i updated all ECUs with E-SYS 3.33 and PSDZ 4.17.13 to I-Step 19-03-552 for my I001 (i3S).
Now i have the problem that my NBT is working but the Navigation won't start. The screen always displays "loading" and when i put in an usb Stick with new maps from BMW-Download Manager for my car it says: "Connect USB-Device with correct unlock code".
Can anybody help me what i have to do ? I used E-Sys without EST token.
I must say, I dont really know how E-Sys handles FSC codes(which are codes that enables features), when doing an update. If it has just updated your NBT2 without first saving the FSC codes(which might be possible), then the navigation will not start because the FSC is missing.
You can check the FSC status with E-sys under the Comfort mode tab. You can then paste the result in here, then it is easy to see if FSC's are ok for navigation and voicecontrol(which I guess does not work either?)
I think you are right. Speech recognition wasn***8216;t also working. I will head to my car and report back with the readings.
Update: Here it is:
--> Status von "3" Steuergerät(en) gelesen <--
EPS[DiagAddress=48(0x30)]
WBY8P610907D00290
RootCertStatus not available
SWSigStatus accepted
SWTApplications
AppID 189(0xBD)
UpgradeIndex 1(0x01)
SWTType SWTclassic light
FSCStatus not available
FSCCertStatus not available
HU_NBT2[DiagAddress=99(0x63)]
WBY8P610907D00290
SWTApplications
AppID 158(0x9E)
FSCStatus rejected
AppID 160(0xA0)
FSCStatus rejected
AppID 368(0x170)
AppID 111(0x6F)
FSCStatus rejected
AppID 159(0x9F)
FSCStatus rejected
AppID 156(0x9C)
FSCStatus rejected
AppID 229(0xE5)
FSCStatus rejected
AppID 288(0x120)
UpgradeIndex 61(0x3D)
FSCStatus rejected
AppID 323(0x143)
FSCStatus rejected
AppID 366(0x16E)
FSCStatus rejected
AppID 367(0x16F)
FSCStatus rejected
KAFAS2[DiagAddress=93(0x5D)]
WBY8P610907D00290
SWTApplications
AppID 126(0x7E)
FSCStatus accepted
AppID 190(0xBE)
FSCStatus accepted
AppID 191(0xBF)
FSCStatus accepted
E5 - M Lap Timer
6F - Satellite Tuner
143 - Apple Car Play
I know why i have these codes in my Headunit. I used FemtoEVO before to activate Full Screen Apple Car Play. My guess is, FemtoEVO coded them into my NBT2.
Beside that, my NBT2 is working again. I used FemtoEVO to activate all my FSCs. Everything is fine, but i think FemtoEVO made weired changes to my headunit. :eeps:
My guess is that for FemtoEVO to activate carplay and others, it needs to change the rootcertificate in the NBT to accept the self signed certificates, and therefore also needs to load the fake FSC's for navi and speach, and that is why they do not work anymore. If you take you car to the dealer, and have them update the car next time, your navi and other original stuff will work with original BMW FSC codes, but carplay will not work until you do FemtoEVO magic again
Quick one, did BMW not update the latest software with a mechanism to block false self signed certificates? Loading the fake ones will result in the same issue as you run the latest software version. Also how do you clean the blocked certificates? You need telnet to do a persistent state cleansing with tool32 as status is rejected and the fake FSC will be newer then the original set so how do you overwrite? Interesting to learn how you resolve.
Before that i had an Audi A5. To do a little fiddling i opened up the Headunit and mounted the harddrive under Linux. The OS was a qnx and if i get access to the filesystem it is easy to generate public and private keys if i find the root cert. But i am happy it is running now. So.
But if somebody could shade a bit of light in using e-sys or other BMW tools to do the job (ista / Rheingold) that would be fine... :angel:
So i was talking to the guys from FemtoEVO and they said "Component Protection" is active. They have a routine to make it reversible with the Backup Files from the App. So they made the thoughts i didn't when updating !
Thanks Shawn for your help and engagemant. You really do know alot. FemtoEVO is writing a 170 FSC Code. I have a file for FemtoEVO (FSC_7D00290_0170007F.fsc) - thats exactly what it's used for.
I am impressed.
Interesting - but a pain in the ass to cope with these DRM.
Related Threads
BimmerFest BMW Forum
11.4M posts
754.1K members
Since 2001
