F30 320i vs 328i engines - Part number comparison
tags:
f30post f30 news f30 328 bmw parts bmw part numbers bmw news bmw f30 320i bmw 320 vs 328 2013 320i 2013 3 series
BMW has just announced a new entry level F30 3 series, the 320i. The 320i shares the same N20; TwinPower single turbo, twin scroll, 2.0 liter inline 4 cylinder engine as the 328i. The 320i is factory rated at 180 hp at 5,000 RPMs and 200 lb-ft of torque from 1,250 RPMs. Stacked next to the 328i with 240hp at 5000 RPMs and 255 lb-ft of torque from 1250 RPMs and the obvious question is what is the difference in the two engines.
The first obvious answer is there is something in BMW's DME control software that limits the power, most likely by limiting boost pressure, on the 320i. That appears to be true as both the 320 and the 328 use the same DME hardware (PN - 12148604210) and the same engine control system MEVD 17.2.9. With a software tweak the likely difference between the 320i and the 328i we go in search of other changes that might limit the 320is ability to make the same power the 328i N20 puts down.
Read more about the 2013 BMW 320i entry level 3 series
The next easy target is the intake, exhaust manifold and turbo. Surprisingly they turned out to be the same part number. In fact the 320i and the 328i share the exact same part numbers for a majority of the engine components.
Shared engine components between F30 320i and 328i
- Cylinder head - PN 11127624778
- Connecting rods - PN 11247624616
- Crankshaft - PN 11212212762
- Intake manifold - PN 11617588126
- Air box - PN 13717597589
- Air filter - PN 13718507320
- Intercooler - PN 17517618809
- Radiator - PN 17117600520
- Throttle body - PN 13547588625
- HPFP - PN 13517584461
- MAF - PN 13627602038
- DME/ECU - PN 12148604210
- Exhaust manifold/turbo - PN 11657642469
See what is missing in the above list? The difference in the 320i and the 328i is the pistons. While both have a 10:1 compression ratio the 320i has a different part numbers for the pistons then the 328i. What that exactly means in terms of the ability to boost the turbo pressure and get 328 horsepower from your 320 is not yet known.
Stay tuned as we continue to sift through BMW's technical documents searching for an answer.
Recent BMW News
Latest Forum Discussions
- Runflat warning light
- Suing the state/County for deceiving lane
- No Need to Worry, Right?
- Interior Trim Touch Up or Replacement
- What color wheels would look good?
- 2007 335I convertible top Leak
- Tire swap
- Steering wheel multifunction switch not working
- Cigarette lighters not working 08 335i e90
- 2013 328i convertible wind deflactor
January 17, 2013, 6:18 pm
WOW! So there's some serious potential to turn things back up in this car then!
If you could get to 210-220hp with a similar boost in torque with a Stage 1 upgrade, this car just got a whole lot more interesting to me.
January 17, 2013, 8:33 pm
January 17, 2013, 8:34 pm
What's the bore & stroke between the engines?
From your list there are lots of areas for lost power & response from these:
-smaller diameter throttle body
-smaller or non straight intake manifold runners
-smaller diameter airbox
-lower flow CFM air filter
-smaller intercooler
-non dished pistons
-crankshaft with a lower stroke
-smaller exhaust manifold/turbo
-non polished or ported cylinder head
Seems like they are limiting power via less air & a controlled less powerful combustion. Plus the turbo recovery and cooling are more crippled.
January 17, 2013, 9:15 pm
Are we sure it's 10:1. Here's the difference in the short block description
328i
Short Engine N20B20A 1 11002297079
only in conjunction with
320i
For vehicles with
Low compression engine
S858A=Yes <== what is this?
01 Short Engine N20B20A 1 11002297079
January 17, 2013, 11:20 pm
isn't starting w/a lower compression engine better for swapping in a big honk'n turbo?
(of course that would only be coupled with greatly increasing for the airflow both in and out ; just wanted to frame it with that)
January 18, 2013, 12:52 am
Basically we'll have to rely on a vendor to engineer an exhaust manifold and plumbing, or swap in from another engine/year like they do on the Audi's A4's, which have a similar setup. I checked the 745Li (IIRC), which is a turbo'd v8, but the header flanges are different and it may not even be an "upgrade". Intra-make part upgrade/swapping is not a new concept, but in the case of turbo's it requires knowing the subtle differences between the parts.
