POWER/TORQUE/GEARING
Engine horsepower and engine torque is perhaps the single most misunderstood subject amongst people and even proclaimed car enthusiasts. The importance of the two values have been argued for as long as engines have existed and that is solely due to lack of understanding in physics and how powertrains really work in cars. In order to fully form an understanding, the very basics must be thoroughly grasped.
Defining Horsepower and Torque:
There are certain basic and fundamental equations that apply to physics upon which the foundations of more complex areas of knowledge are based on. An important concept to understand is motion. Motion is described by a few characteristics. Distance, Velocity, Acceleration, and Jerk. This will be explained with empirical units commonly used when discussing cars as well as in context.
Distance: is just a length in physical space of one dimension. Distance is measured in miles.
Velocity: is how much distance is traveled in a given period of time. Velocity is measured in miles per hour. For every single hour, the distance traveled X amount of miles. Velocity is the change in distance over time. Velocity is a characteristic of motion that cannot be felt. Traveling at a constant velocity cannot be known through a physical sense, because traveling at a constant velocity has no net force. Even if a force needs to be applied to maintain a constant velocity, it will be canceled out by the force of friction required and therefore the driver feels no force and therefore does not feel anything.
Acceleration: is how much velocity is changing in a given period of time. Acceleration is measured in miles per hour per hour. For every single hour, the velocity gained is an X amount of miles per hour. Acceleration is the change in velocity over time. Acceleration requires force and is therefore felt by the driver.
Jerk: is how much acceleration is changing in a given period of time. Jerk is measured in miles per hour per hour per hour. For every single hour, the acceleration gained is an X amount of miles per hour per hour. Jerk is the change in acceleration over time. Jerk requires a change in force, because a change in force causes a change in acceleration and is also felt by the driver. In automobile terms, jerk accounts for the fact that force is not applied instantly, but rather over a period of time.
Now, the set of terms to explain are how changes of different aspects of motion can be quantified or changed.
Force: Force is anything that causes an object to change velocity which means cause it to accelerate.
Torque: Torque is a force applied on a lever in rotation. If force is a push then torque is a twist. It is simply force applied on a lever of which the length is equally important as the magnitude of the force itself. It is shown as Newton meters except it is the amount of force that is applied on a given length lever.
Work & Energy: Work is the application of force through a certain distance. If a person applies a given force on a cart through a given distance then that person has done work. Energy is the capacity to do work and in this case, is kinetic energy. Both are measured in the same units. Work as well as energy is measured as Newton Meters which is commonly referred to as Joules.
Power: Power is the amount of work done over a period of time. If a person applies a given force on a cart through a given distance in a given period of time, that person has made an X amount of power. If that person can do it in less time then they have produced more power. Power is measured in watts. Approximately 746 watts equates to one horsepower.
Now lets place all of those terms in equations with explanations.
Velocity=Distance/Time <-Self Explanatory.
Acceleration=Force/Mass <-Force and mass is directly proportional to acceleration. Less mass and more force equate to more acceleration.
Kinetic Energy=(1/2)(Mass)(Velocity^2) <-This is the energy that an object has due to motion. It accounts for the velocity of motion as well as mass, however the values are not proportional. A car requires four times more energy to just double velocity. The ability to double velocity is defined as energy. Once that energy has been used and the velocity has doubled, it means that work was done on the object. Energy and work are very similar and both important.
Work=Final Kinetic Energy-Initial Kinetic Energy <-Work is the change in kinetic energy, as mention above, changing velocity of a car changes its energy. Work is just representing the change in energy.
Power=Work/Time <-Power takes into account how fast work can be done. While work just represents a change in energy or in our case, velocity, it never accounts for how long it takes for it do so. Doubling velocity may take 5 seconds or 10 seconds. The shorter the time span means that work can be applied at a faster rate and therefore that means more power is applied. Power is how much time it takes to accelerate an object through a certain distance or more simply, how much time it takes for an object of a given mass to change velocity and thereby automatically changing its energy. Given a cars mass and power, its possible to calculate the time it takes that car to reach a certain speed. Don't rush to do this yet, because as seen later on, it is entirely inaccurate in a realistic scenario.
