I've noticed that my car shudders badly when braking while passing over larger road imperfections (expansion joints, potholes). My Integra is fine when I go over the same. Is there something wrong with my 525iT or is this just normal for the car?
Is it only after hitting bumps, or does it do it all the time while braking? Shuttering under braking tends to be warped rotors. How many miles on the car/brakes?LA525iT said:I've noticed that my car shudders badly when braking while passing over larger road imperfections (expansion joints, potholes). My Integra is fine when I go over the same. Is there something wrong with my 525iT or is this just normal for the car?
you could be correctPlaz said:You sure it's not just the ABS activating?
I'm not braking hard, usually just downshifting and gently braking to a stop (I'm talking about an expansion joint on the Main Street bridge over the 10 freeway in Santa Monica).Plaz said:You sure it's not just the ABS activating?
If you applying any brakes and go over a bump that's the ABS kicking in and you would only feel it throguh the pedal. It feels like the pedal is pushing back against you because it actually is. The brakes are pulsating so that they do not lock up on you. This is normal for every car with ABS, I would imagine that your integra is not equipped with ABS. If you feel a vibration under normal braking conditions at highway speeds that is most likely due to warped rotors as previous poster stated. You have driven more than enough miles to have warped your rotors.LA525iT said:I'm not braking hard, usually just downshifting and gently braking to a stop (I'm talking about an expansion joint on the Main Street bridge over the 10 freeway in Santa Monica).
Could be the ABS triggered, but seems like a much more pronounced shudder through the pedals.
Car has 18,000 miles on it, 1.5 years old and I'm the original owner.
LA I know exactly what you are talking about, it is the ABS activation but very odd in deed, not the normal ABS activation, but a whole front end shuttering, and does not stop after you go over the bump, until you release the brakes.LA525iT said:I'm not braking hard, usually just downshifting and gently braking to a stop (I'm talking about an expansion joint on the Main Street bridge over the 10 freeway in Santa Monica).
Dagoodagoo98 said:How can you expect every car to have the same exact ABS feel? That's like expecting every car to have the same steering feel. The know what ABS feels like when it kicks in on a car. I can't say that I can recognize the severity between this car and my previous cat but you should know what the ABS feels like and its as simple as that. Maybe there is a combination of the ABS and your rotors being warped.
When was the last time you guys changed your rotors? People you have bad braking habits (people who over brake or apply brakes by holding the brake down until they are at the speed they wish rather than applying brakes and releasing them allowing inertia to do its work) go through brakes and rotors quicker and tend to warp their rotors because they are always hot.
Exactly, thanks to you and the others for your replies, at least I know it is not just my car :thumbup:shabbaman said:I've experienced this in my car several times as well. It's as if the ABS doesn't *let go*. Usually it's an expansion joint or a mild pothole and usually I'm driving no more than 5 miles per hour or so. The ABS kicks in and will not *let go* until either the car is fully stopped or the mechanism is "reset" by taking my foot off the brake pedal.
Ditto!E39spd said:Exactly, thanks to you and the others for your replies, at least I know it is not just my car :thumbup:
My reply was constructive, the scenario you described are exact symptoms of warped rotors. Remember that the people on this forum cannot drive the car to tell themselves so they go by your descriptions. When a car has warped rotors, when you apply brakes at highway speed, 50mph and above, the steering wheel shakes from left to right and you feel the vibration in the front of your car until you let go of the brakes.E39spd said:Dagoo
Sorry, my rotors are not warped. When the steering wheel pulls left and right repeatedly until the brakes are released (even after the bump has long passed) and the whole car shutters badly at that same time, I know that it is not normal, have I complained, no, does it happen every time, no, but it does happen sometimes when I brake and go over a bump, and not heavy braking, not limit braking, but well modulated braking.
Rotors were replaced (full brake replacement) only 3k miles ago on my car and 10k miles on the 7.
Relax on criticizing others, we know what we are talking about.
Yes, not every car has the same abs feel, but whole car should not shudder, vibrate, or pull when abs kicks in (plus I have felt normal abs kick in on the car, so I know it is not the normal application).
If even you were driving my car when it happened, you would be quite alarmed the first time!
Be constructive, not destructive - Thanks
I wouldn't exactly call it eccentric. I would call it confused.norcal 528i said:I am just glad that other people find the ABS in these cars a bit eccentric.
I (and I assume other posters who have had similar problems) currently own and have owned other ABS equipped cars and have not experienced this problem with others. Why I should assume ABS is beyond me. Only because it seems recurrent amongst others am I inclined to think design of car and its systems, hence ABS.dagoo98 said:The fact that you brake and go over a bump should first clue you in on the fact that it most likely is your ABS kicking in.
I have experienced the speed bump problem in my old Land Rover. I guess it would be safe to presume that for a split second while the car is rebounding from the speed bump and the brake is pressed hard enough that a momentary instance of lockup is detected by the ABS sensors and begin to cycle the brakes.LA525iT said:I (and I assume other posters who have had similar problems) currently own and have owned other ABS equipped cars and have not experienced this problem with others. Why I should assume ABS is beyond me. Only because it seems recurrent amongst others am I inclined to think design of car and its systems, hence ABS.
