Bimmerfest - BMW Forums
Bimmerfest - BMW Forums (https://www.bimmerfest.com/forums/index.php)
-   X1 E84 (2011 - 2015) (https://www.bimmerfest.com/forums/forumdisplay.php?f=142)
-   -   Looking for advice on 100k Maintenance items for daily driver (https://www.bimmerfest.com/forums/showthread.php?t=1301245)
wohcrag 10-26-2018 06:10 PM
Hello to all
I am looking for advice on 100 k maintenance items for my daily driver .
Like what is the favorite spark plug . Should the coils be replaced at 100k and with which ones. Etc favorite filters . Looking for what dependable brands all around value. Any advice would be appreciated.
2013 x1 msport 35i n55
jaydykeman 11-10-2018 04:41 PM
100k service
this is a fun service as you get to inspect lots of the car. plan on replacing both diffs with red line or similar 75-90 gear oil, transfer case oil which is special, -you have to remove the mount to drain/fill, but it is not hard....flush the brake fluid, replace the plugs with bosch-you don't need the bmws branded ones, they are the same-get a trans pan and 6 qts to the correct red-line trans oil...replace the pan and filter..you can get the zf brand filter from some of the on-line vendors-power steering canister as the filter for that is in the bottom of the unit-coolant drain and fill....*****....sounds like a lot, and it is a bit of work, but you will notice the results, and the front diff is critical as there is a bearing issue there...of course inspect the drive belt and all coolant hoses for cracking/softness-and replace as needed....hope this helps
wohcrag 11-16-2018 09:46 PM
Hey thanks alot for all the good info. I will be gathering my materials for this service soon. Have a great holiday season.
