Dinan Product Release: Stage 1 Suspension for F30 335i & 328i now available.
by Bernie McGroarty on January 17, 2014, 12:29 pm
F30 335i & 328i Stage 1 Suspension
Dinan's Performance Spring set for the F30 chassis 335i & 328i BMW provides greater control over body roll by virtue of carefully calibrated spring rates designed to work in conjunction with the original-equipment standard or Adaptive M Suspension shocks and struts. Dinan lowers the 335i & 328i by 20mm front and rear for improved suspension geometry and an even more aggressive stance. The kit also includes tuned, progressive rate bump stops. The bump stops provide increased suspension travel on the lowered car for improved handling capabilities and ride quality when compared to a lowering spring set alone. The Dinan springs are CNC wound with high tensile chrome silicon wire and shot peened for stress relief to last the life of the car.
The 30% increase in spring rate will reduce the rear suspension compression under acceleration and front suspension compression (or dive) under braking, giving your car a more controlled feel. The Dinan performance springs with the progressive rate bump stops will also provide a noticeable improvement in grip, for high speed driving situations that will inspire confidence in your car's capabilities. The reduced body roll makes the steering more responsive to driver input and will be noticed at speeds as low as 20 mph, up to the top speed of the vehicle.
Product Details:
335i - Retail - $549.00
D190-3011 (rwd only)
328i - Retail - $499.00
D190-3001 (rwd only)
More at www.dinancars.com!
Leave a Comment
10 responses to Dinan Product Release: Stage 1 Suspension for F30 335i & 328i now available.
SD535i commented:
January 17, 2014, 12:34 pm
now if they could only get their stage 2 software working with the F30!!!
SergioK commented:
January 17, 2014, 4:42 pm
It took them this long just to come out with springs??
Dippydo commented:
January 17, 2014, 5:29 pm
If it took this this long to come out with springs for a 2 year old car, imagine how long a tune will take...Geeezus...
chetman7 commented:
January 17, 2014, 8:06 pm
Boo no x drive
Saintor commented:
January 17, 2014, 9:17 pm
How much lower?
stevehecht commented:
January 17, 2014, 9:18 pm
Originally Posted by Saintor View Post
How much lower?
20mm lower than sport/Msport
CarlosC commented:
October 17, 2014, 2:45 pm
Does that mean 40mm lower than stock suspension?
ctome3 commented:
October 17, 2014, 3:36 pm
Any plans for xDrive springs?
CarlosC commented:
October 17, 2014, 3:48 pm
xDrive springs for both F30 328i and 335i are available now at www.dinancars.com
caius commented:
October 17, 2014, 4:00 pm
Are the xdrive springs compatible with F31? If not, reason why?