Back on-topic, I think the OP was incorrect, but I'm open to be proven wrong. I hope I'm right though cuz I'll be pretty pissed if it's just a tune
January 18, 2013, 8:30 am
So I'm really curious about the pistons. That could either be no big deal or big freaking deal when it comes to turning the power up. Why swap them? The biggest reason I can think of is cost-savings OR greater rotating mass efficiency through a different crown design or ring pack design. But it's not like the regular n20 is some inefficient beast - so neither of those really makes sense to me except perhaps cost-savings achievable by using a lower quality piston because you are running so much less dynamic compression against them with the detuned engine.
If I'm totally off base then the 320i is going to be the entry-euro-tuner's delight. No forced "lines", cheaper, and an engine ready to play in the ~260whp range on pump gas.
January 18, 2013, 9:13 am
There is defnitely a difference in compression ratio. The 328 is 10:1 and the 320 is 11:1. Thus, the higher compression 320 will knock a lot sooner than the 328, so less tunable. I've also heard that the 320 has thinner drive shafts.
January 18, 2013, 11:15 am
http://www.bmwusa.com/Standard/Conte...fications.aspx
The 320i gets different part numbers for the rear half shafts, but it doesn't look like the 328 shares half shafts with the 335i either. So you could say the 328i shafts are thinner then the 335i. I have no idea if that is true or not, but you see my point.
Tim
January 18, 2013, 11:17 am
-non dished pistons
Tim
January 18, 2013, 11:26 am
328i
320i
For vehicles with
Tim
January 18, 2013, 11:32 am
Check post #6 here: No official quote from BMW, but rather a BMW tuning company in SA.
http://www.bmwfanatics.co.za/showthread.php?tid=39504
January 18, 2013, 11:35 am
Makes sense I guess. That means that you'd need a thicker head gasket or something to decrease the compression ratio to really be able to turn up the boost. Not the end of the world but not as simple as a software flash.
Tim
January 18, 2013, 12:05 pm
According to RealOEM the 328i N20 piston (11257618811) is no longer manufactured http://www.realoem.com/bmw/showparts...70&hg=11&fg=20
January 18, 2013, 12:22 pm
The bmwusa configurator says the 320i base weight is 3295lb, so with the same N20 engine as 328i(3410lb, 8AT), where is the weight reduction coming from? Also, detuned N26 is not available on 320i, which is odd since N26 should benefit BMWNA on the PZEV footprint. This may mean N26 is either too expensive, or, N26 cannot be tuned(disappointing!).
January 18, 2013, 1:40 pm
Tim
January 18, 2013, 1:42 pm
January 18, 2013, 2:08 pm
328i:
Engine
Type/cylinders/valves per cylinder
TwinPower Turbo/Inline 4/4
Displacement
1997 cc
Bore/stroke
3.3/3.5 inch
Nominal output hp/rpm
240/5000-6000
Max. torque lb-ft/rpm
255/1250-4800
Compression ratio
10 :1
320i:
Engine
Displacement
1997 cc
Bore/stroke
3.3/3.5 inch
181/5000
184(250) / 1250-4500
Compression ratio
10 :1
January 18, 2013, 2:14 pm
I have feeling the data on BMWUSA.com is wrong.
January 18, 2013, 2:15 pm
328i:
Engine
Displacement
1997 cc
Bore/stroke
3.3/3.5 inch
181/5000
Compression ratio
10 :1
320i:
Engine
Displacement
1997 cc
Bore/stroke
3.3/3.5 inch
181/5000
Compression ratio
10 :1
January 18, 2013, 2:22 pm
January 18, 2013, 2:38 pm
The datasheet also says 320i 8AT has 250 lb-ft, which is almost the same as the 328i. So it seems the only difference is really 60+HP.
Footnote
Figures in ( ) apply to vehicles with 8-speed automatic transmission.
181/5000
January 18, 2013, 2:57 pm
Unfortunately, here's what I *think* happened. I have an email out to BMW to comment.
2012 MY 328's have 10:1 N20's tuned low
2013 MY 320's have 11:1 N20's boosted low
~2013 MY 328's have 11:1 N20's boosted high (see my post about piston being discontinued)
This would mean that BMW would put the same engine with the same CR in both 320 and 328. Makes sense for simplicity sake. The bad thing (for 328 owners) is they will already be tuned high (most likely more boost from factory). So, from BMW's perspective 328 owners can no longer piggy back to ~335i power, but 320 owners can piggy back to 328 power. This is oversimplified, but hopefully you get the idea.
If a "legacy" 328 needs a new piston all 4 will be replaced with the 11:1 CR ones and a software update. This whole setup means that BMW has to only maintain 1 set of pistons and two tunes. Not 2 sets of pistons and two tunes. One way to confirm without digging into the engine is to check new vs old 328 boost pressures, which is probably where they would make the adjustment (like a piggyback).
