial engagement in between. The torque split between rear and front wheels is thus steplessly variable. Engagement pressure on the multi-disc clutch is directed by an electronic control system in response to actual road and driving conditions. This gives xDrive a dynamic ability that is unparalleled by other all-wheel drive systems.
The new BMW X3 also features completely redeveloped suspension technology. The combination of a double-joint spring-strut suspension at the front and a multi-link rear suspension provides the foundation for agility and driving comfort. The standard Servotronic speed-sensitive power steering contributes to the X3's precise handling.
Adjacent to the E-Shift lever on the X3's center console is the optional Driving Dynamics Control selector (included with EDC). DDC provides three settings that tailor vehicle characteristics to different drivers, one driver's different moods, driving conditions or all of the above. The settings are Normal, Sport and Sport Plus; the following vehicle-dynamics parameters are affected:
* Shock-absorber firmness (within the Electronic Damping Control system)
* Engine throttle response
* Transmission shift characteristics
* Power-steering assist level
* Dynamic Stability Control mode
The X3's driving dynamics can be widely controlled by these different calibrations of so many elements. In addition, when equipped with the Navigation system, the driver may use iDrive to custom-tailor the Sport setting.
Just ahead of the Driving Dynamics Control switch is the Dynamic Stability Control switch for BMW's all-encompassing stability- and traction-control system. A brief push on this button switches the system to Dynamic Traction Control, in which DSC's intervention threshold is raised; one effect of this setting is improved traction in deep snow. A long push on the same button de-activates DSC altogether, though the anti-lock braking and anti-rollover functions always remain active.
An extensive range of standard and optional BMW ConnectedDrive functions
Production at the BMW Spartanburg plant
The new BMW X3 is produced at the BMW Spartanburg, South Carolina plant.. With the production of the BMW X5 and BMW X6 models, the location, has become the competence center for BMW X models within the BMW Group's worldwide production network. Thanks to a comprehensive $750 million expansion, BMW Plant Spartanburg is ready to produce the new X3 for distribution around the world.
Agility and comfort, sportiness and efficiency, ruggedness and elegance, flexibility and premium ambience the new BMW X3 fulfils the varying demands made on a modern Sports Activity Vehicle. With its multifaceted qualities it sets new standards in the segment established by its predecessor. The all-new X3 is due to arrive in US showrooms by the end of 2010
Update - M Sports Package Details Now Available
Dynamic and compelling, the M Sports package drives the sporty nature of the BMW X3 to even greater heights. The rich Carbon Black metallic paint finish and powerful 19-inch M light-weight alloy wheel rims set the tone, while the sports suspension tuning delivers the experience.
More
Driving tools: the M multifunction leather steering wheel and variable sports steering. The M gear selection lever boasts particularly short throws. In the BMW xDrive35i with standard eight-speed automatic transmission Steptronic, the M leather steering wheel also features gearshift paddles. The sporty suspension settings give you stiffer dampers and deliver precise feedback.
Ergonomically shaped sports seats provide side support against strong lateral forces, such as when cornering at speed. The Pearlpoint cloth-leather upholstery offers a beautifully tactile surface; matching the BMW Individual roof liner, it comes in sleek Anthracite.
With the M Sports package, the side skirts, wheel arches and front and rear aprons are in body colour for example, the Carbon Black metallic paint finish that is exclusive to the M Sports package. Window surrounds and roof rails are in the high-gloss BMW Individual Shadow Line.
Available from the second quarter of 2011 (subject to change)
Follow our full F25 X3 coverage at http://www.bimmerfest.com/tag/F25
Recent BMW News
Latest Forum Discussions
July 14, 2010, 6:32 pm
Wow, sounds nice!
Hopefully people like the 8 speed over the "exemplary 6-speed automatic "!
July 14, 2010, 6:33 pm
I'll have more pictures up in a minute, I'm really impressed with the look of the F25 X3. Much improved over the out going E83 in my mind.
Tim
July 14, 2010, 6:54 pm
More pictures are up, what do you think?
July 14, 2010, 7:05 pm
July 14, 2010, 7:11 pm
It's an SUV so I'd never even consider buying it, but...much better looking than the first generation model.
I suppose that between this and the F10, we can start to get an idea of what the next 3er will look like.
July 14, 2010, 10:28 pm
I want one. I'll prpbably wait a year though.
Thanks for posting the pics and article Tim!
July 14, 2010, 10:45 pm
No mentioning of diesel engine. That's a let down. Would love to drive one here.
July 14, 2010, 11:03 pm
Damn...... I would definitely consider this above Audi Q5 for my next vehicle...
but then Audi Q5 will be in its second generation by then.
July 14, 2010, 11:15 pm
http://strada.posterous.com/2011-bmw-x3
Still not sure about the rear view under the bumper/valance.
Looks a bit like the transverse muffler the prototype exhibited,
but I hope it's not and that there is some sort of spare wheel under there.
July 15, 2010, 12:11 am
Don't know this for a fact - but would place a hefty bet on it.
July 15, 2010, 12:20 am
Added a video overview of the New BMW X3! Its a quick way to get all the highlights of what the new X3 offers.
http://www.youtube.com/watch?v=d5dwt1g7ZxM
July 15, 2010, 12:21 am
July 15, 2010, 12:32 am
The press release talks about a standard 8-speed automatic, which implies no manual for the US market. Bummer, because it's the 6-spd manual in my 2006 X3 3.0i that sold me on it. Without a manual, there's very little to distinguish this from a Q5. It's just another overweight station wagon with a high center of gravity. When my X3 eventually goes, I don't think I'll get another SUV. I only use it to get to hard-to-reach trailheads in the Cascades a few half dozen times a year anyway.