Now things get interesting. To better understand these equations, they can be re-arranged to better fit the uses of analyzing a car.
If Power=Work/Time then Power=(Force X Distance)/Time. Since Velocity=Distance/Time then Power=Force X Velocity.
Force=Power/Velocity
^These equations (same equation just re-arranged) mean that power dictates the force that can applied at a given velocity. Provided the power is constant at all times (such as a battery) then as velocity increases, force decreases. In order to apply more force at a higher velocity, more power must be used. The relationship is inverse.
This leads to the final combined and most critical equation of cars.
Acceleration=(Power/Velocity)/Mass <-This means that to increase acceleration at a given speed, the power must be increased and/or the mass must be reduced. To achieve more acceleration, there must be less velocity so that it takes less energy to accelerate.
It is extremely important to note that torque and work/energy not be confused due to the similar appearing units. Even though the units appear similar, they are entirely different things and is also a common area of confusion amongst many proclaimed car enthusiasts. Nm in Torque is very different from Nm in work or energy. Torque is still a force by nature so work applied due to torque would can represented as Nm-m. The force on a lever of given distance is torque while the circumference (distance) through which that force is applied is the work created by that torque applied through a certain distance in a rotational manner.
Engines are weak:
An engine, even the most powerful around are much weaker than many realize. An average grown human can take the flywheel of most street engines in use today and hold it in place even if the engine is operating at maximum throttle. A street engine commonly has ~200ft-lbs of torque at maximum, its commonly even less. 200lbs of force isn't enough to do much of anything on a car. So how is it that these tiny and weak engines are able to accelerate such heavy cars so quickly. The answer to that is speed and gearing.
Suppose a person is tasked to use a 1ft lever and turn it around a pivot. A strong person may easily provide the same torque as a street engine. Now suppose that person was tasked to turn that pivot as fast as they can. A revolution or maybe even two per second is a reasonable estimate. Now, lets multiply that by 60 seconds to find the revolutions per minute. (2*60=120rpm). So a person is turning that at 120rpm (Rounds Per Minute). Well….most street engines operate over 2000rpm and can usually go up to 7000rpm. That can be dozens of times faster.
So now the question arises of why that's significant. Why does it matter that an engine can spin fast even though it isn't strong. Well the answer to that is gearing which will be talked about later.
Torque versus RPM:
Remember the equation of Power? Its Power=Force*Velocity. In car world, Power=Torque*RPM. Torque is a type of force and RPM is a speed. RPM is rounds per minute which is a distance in a time. Torque is a rotational force and RPM is a rotational speed. So power can be increased by either increasing RPM and/or increasing Torque.
Gearing:
Now comes the important summation of understanding everything discussed above. To understand gearing, a basic understanding of mechanical advantage must be acquired first. So what is mechanical advantage? Mechanical advantage is using leverage to amplify force. This brings us back to the equation of power. Leverage is largely based on the principle of conservation of energy which can be shown by both equations for energy and equations for power. Since time is constant in leverage for both sides of a pivot then the energy as well as power must be equal. Since distance as well as velocity changes then force must also change in order for the energy and power to remain constant.
Imagine a seesaw, the simplest form of leverage that can be demonstrated. A seesaw is a long bar that has a pivot or fulcrum in the middle. In the case of a see saw, the pivot point is directly in the middle of the bar. Now suppose two people sat on the seesaw of different weights. Due to leverage the people of different weights can perfectly balance the seesaw by simply sitting at different distances from the center of the seesaw. If the seesaw is a total of 20 feet and the two people on it are 200 pounds and 150 pounds then how would they balance it. Its all about torque. Since the pivot is exactly in the middle at 10 feet, then the 150 pound person would be exerting a torque of 150 pounds at 10 feet. This can simply be converted to having 1500ft-lbs, because typical measurements of torque in the automotive world use the distance of the leverage as constant being 1 foot. 150 pounds on a 10 foot lever would be equivalent of 1500 pounds on a 1 foot lever. Yes, this means that the 150 pound person can balance the seesaw if a 1500 pound object was placed 1 foot from the other side of the pivot. The two forces would cancel each other out and the seesaw would be in equilibrium. Since the seesaw must be balanced then the 200 pound person must be sitting at a certain distance away from the pivot that allows that person to exert 1500ft-lbs of torque. This is just a simple equation of (150lbs*10)=(200lbs*X). Solve for X and the answer is 7.5ft. At the point of the pivot, both people will be exerting the same torque and cancel each other out simply by changing the length of their leverage.
