2010 BMW X6M pushing 670hp by Mansory
by Tim Jones on November 11, 2010, 10:25 am
  tags:
x6m x6
After building up their BMW X5 M, tuning company Mansory set their sites on the X6 M. With the X6M already having an aggressive body kit from the factory Mansory went even more aggressive with the body kit, carbon fiber hood and 23" wheels! To move all this new body aggression Mansory has 'found' an additional 115 horsepower out of the engine moving their juiced up X6M from naught to 60 in 4.2 seconds!
The press release seems to have been machine translated so its a little rough. If you don't feel like reading translated marketing fluff just jump down to the pictures.
MANSORY Switzerland AG upgrades the BMW X6 M.
Soon after the presentation of the individualized BMW X5, MANSORY Switzerland AG, with its sister model the BMW X6, presents in society the second Bavarian automobile to be the fortunate object of a comprehensive revamp. An exclusive bodywork, performance and interior program has been developed and gives the SUV coupe a definitely more sporty appearance.
Just as with all previous vehicles, with the BMW X6, MANSORY has paid close attention to the precise fit of parts while at the same time bearing in mind a sporty, individual design. The perfectly harmonizing details turn the high demands which MANSORY makes on itself and on its products into reality and transform the wide-bodied Bavarian into a real eye-catcher. Due to a new front spoiler with larger air intakes and an extra light bonnet made entirely of carbon which, with its ventilation channels, optimizes air flow to the front engine, the MANSORY X6 already looks a lot more brawny when you catch sight of it in the rear-view mirror.
This impression is reinforced even more by the widened wings which flow into the newly designed side skirts and give the vehicle around 70 millimeters more width at the front and 80 millimeters at the rear.
At the back a newly designed skirt comes into play using an integrated diffuser which has room for four stainless steel exhaust pipes from the MANSORY sports exhaust system. A roof spoiler for additional contact pressure and a rear spoiler lip give the MANSORY X6 more stability at high speeds. Nearly all the aerodynamic components are fabricated by the engineers from high-tensile polyurethane (PU-RIM) and from prepreg autoclave carbon, characteristic of MANSORY. In the process, the preformed carbon-fiber parts are given a permanent shape in autoclaves by the effects of vacuum and heat which guarantees a perfect surface finish with low weight.
So that the overwhelming visual presence is given appropriate backup, MANSORY treats the BMW X6 M's production engine to a performance upgrade. At around 670 HP / 493 kW and a huge torque of 950 Nm at 5900 rpm, the MANSORY X6 surpasses the original figures by a long chalk (production engine: 555 HP / 408 kW and 680 Nm at 1500 – 5650 rpm). This leap in performance is made possible by using an entirely new exhaust system complete with exhaust manifold and perfected engine electronics. The performance, too, benefits from these modifications. In a mere 4.2 seconds, the MANSORY X6 makes it from a standing start to main road speed and thanks to a Vmax override reaches a top speed of 300 km/h.
Contact with the road is via distinctive MANSORY light alloy rims. These improve the handling and highlight the vehicle's appearance. The M10 silver-finished, cast, monoblock wheels are equipped with 315/25R23 tires which make for the right surface grip. With progressively wound sports suspension and an adapted height adjustment, at the same time the vehicle's center of gravity is lowered by around 40 millimeters so that the 23***8243; wheels fill the wheel arches. Larger brake discs and a multi-piston brake system to improve the deceleration values of the MANSORY X6 are already at the trial stage.
With the ergonomically, newly designed MANSORY Sports steering wheel, MANSORY Switzerland offers customers a special feature for the vehicle interior. Just as for all other MANSORY vehicles the same applies to the BMW X6: the customer can compose his own quite personal vehicle interior from the practically endless combinations of leather, Alcantara, wood, carbon or aluminum trim and just about any technical gadget imaginable. The in-house MANSORY leather workshop is always available to turn the customer's wishes into reality.
Source of press release - http://emotorauto.com/2010/11/10/201...hp-by-mansory/
Read more news about the BMW X6 M
Leave a Comment
0 responses to 2010 BMW X6M pushing 670hp by Mansory
