AGA Tools & Products - AUX-USB + Bluetooth Accessory Kit
by Tim Jones on February 6, 2017, 9:10 pm
AGA Tools & Products has two new solutions for BMW models: a simple fix for broken AUX-USB plugs and an easy way to make your BMW Bluetooth compatible.
aga tools aux usb kit
AUX-USB Kit
When an AUX-USB plug drops into the center console, it makes it impossible to plug in your phone and other devices. With the AUX-USB Plug Saver from AGA Tools & Products, you don't need to replace the console to fix the plug. Our spring steel, heat-treated frame secures the AUX-USB plug and prevents it from sinking into the console. Our AUX-USB Plug Saver matches the color of the console, making this a seamless and cost-effective solution.
Upgrading to a Bluetooth-friendly system can be pricey, if your BMW doesn't have Bluetooth capabilities. With AGA Tools & Products' Bluetooth Accessory Kit, you can play music and receive calls via Bluetooth in 3 simple steps. Cut the cord and bring your BMW into the 21 st century with this inexpensive fix that's easy to install and easy to use. For more information, visit http://www.agatools.com/part/audio-accessories- kits.
aga bluetooth accessory kit
Leave a Comment
3 responses to AGA Tools & Products - AUX-USB + Bluetooth Accessory Kit
listerone commented:
February 9, 2017, 10:36 am
save for later
Fjfrank1 commented:
February 9, 2017, 5:05 pm
Does it work with e65 models?
Sent from my SM-N920P using Bimmerfest mobile app
tim330i commented:
February 9, 2017, 5:16 pm
Which product are you asking about?
Tim