The reason why this works is conservation of energy and here is why. If the seesaw with the two people moves back and forth, the 150lbs person would be moving a greater distance than the 200lbs person, because they are sitting further from the pivot. Since Work=Force*Distance, the only thing constant is Work due to the law of conservation of energy. If the Distance is different for the two people, then the force must also be different in order to compensate and have the same amount of work to conserve energy. This can also be shown by the power equation. Since Power=Force*Velocity, then the two people travel at different velocities when the seesaw is moving and therefore the force must change to compensate and produce the same power output. Leverage can change force, but it can never change energy and as a result it cannot change power. Torque and force can be manipulated, but power and energy of a system must always be conserved.
Gears operate on the same exact principle with no exceptions. It is just easier to visualize a simple lever device. In gears, everything is about speed and torque. When multiplying torque, the speed is reduced. When dividing torque, speed is increased. Torque and speed have an inverse relationship. This is why in a car, the highest gear has the lowest torque (and therefore acceleration), but allows for the highest achievable speed on the road.
So suppose a car is placed in the highest gear at 5mph. In many cars, this is 6th gear. The driver will notice how the acceleration is very poor, however the RPM of the engine is gaining at a slow rate also. Now if the car is placed in 1st gear, the car will accelerate faster, but the RPM of the engine will also shoot up faster. This faster acceleration can only be maintained for as long as the engine allows, which is until it reaches redline. Once the engine is at redline, the driver must shift to 2nd gear. What this means is that the driver is sacrificing torque and acceleration, for more speed. 2nd gear will bring down the rpm of the engine and allow the car to keep accelerating to a faster velocity until once again it must shift to 3rd gear and sacrifice even more torque to gain more speed. This is why in cars, the transmission and gearing system (which also includes differentials and tire diameter) are designed for tremendous torque multiplication to be able to accelerate cars at what people consider a reasonable rate.
Here are three very important equations regarding engine power, torque, and the torque at the wheels. This is all using imperial system units which is the reason for the constants.
Horsepower=(Torque*RPM)/5252
Torque=(Horsepower*5252)/RPM
Wheel Torque=((Engine Torque)*(Transmission Gear)*(Differential Gear))/(Rolling Radius of Tire)
The torque provided to the wheels is vastly different from the torque the engine creates, because it is multiplied many times.
Lets simplify this now. Suppose there was an engine on a stand that was mated with a special transmission. This transmission has three special factors. It has an infinite amount of gear ratios, each gear ratio is infinitely close to the ratio before as well as after it, and it can be switched between each gear infinitely fast. This means that this transmission can hold the engine at a constant rpm at any velocity that the transmission outputs. At which RPM would the transmission then proceed to hold the engine? Would it be at the peak power or the peak torque? In a street engine, the engine is always producing less torque at its peak power rpm then it does when it is at peak torque rpm. If power is merely a calculation then why would a transmission optimally hold an engine at peak power? The answer is multiplication.
The greatest acceleration at any given speed occurs only at the peak power, not the peak torque, because despite less torque at the peak power….the multiplication due to gearing is always greater and always will compensate as well as supersede the torque provided at peak torque.
Lets take a look at an example. Suppose there is an engine with the following specifications:
Peak Power=200hp @ 6,000rpm
Peak Torque=200ft-lb @ 4,000rpm
So now lets use equations to find the torque provided at peak power as well as the power provided at peak torque.