-James
Seattle, WA
2006 X3 3.0i (manual, sport, premium, xenons, PDC, prem stereo)
2006 Mini CooperS convertible (manual, sport, premium, xenons, HK stereo)
July 15, 2010, 12:33 am
In the photo below, note that the speedometer is only in kilometers. This is not a US-spec car.
July 15, 2010, 12:42 am
Doh!
July 15, 2010, 12:52 am
July 15, 2010, 2:15 am
The good - DPC, aka torque vectoring is available, as in Acura's SH-AWD. So far only X6 got this.
The bad - Car and Driver reported that only the 8-sp auto stays in the U.S.
Design is much improved. Interior is Audi - like. Exterior - rear and side look great, front is pretty generic BMW look.
July 15, 2010, 2:30 am
July 15, 2010, 8:42 am
every CUV nowsaday looks the same
BMW, Infinity, Audi, CRV, RAV4, etc. they all look the same style ??
July 15, 2010, 10:07 am
July 15, 2010, 10:32 am
BMW has released the M-sports package details!
Check it out - http://www.bimmerfest.com/forums/sho...d.php?t=469178
July 15, 2010, 10:36 am
BMW DE does have the website updated for technical data and specifications.
The 6-speed manual is standard on the xDrive20d with the 8AT as an option. The combined consumption is just 5,6 l/100km (42 US mpg) on that model. I'm impressed that the 6-zylinder petrol will be the first 6-cylinder motor and automatic transmission with Auto Start-stop; should really be great to reduce emissions and consumption while at a standstill.
That said, I'm a bit disappointed by the headlights and taillights on the X3. When I saw the chassis at the factory, I had high hopes because the side of the vehicle looks great with the smooth lines. BMW had it going- the 7er, 5er, and X1 were vehicles that I liked when I saw pictures and specs. The X3 seems a bit bland and I'm not really sure where it fits in the line-up. If the X1 is supposed to be small and agile, and a Range Rover is the "house on wheels", where does the X3 stand? I don't really think this one will be a standout.
July 15, 2010, 11:54 am
A minor version?
July 15, 2010, 12:32 pm
July 15, 2010, 12:49 pm
colors and stuff
July 15, 2010, 2:35 pm
A minor version?
July 15, 2010, 2:38 pm
Looks like they are going to use the same engine as the F10 528 in the X28.
July 15, 2010, 3:38 pm
I actually very much like the new X3. I'll be curious to see one in person though!
July 15, 2010, 4:21 pm
Any word on pricing?
July 15, 2010, 4:30 pm
Pricing for the 2011 X3 won't be released until right before they go on sale. That being said BMW needs to have a winner on its hands with the new X3 and will probably price it accordingly. I would expect a similarly spec'ed F25 to be the same if not a hair cheaper than the outgoing E83. As soon as pricing is available or we have any rumors they'll be posted up and we can see if I'm right or not
Tim
July 15, 2010, 5:20 pm
That interior is so nice... Does this put the X3 ahead of the Q5 and GLK? I think it's very posisble. I don't think it's going to be any cheaper. I'd bet 1-2k more expensive.
July 15, 2010, 9:38 pm
I've attached the options and pricing for the German market. Prices include 19% MwSt.
July 15, 2010, 10:04 pm
So does iDrive come standard now if you don't order navigation?
July 16, 2010, 10:24 pm
I really like the looks the F25!
I would think the pricing would be comparable to the E83, look at the pricing on the 2011 X5 it actually dropped.
July 17, 2010, 2:21 pm
July 17, 2010, 9:06 pm
I have also noticed that the telescopic headrests are absent. In the 2007 they had conventional headrests like this model. In my next 2008 x3 they had the telescopic. Wonder why they changed back?
July 17, 2010, 9:57 pm
I saw one in person yesterday outside Greenville. Talk about picking the right time to visit my friend down there! It had manufacturer plates and was Vermillion Red.........can't say that's the best colour for it. I'm still not a fan of the design.
July 23, 2010, 12:26 am
some more pics:
August 16, 2010, 9:09 am
This is exciting news! The preliminary reports by the car mags. come to the same conclusion: the new X3 is a tremendous improvement over the out going model both in interior quality and improved suspension. It seems to be as large as the original X5. I'm giddy over the fact that it will be offered as an N55 single turbo "35i" version with 0-60 mph of around 5.5 seconds. An 8 speed ZF AT seals the deal.
This X3 sounds like the real thing and a new class leader.
August 16, 2010, 9:12 am
I wouldn't do the South Carolina quick turn around custom ordering because I would be paying top dollar at MSRP. I would rather go through my dealer and have some room to negotiate.
August 16, 2010, 10:32 am
August 16, 2010, 11:01 am
Like AzN, I doubt there will be much impact on the negotiating process.
August 16, 2010, 12:21 pm
August 16, 2010, 12:23 pm
August 16, 2010, 12:24 pm
Seems like one of the rare times BMW actually listened and from what I've read, has fixed the glaring faults found in the current X3.
September 2, 2010, 9:59 am
The old X3 is loosely based on the previous 3 series. How about the new X3? Based on the old X3, X5, or new 3 series?
September 2, 2010, 10:15 am
September 2, 2010, 12:44 pm
Speaking in reverse, I so hope that the new 8 speed ZF Steptronic in the X3 finds its way into the redesigned 328i in a couple of years. I hate the sleepy 6 speed GM Steptronic.
September 2, 2010, 12:47 pm
That said, I'm sure there are many components shared with or quite like the E90.
September 2, 2010, 1:20 pm
I don't like the new X3 because I feel instead of making it unique like Audi did with the Q5, they just made it a smaller downgraded version of an X5.