This is all speculation, but might be worth looking into deeper.
EDIT: This jives with namelessman's post. Power increase from boost would primarily be seen in the HP range.
January 18, 2013, 3:41 pm
Is HP = torque x rpm? Since the torque specs on both are similar(at least for 8AT), so maybe the difference is to taper the engine rev on 320i N20 at 5000rpm to throttle at 181hp, but allows 328i N20 to keep pushing to 6000rpm and 240hp. I guess we would see dyno charts soon enough on this. For now, 328i does appear to be a $2k-3k(expensive) factory tune versus 320i.
As tim330i noted, the bmwusa data can be incorrect too, or else it would really be odd that 320i N20 MT only get 184 lb-ft@1250-4500rpm ....
January 18, 2013, 4:12 pm
January 18, 2013, 6:00 pm
Taking a look at the UK 320i engine specs, this is what I would expect:
Engine Cylinders/valves 4/4
Capacity (cc) 1997
Stroke/Bore (mm) 90.1/84.0
Stroke/Bore (inch) 3.50/3.30
Max output (kW/hp/rpm) 135 (184)/5000
Max torque (Nm/rpm) 270/1250-4500 (270Nm = ~200lb-ft)
Compression ratio : 11.0:1
January 18, 2013, 6:14 pm
What is unclear now is how to get the 120-lb weight reduction. Does the factory take out all the noise-insulation material to save weight and 320i is noisy as hell?
January 18, 2013, 9:40 pm
electric seats
rear fold-downs
Different:
Exhaust
Drive and axle shafts
Tranny
Here and there you could probably pick away 120-lb
January 18, 2013, 9:55 pm
electric seats
rear fold-downs
Different:
Exhaust
Tranny
January 19, 2013, 2:01 am
electric seats
rear fold-downs
Different:
Exhaust
Tranny
January 19, 2013, 2:34 am
its a different transmission?
January 19, 2013, 9:24 am
January 19, 2013, 11:56 am
(copy-paste data disclaimer
rear axle output shafts -- 320i: 28mm; 328i: 31mm; 335i: 35mm
drive shafts for AT -- 320i: 1563mm; 328i: 1539mm; 335i:1508.5mm
335i AT:
Rmfd automatic transmission EH GA8HP45Z 1 09/2012 24008601194
328i AT:
Rmfd automatic transmission EH GA8HP45Z 1 09/2012 24008609706
320i AT:
Rmfd automatic transmission EH GA8HP45Z 1 09/2012 24008609707
335i MT:
Rmfd-6 speed gearbox GS6-45BZ - THY8 1 23007617492
328i MT:
Rmfd-6 speed gearbox GS6-17BG - TAU0 1 23007633990
328i MT:
Rmfd-6 speed gearbox GS6-17BG - TAY9 1 23007633989
January 19, 2013, 11:58 am
335i AT:
328i AT:
320i AT:
335i MT:
328i MT:
328i MT:
January 19, 2013, 12:06 pm
January 19, 2013, 8:16 pm
January 21, 2013, 1:08 am
328i
320i
For vehicles with
January 21, 2013, 1:22 am
January 21, 2013, 5:21 am
Anyone have the 0-60 time on the 320?
Sorry just saw the answer in the other thread.
January 21, 2013, 10:53 pm
I can't speak to CEL's, etc. That's probably better asked in a separate thread. I will say if the 2013+ 328's do have a different CR, the vendors will probably have to start asking customers the MY of their 328's.
February 1, 2013, 11:00 am
I can 100% confirm that the compression ratio on the F30 320i is 10:1. That is the same 10:1 that the 328i has.
Tim
February 1, 2013, 8:38 pm
Tim
February 2, 2013, 9:11 am
Tim
February 2, 2013, 9:01 pm
Sweet!
February 3, 2013, 4:23 pm
February 12, 2013, 12:52 pm
Any updates on the engine comparisons?
February 12, 2013, 1:36 pm
Tim
February 12, 2013, 2:06 pm
Tim
N20 Stage2 tune development is underway now.
February 12, 2013, 2:26 pm
Tim
February 12, 2013, 2:42 pm
Tim
February 12, 2013, 3:13 pm
Sent from my iPhone using BimmerApp
February 13, 2013, 10:44 am
February 28, 2013, 9:21 am
Care to speculate on what stage 1 adds in the 320i? By my guesstimates it should put out 210-220 bhp?
May 20, 2013, 2:59 pm
Let me bump this to catch Terry's attention as I too would appreciate hearing his answer.
Jack