Torque @ Peak power RPM (6,000rpm)=175ft-lb
Power @ Peak torque RPM (4,000rpm)=152hp
Notice here that less power is produced at peak torque. Here is the significance to that. Suppose we have a rear wheel drive vehicle with a transmission gear of 4:1, a differential gear of 4:1, and a loaded tire radius of 1 foot.
At the peak torque rpm, the car will be traveling at 17.8mph.
The car in this case will be delivering ((200ft-lb)(4)(4))/(1) total pounds of force to the road. By dividing the tire radius, we are finding the force applied to the road itself at the very outer edge of that tire.
After doing the math, the force will be 3200lbs. Remember that weight is a force, because weight is Mass*Gravity (with varying units).
Now what kind of force would the car have at the same speed of 17.8mph if only the engine had been at peak power rpm instead of peak torque. In order to accomplish that, the gearing must be changed. It doesn't matter what we change so lets do the transmission gear ratio. For this speed, the transmission ratio would now have to be 6:1 instead of 4:1.
In this case the car will be delivering (175ft-lb)(6)(4)/(1) total pounds of force to the road. After doing the math, the force is 4200lbs.
So the force at peak power is 4200lbs at 17.8mph while the force at peak torque is 3200lbs at 17.8. That's over 31% more torque at the wheels. So as can be seen, despite less engine torque, power allows for more torque at the wheels through multiplication.
Area under the curve:
Peak power and peak torque are just instant values that occur at a point in the rpm range of an engine. As important and significant as they are, the amount of torque and power an engine produces throughout its rpm range is also important if the car is using gears. If a continuously variable transmission is issued, it could keep an engine at its peak power rpm and adjust gears for every speed so that torque multiplication is maximum for every speed. Since street cars at this point still use gears, it means that one magnitude of torque multiplication (a gear) must be kept for a range of speeds, not just one speed.
If an engine is placed on a dynamometer it will provide a chart of an engine's torque through its rpm range. Power is then calculated from that curve. So then the question is raised, which curve is more important?
When an engine is on a stand, the power is more important. Based on the power curve, the gearing system can be set. This is shown by the area under the curve….aka the integral. Once an engine already has a system of gears, it means that its potential is now limited and acceleration in a given gear will in fact mimic the torque curve since torque is the only thing that is changing if the gearing is constant. The power curve, or at least part of it, shows the true performance potential of an engine when mated with a conventional transmission or gearing system. Once an engine is already mated with gearing then the torque curve shows what happens when accelerating.
The torque will remain the same in area no matter which RPM it is presented at. The power curve however will be larger at higher rpm's, which is why torque and rpm are equally important with regards to power and therefore performance. An engine that is already mated with a transmission already has its performance potential taken advantage of only to the extent of its gearing. The longer the gears are then the less potential of power that engine is used, because it is operating further away from peak power.
An engine with the same torque at higher rpm's can use steeper gearing ratios to achieve the same speed due to gearing which
means that they can achieve much greater acceleration. So a 2.4L F1 engine with a relatively small amount of torque, but high horsepower is just as capable as an engine with the same horsepower even if it has a thousand ft-lb of torque, such as a truck engine.
Due to gearing, a theoretical top speed if accounting for air resistance is based on peak power, not peak torque.
Shifting Points:
There is a lot of debate on shifting points with cars. Simply put, shifting at any point other than redline is almost always bad. Even if torque is drastically declining at redline, the torque at the wheels from remaining in a lower gear will almost always compensate and still provide better acceleration then the next gear.
Differential modification theory (Short or long gears):
Changing out a differential can yield significant performance gains. Shorter gears keep rpm closer to peak power and therefore improve acceleration of a car. This is due to more torque multiplication. However, due to limited amounts of gears, top speed is sacrificed when this is done.