I am sorry if I misinterpreted your reply, but it sounded a bit arrogant when I read it.dagoo98 said:My reply was constructive, the scenario you described are exact symptoms of warped rotors. Remember that the people on this forum cannot drive the car to tell themselves so they go by your descriptions. When a car has warped rotors, when you apply brakes at highway speed, 50mph and above, the steering wheel shakes from left to right and you feel the vibration in the front of your car until you let go of the brakes.
The fact that you brake and go over a bump should first clue you in on the fact that it most likely is your ABS kicking in. It also will not stop until you release the brake because that is what is designed to do, the whole purpose is to prevent the brakes from locking up and causing an unsafe condition. It forces the driver to release the brake and re-engage the brakes which ensures that the brakes will not lock up because of the bumps in the road. I simply was trying to explain that it was either your rotors being warped or your ABS kicking in, not quite sure how that's destructive.
I don't understand when people post here looking for answers and then get offended when others offer answers.
Thank you norcal 528i for understanding the intentions of my reply. :thumbup:
12-19-2004, 07:47 AMOK, so I feel I am an unfortunate expert with this subject.
First off, this is not ABS normal working. This is ABS malfunctioning if at all.
Anybody with this problem knows how an ABS feels like when it engages. This does not feel the same.
Believe me when I tell you, one month after buying my E39 this symptom surprised me when I came to a red light. I was about 40'-50' away, driving normal city speed. The car did not even slowed down. Right into the butt of the car that was standing at the red light. $3500 damage on my car. $1500 on his car.
Since then, almost 3 crashes into the rear end of cars in front of me.
Fact: it will usually happen in a slow speed. 3-5 mph. The vibration is much faster then the pulsating speed of ABS working correctly.
cure: replaced shocks and struts on front and rear ends. I also replaced wheels from 16" to 17" two weeks later. Since then, symptom almost completely disappeared. (Edit, 9/14/09: It was actually gone forever, I just didn't know it at that time yet.)
I have a theory of exactly how this happens. but it is way too long to explain in writing. (9/14/09 Edit: I am explaining it later in this post.) But it has to do with a "positive feedback loop" between wheel bouncing to the air, while abs activates at the wrong time, landing on the road just to bounce again and to activate abs again while in the air. It causes harmonic oscillation that will not stop because it continues to feed itself infinitely.
Not ABS, you can stop a car with ABS activated.
Not warped rotors. Warped rotors vibrates the steering wheel in high speed braking.
This symptom, happens in slow speed. Vibrate the front wheels (bouncing), and the car will NOT stop.
Of course, anybody who did not experience this first hand will think we don't know what we are talking about and we don't know how ABS feels.
Hope it is a little more clear now.
Is that fairly describes what you guys experiencing?
12-19-2004, 08:39 AM12-18-2004, 12:30 PM
When the first crash happened I was driving around 30mph, you know, just normal lazy driving from one traffic light to the next one. We were the only two cars at that stop. I started to stop at normal distance, the front started to vibrate. Since I was 'new' to the car, I didn't understand what was happening thought that is the ABS and that it will stop, but the car continued and 20' away I realized something is very wrong and I can't stop the car. I pressed the brakes as hard as I could, the car didn't even slowed down. Crashed right into that guy in front of me. I now know that if it happens you should quickly release the brake pedal and re-apply the brakes. This is THE one reason I would not let anybody drive my car, by the way! In most other times it just when speed is very slow, so you have time to react.Interesting explanation. How fast were you driving when the first crash happened? In my case it's never happened at speed more than 3-5 miles per hour, like you said, so besides the annoyance I've never really considered it to be a safety concern. If this condition happens at speeds greater than 5 miles I'd be concerned. Can you elaborate a little more about that crash that you had? Thanks.
At other times it was just crawling in heavy city (NYC) traffic when you drive bumper to bumper. You are closing a gap of 15' to the car in front of you, and this happens when you are 5-8' away... now you are in BIG trouble, right?... LOL. Only the experience from the past teaches you to quickly react by releasing the brakes and re-applying. Very scary.
This is definitely a safety issue, IMO.
12-19-2004, 09:04 AMIs it possible that your front shocks are gone already? Stock shocks are by Sachs. (I think the sport package also by Sachs.) But they don't last forever. I went to a few dealers and few other shops and told them I suspect my shocks are gone. They all told me that my shocks are good. One dealer mechanic even took it to a road test with me. Another SA took it with me to demonstrate ABS... I don't know of any way to measure shocks effectiveness. Its all subjective and comes down to "feel".
When I finally replaced the shocks, the technician was 'shocked' at their condition, The front shocks were so gone that I could compress them completely or pull them out easily with just two fingers!
If you have this problem on your car, then most likely you have bumpy roads where you usually drive, and chances are, your shocks worn out faster. Just like mine.
The contribution of the shocks to this problem is that they do not suspend/dampen the spring vibrations. The contribution of the wheel size is in its weight and tire wall height, which will affect the frequency of the 'bounciness'. My thought was that since I thought of this as a feedback, I wanted to break the cycle by changing the "oscillation frequency"...
