521 - 540 of 2,093 Posts
I tried to pull a part # from ETK database, there's so many part numbers available (15+), I'm lost.
I guess adaptive LED headlight would be the best choice?
If you have a post-LCI 535dx, it looks like the part numbers are 63117343907/8 for the Euro AHL Xenons and 63117352481/2 for the Euro LEDs (but you should of course confirm this if you decide to go ahead). There is a very small difference in MSRPs between the AHL Xenons and the LEDs, so the LEDs might be the way to go.
While removing headlight, no chamber was water sealed except when you pull out xenon bulb. Is that what you talking about?
I was talking about if you have to disassemble the headlight. It happened to me before and it was a failure, it was leaking water after. Happened long time ago when angel eyes were retrofitted in old X5s. Scared to touch mine now, lol.
I drive 2015 F15 xDrive35d
There is no Euro X5 35dX in the database (it is probably a US-only model). Assuming that the parts for the Euro X5 30dX and X5 35iX fit, the Euro AHL Xenons are 63117317105/6 and the Euro LEDs are 63117442647/8 (this is a new part number for vehicles starting production this month).
you can checkout website: realoem dot com
This is what I found for a Euro X5 May 2015 production and EUR market: http://www.realoem.com/bmw/enUS/showparts?id=KR01-EUR-04-2015-F15-BMW-X5_35iX&diagId=63_1478
Adaptive Headlights
S524A=Yes
63117317106 - AHL-xenon headlight, right 1
Not included with headlight:
Control unit, xenon light
Bulb, xenon light with ballast unit
Headlight control module
63117317105 - AHL-xenon headlight, left 1
I post a Flap video in Bi-xenons, we are out of luck getting No Dazzle Tunnel feature. My SZL is otw and I will be happy to get Glare Free High Beam Assistance. If with incoming traffic left light switches to low beam and right stays high beam while moving away from driver, I am fine with that. Bottom line it will be better than what I have now.
What you're describing is called the Glare Free High Beam. The tunnel is part of this process, however, since our cars have flaps, the tunnel is Not created so while one headlight switches to low and other stays in high. The one that is high is still glaring the driver in front of you.
I thought KAFAS will move it away from driver !!! At least that was my understanding watching all those Bi-xenon glare free videos.
Someone, please help me code HBA on my F15.
This is what I've coded so far with no luck:
(BDC_BODY) FLA_AKTIVIERUNG --> LDS_in_A
(KAFAS2) FLA_ON_OFF --> FLA_on
(HU_NBT) HIGH_BEAM_ASSISTANT --> activ
There's no FRM ECU and I can't find FLA_AUTO_ACTIV