The rule of engines:
1) That peak horsepower IS the single most important and ONLY important aspect of an engine's maximum performance ability. This case scenario only happens if this engine is always running at its peak power rpm and that can only happen with a CVT designed for this. There are no *if's*, *and's* or *buts* for this.
2) In the real world when comparing normal cars, the most important aspect of an engine's performance capabilities when mated with a conventional gear based transmission is the power curve. This is because the area under the curve of a different operating range takes into account the torque and rpm which is what is needed to determine the best ratio of gear multiplication to use for that engine.
3) Peak Horsepower is the best indicator usually of a cars performance at first glance (ignoring weight). Most websites provide only provide specifications on peak torque rpm and peak horsepower rpm. Out of the two values, the Peak Horsepower alone will provide the best predicament of performance. Torque provides much less prediction accuracy, because trucks and work-horse vehicles have relatively low horsepower and very high torque levels, because they use diesel engines operating at high stroke to bore ratios and requiring immense compression. They cannot spin to high rpm's. A high peak horsepower says that most likely, the vehicle is producing more torque at high rpm's and therefore most "likely" has more performance potential. In most cases, the car with a better horsepower/weight will win.
4)Once an engine is already mated with a transmission, such as a car, the torque curve must be used, not the power curve to determine force exerted to the road. The given power has already been taken advantage of to a certain and limited extent by the gearing and cannot be used anymore, so the power curve in this case is irrelevant. Since the car remains in the same gear over a variety of speeds, the power may be increasing, but the acceleration is decreasing, because the torque is decreasing and the car is not compensating for that with steeper gearing and therefore the power curve doesn't apply when an engine is already connected to a transmission. So basically if you want to compare the performance of your car against a friend's car (not the engine, but the CAR), which already have wheels, a differential and a transmission set in, then use the torque curve of the engine.
5)Two engines making the same power, (peak power in the case of a CVT or power under the curve in the operation range given by gearing) are equals in all aspects regardless of any torque, displacement or any other factors.
So what have we learned?
Horsepower is more important than torque. Common sense, physics, mathematics and real life all prove it. More horsepower is more important, because it means more torque delivered to the road to accelerate the car, because it all has to go back to the gearing system. However, peak horsepower and torque numbers say little in terms of daily driven cars sold on markets today due to the variability in the curves and gearing purposes set in them. So next time a friend argues that his obnoxiously huge American muscle car V8 has *tons* of torque to compensate for its low horsepower, tell them they don't know what they're talking about. A small 1.8L engines like ones made in Japan and Germany are just as capable if they put out similar horsepower averages, except due to their higher rpm they are a lot more complex and advanced. Remember, when going from idle, torque at low rpm does help with daily drive-ability. However in a drag race and any performance situation, horsepower is what really counts. Thank you for reading. Always remember that the key to the entire war is *gearing*. If you don't account for gearing than the game can change a lot, but then again there would be no point since gearing is used everywhere. Torque of an engine is an absolutely meaningless value in real life performance of a car. We can sum everything into one, three word statement.
HORSEPOWER WINS RACES.
Credit: Carstechinfo.com
Leave a Comment
33 responses to Horsepower vs Torque: Explanation and Relevance to you
DSXMachina commented:
December 4, 2012, 10:06 pm
Is this posted elsewhere in Bimmerfest?
Bimmer1995318ti commented:
December 5, 2012, 1:17 pm
This is wonderful. My favorite post so far. Excellent write sir.
jcs commented:
December 6, 2012, 8:37 am
Thanks a lot for posting this. Very well written and explained.
JimD1 commented:
December 6, 2012, 8:55 am
I didn't read the whole thing but it seems OK. There is a far easier explanation of the two terms, however. Torque is just rotational force. It takes torque to spin the wheels against load. As long as you have more torque than the resistance, the vehicle moves. An 18 wheeler needs a lot of torque to get the load moving. The diesel engines they use have many times more torque than they have hp.
To accelerate quickly we need to do work quickly. In physics, work is defined as force times distance. The rate at which work is done is power. Our electric companies measure power in watts and kilowatts (thousands of watts). Watts and hp both measure power. 1 horsepower is defined as 33,000 lb-ft/min and is equivilent to almost 746W.