I think replacing the shocks had more to do with curing this problem on my car then size of the wheels. How many miles do you have on your shocks?
07-17-2007, 12:29 AMKarlB, thats pretty much what I am thinking.
Here is my theory of how this happens:
1. I am braking at a speed that should not activate ABS. No wheel locking.
2. Front wheel hit a bump, and bounce to the air.
3. Since the wheel is in the air, it will now lock because there is no resistance. (the weight of the car does not push the wheel forward against the pressure of the brakes, so that wheel will easily lock.)
4. ABS will notice that one wheel is not turning, while the others do turn. Therefore mistakenly thinking that this wheel is sliding on the road!
5. ABS will start pulsating the brakes, in harmony with the bouncing rate of the wheels, therefore causing them to continue bouncing, just for the ABS to continue thinking they are locked.
TXE39, you said you have it on your Land Rover. I heard BMW owns Land Rover... ??? Just like they own, Mini, and RR.
You know that story of the soldiers marching on a bridge and the pace of their steps matched the "oscillating frequency" of the bridge. The frequency feed on itself vibrating the bridge so much that it destroyed the bridge.
I think that is what happening on our E39s. The cure is to change the frequency or to prevent it from even developing (shocks).
Any other thoughts/theories out there?
Oh, and I didn't have almost 3 crashes. I meant to say I had a "almost a crash" about three times since that ONE crash...
09-30-2007, 01:48 PMI actually had to pleasure of crashing my car into the rear of the car in front of me when that happened to me the first time. $3,500 damage.
Then I almost crashed into a rear of a 24' truck a few months later, and a few other close calls. I just learned that I have to let go of the brakes, and reapply the brakes quickly before I hit something.
And it was not the rubber bushing.
All the control arms were replaced, and it happened again, just not as often. Then I decided to replace the shocks. After replacing the shocks, the problem was gone. That was 60,000 miles ago and it never happened again.
(EDIT, 9/14/09: it is now more then 2 years later (meaning total 5 years), and still, it NEVER happened again. Problem solved. Gone.)
Checking the old shocks after they were out, they were completely gone. There was no resistance left in them. Zero. You could completely compress them while holding he rod between your two fingers.
09-30-2007, 02:27 PMIf you are still experiencing this. Fix it ASAP. Go to a good BMW tech, and have them look at the front suspension and fix/replace anything that is worn out - meaning, the obvious noticeable wear. If after that you still have the problem, than replace your shocks.
Good shock absorbers will STOP the 'bouncing'. Shut shocks = you are riding on springs. The car will bounce like a basketball.
Again, fix it ASAP. You can kill yourself or somebody else. Seriously.
(This guy finally got it! )So, someone on this thread earlier was talking about "harmonic oscillations".. not exactly the right description but good enough. If we think back to elementary diff eq. or physics, we would remember that you can never have harmonic oscillation in a system with any sort of damping, so logically the damping must be at fault (which it was).. Combine this with the fact that any fault in DSC/ABS is highly unlikely, and you have found your culprit..
Don't know why you guys got into this big discussion about driving styles a couple years ago, when if you just sat down and thought about it you would have found out the answer.
So... I started posting about this in 2004. I explained then and I will repeat again: YOU NEED TO REPLACE YOUR SHOCKS. Some argued with me that replacing the rubber bushing is the solution, but if you will read the whole thread, you will see that bushing did not solve the problem, or solved it only temporarily. The problem came back rather quickly. ONLY after replacing the struts/shocks the problem was gone. Mine is gone for 5 years already, never to return, EVEN when my bushing were shot.Exactly! You got it! That is exactly what I am explaining!
That was my post. Paying $3500, having my insurance go up, and almost killing myself on another occasion, made me very passionate about this issue.
I said a few times in this thread, that this is dangerous. Just a few days ago I told someone on this thread to fix it before he could kill someone or himself.
***8230;. and guess what. Just yesterday, Splooge had an accident. Just like the one I described.
Sorry about your car, Splooge.
Interesting explanation. How fast were you driving when the first crash happened? In my case it's never happened at speed more than 3-5 miles per hour, like you said, so besides the annoyance I've never really considered it to be a safety concern. If this condition happens at speeds greater than 5 miles I'd be concerned. Can you elaborate a little more about that crash that you had? Thanks.MatWiz said:OK, so I feel I am an unfortunate expert with this subject.
First off, this is not ABS normal working. This is ABS malfuntioning it at all.
cure: replaced shocks and struts on front and rear ends. Replaced wheels from 16" to 17" two weeks later. Since then, sysmptom almost completely dissapeared.
I have a theory of exactly how this happens. but it is way too long to explain in writing. But it has to do with a "positive feedback loop" between wheel bouncing to the air, while abs activates at the wrong time, landing on the road just to bounce again and to activate abs again while in the air. It causes harmonic oscilation that will not stop because it continues to feed itsef infinitly.
Not wraped rotors. Wraped rotors vibrates the steering wheel in high speed braking.
This symptom, happends in slow speed. Vibrate the front wheels (bouncing), and the car will NOT stop.
Is that fairly describs what you guys experiencing?