It makes a lot of sense to me that what makes us accelerate more quickly is not force but the rate at which work is done. That is why hp is more important than torque for acceleration.
Jim
Bandem commented:
December 6, 2012, 11:37 am
Jim
Thats true, but somebody with little understanding reading this will make no real-world connection from that explanation and still won't understand. What you wrote has been written all over the internet and its not explaining the significance in a realistic way that a person can relate to. Before I understood the topics I wrote about, I read dozens of explanations very similar to that and it absolutely did nothing to help my understanding. In fact I ended those articles with more questions than answers.
Gripster commented:
December 7, 2012, 10:39 am
Great explanation. It's like a engineering degree in a single post. Except in plain English.
JimD1 commented:
December 7, 2012, 2:51 pm
I have a degree in mechanical engineering which may be part of the reason the shorter explanation works well for me.
With respect to gearing, what is really going on is you have to get into and stay into the rpm range where peak hp is developed to maximize acceleration. It is correct to think of the gearing as multiplying torque but what we really care about for acceleration is the hp. If you shift early, the hp available is less so you accelerate more slowly. If you shift around red line, you are typically spending most of your time near peak hp so you accelerate more quickly. A really high numerical advantage at the start gets you into peak power very quickly. Tight gear to gear spacing keeps the fall off less when you shift gears.
A manual transmission is in some ways helpful to acceleration so a lot of the time the manufacturer will compensate with the gearing. A 128i manual is faster than a 128i automatic. But in a 135 they are essentially identical. At least in 2009, the 135i automatic has more gearing advantage at the start to make up for the lower efficiency of the torque converter automatic. With the DTC the losses of the torque converter are eliminated so the automatic may be quicker if it still has a gearing advantage. Shifts of an automatic are quicker but torque converter automatics are somewhat inefficient due to the need to transfer power through the torque converter.
Jim
Bandem commented:
December 7, 2012, 4:36 pm
Exactly! My point was to explain to everybody, not just scientists. My audience wasn't aimed at you, because you already know far more than this anyway. My explanation was child's play for somebody who has a ME degree, knowing what it involves.
Yup, exactly, shorter gearing to keep you closer to peak HP is better. However, you have a limited amount of them, usually 6, so at that point, it will be faster for you to drop off a lot lower RPM's, then shift every 2 seconds, because shifting ultra fast isn't easy.
I may actually edit my post to touch onto this topic. I think TQ automatics are slowly dying off in high-end cars. A lot of high-end cars have """AUTOMATICS""" who only use a torque converter for 1st gear or just getting moving, and then use a full lock-up clutch for everything past. Its a more expensive way, but DCT's and SMG's can all be shifted automatically and still have low power loss.
Oh yeah, and I am also going to add a great reference to my example to give people a sense of reality in acceleration times. From what I found/derived.
I see that ((Velocity^2/2))*(Mass/Power)=Time
Is this right, just to confirm? I want to show people that if you had optimal gearing, it would take a lot less power in cars to accelerate to 60mph (for example). A CVT running at peak HP can cut 0-60times off by as much as half in some cases. A toyota Camry with 200hp can do a 0-60mph in well under 5s with a CVT. Goes to show how critical gearing is, which is why I emphasize it.
Robin128 commented:
December 8, 2012, 6:19 am
I am a Chartered Management Accountant with an MBA...not a ME...however, the detailed and simple explanations above explained it all...thanks!
JimD1 commented:
December 16, 2012, 5:21 pm
I don't think there are any simple equations to turn hp or torque into acceleration. We know that distance=initial velocity times time plus one half times the acceleration times the time squared. We also know that force equals mass times acceleration. The problem is with the force part of the f=ma equation. We can rearrange it to a=f/m but where do we get force? At any instant, I think it is the torque of the motor times the gearing minus any losses. But it constantly changes as the rpm changes and the gears change. So you'd have to do a lot of work to try and calculate this.
Maybe that difficulty is why the on-line calculators are empherical. They use published (or test) information to develop a relationship.
Jim
Bandem commented:
December 17, 2012, 8:44 pm
I realize rpm is changing, but ignore automotive for a minute.
Analyze this equation purely from a physics and theoretical standpoint:
^Does that equation mathematically work out?
JimD1 commented:
December 18, 2012, 5:45 pm
One of the simplest ways to check an equation is to plug in the units and see if you get the result you want.
If we square velocity in Ft/sec we get feet squared over seconds squared. I like pounds for mass. 1hp=33,000 ft lbs/minute which we can convert to ft lbs per second by dividing by 60. That gives us units we can deal with.
But if we go through the math on the left side of your equation, we get ft/sec or velocity. We do not get time.
Jim
Bandem commented:
December 26, 2012, 3:12 pm
I added a section I forgot about differentials. Some more updates with pictures to be added.
Bandem commented:
January 10, 2013, 3:32 pm
Jim
Actually, I got a some time to recheck that and it does work out for me. Power is Work/Time. Kinetic Energy/Time=Power so that can be redone so as Energy/Power is time. When I used SI units, it worked for me.
Bandem commented:
January 14, 2013, 9:39 pm
Added a section on CVT!
ProRail commented:
January 14, 2013, 10:33 pm
Enough, already. Torque vs. HP? Lots of these guys don't even know the difference between acceleration and velocity, and what's more they don't care.
Bandem commented:
January 14, 2013, 11:11 pm
Well, if they don't care they won't read it. This is for the ones that do .
DreamerM6 commented:
February 10, 2013, 11:53 am
Awesome thanks so much!
Candide13 commented:
April 25, 2013, 3:20 pm
It is quite easy to get a link between power, torque and acceleration if you are willing to ignore friction and air resistance (and don't change gear .
Take the kinetic energy of the car, which is
E= 0.5*m*v^2
where m is the mass of the car and v is its speed. Actually, there should also be a contribution from the spinning wheels, and the spinning engine, but we can imagine those have been absorbed in the definition of the mass m, ie the relevant m is a little higher than the actual weight of the car.
Now, the rate of change of energy with time equals the power P. So, by the magic of calculus, we obtain:
m*v*a = P
where `a' is the acceleration (ie the rate of change of the velocity). So, at a given speed v your possible acceleration is proportional to the available power P, as you would expect. Of course, as you accelerate, your speed v goes up, so depending on how P changes with vehicle speed you may accelerate at different rates.
Now, we use the fact that power is torque times (angular) velocity of the prop-shaft and that the angular velocity is proportional to the speed of the car (if you don't change gear), so P is proportional to v times the torque T, say.
That means the v cancels on both sides and we get that m*a is proportional to the torque T! So as you speed up you find your acceleration is proportional to the torque T offered by the engine. The vehicle speed and the engine rev speed cancel out.
This means that with a flat torque curve your acceleration will be constant, which is why people rave about "linear" acceleration when the usable rev band has a large chunk of constant torque, as it does in the V8 M3, for example, which has some 4000 rpm of usable rev band with essentially flat torque.
Bandem commented:
April 27, 2013, 7:13 pm
Not as easy as you may think. I can't tell you how many people I know who have the mindset of:
"Power is just a calculated value and therefore unimportant, your torque is what's important because its what actually accelerates you" or
"My muscle car has only 200hp, but a billion lb-ft of torque and therefore is as fast as car with more power"
And most of all, what drives me nuts is the extremely common confusion when people think torque is the same thing as work since both involve force and distance...Torque has nothing to do with work or energy. A lot of people don't realize that and its probably in the roots of that misconception.
AutoGuy commented:
February 7, 2014, 11:32 am
That is a pretty thorough explanation on the difference between torque and horsepower. Really explains why horsepower is more important than torque in acceleration. Nicely done.
Leo-RochesterMI commented:
March 23, 2014, 1:47 pm
Great texts here:
Let's not forget though that the application also plays a role in this discussion.
If one wants to scream the engine at max power, power is everything that maters. However, high torque will keep the driving experience "effortless" in normal everyday driving.
If you can afford it, you want to have the most power capable, large engine (torque), and the most sophisticated large transmission (more gears) that money can buy. That's what many cars are labelled as a delight to drive in any conditions (eg, Aston Martin 12 cyl., except race track), and others recognized as quite laborious to drive (eg, Ferrari V8, anywhere but in the track).
Not very difficult, just a matter of money and/or application.
Leo-RochesterMI
2010 30ixDrive Black/Black
cridge commented:
April 4, 2014, 8:32 pm
Understeer is when you hit the wall with the front of the car.
Oversteer is when you hit the wall with the rear of the car.
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you
dsx724 commented:
April 11, 2014, 7:43 pm
loled at the last one.
Fish23 commented:
April 24, 2014, 5:41 pm
Me too. Well done........
nicobmwlife commented:
November 23, 2014, 2:49 pm
thank you for writting this. Solid points!
December 19, 2014, 10:42 pm
Killin it !!
sinahb commented:
December 20, 2014, 8:53 pm
Wow, just wow. All that detail! thanks a lot
Damon44 commented:
January 4, 2015, 6:27 am
As if I was taking Physics again in the 70's. Excellent definitions of basic principles. Wonderful reference material. Thank you.
Phil2204 commented:
October 12, 2015, 3:47 pm
A well written and thorough explanation. Many thanks for taking the time and sharing!!
jlbjr commented:
July 31, 2016, 8:03 pm
This sounded interesting until you made the statement about holding the flywheel of the engine. No way that is right. JMO.
Morgan444 commented:
October 4, 2016, 3:38 pm
"An engine, even the most powerful around are much weaker than many realize. An average grown human can take the flywheel of most street engines in use today and hold it in place even if the engine is operating at maximum throttle."
What???
I'd love to see someone hold the flywheel of even a small engine when just turned over on the starter motor.
There is a very direct relationship between torque and horsepower. The formula originally posted is the single thing in the OP that is in any way relevant:
Horsepower = (Torque x RPMs) / 5252
The constant of 5252 has a complex calculation behind it that is probably not important to this discussion. The thing to understand is that horsepower is calculated from torque which in turn is physically measured on a dynamometer. But importantly, nothing about this formula has anything to do with the acceleration of the vehicle or the speed of the propshaft. It has only to do with the speed of the engine (RPM) and the torque produced by the engine at specific engine speeds.
The reason why a car cannot accelerate well at low speed in 3rd gear is because the engine RPM at that road speed in that gear is too low to produce torque. This is a characteristic of the engine design.
Just look at a torque curve graph - this is not rocket science.
When you see a car being run on a "rolling road" (dynamometer), do you think they're measuring horsepower? They aren't, they're measuring torque. The horsepower rating is derived from the torque measured.
"If power is merely a calculation . . . ." It's not a case of "if". It IS merely a calculation.
Actually, there is so much wrong with the OP, I'm astonished that this has been given "sticky" status.
zombimmered540i commented:
December 25, 2016, 11:33 am
I'm glad I read this. Someone above me in the comments said, and im paraphrasing, "a noob that reads this wont gain in knowledge, and will have more questions at the end." I have to say, at 44 I have the amount of time it took me to read this vested in the hp vs Nm's. Aside from 9th grade science and the usual math classes. I now can say, without a doubt, that I understnd what the two units of measurement mean, and why gearing is so important. For the first time in my life i own a car that I want to spend my time and money on. I havent so much as washed a car in 12 years. Til a few months ago. Now i have a kick ass E34 on jack stands in my garage, front end dismantled, and parts in the mail. What does this all mean? I dont have the foggiest. But I do know that if tbis is the quality of info i will find on here, Im gonna love this forum as much as I do my Zombimmer. I tend to ramble, sorry. Great explanation. cant wait to school a few chevy owners. thanx for the knowledge. sincerely
