Bimmerfest - BMW Forums - View Single Post - Build Log: M57 X5
Old 04-30-2019, 12:09 PM
ArgentoCarNut ArgentoCarNut is offline
What was that?
Mein Auto: 05 M3, '13 TLC, '11X5 35i
Originally Posted by ucsbwsr View Post
I don't really understand this comment?
You will want to check if your X5 has provisions for the entertainment system. Searching RealOEM I didn't see any wiring harness specified for the rear seat entertainment so I assume it's part of the main harness which means all X5s would have it and consequently this "kit" can be integrated by installing and likely some basic VO/module coding.
If you want to check your X5 for the wiring; removing the front and rear side panels of the console and then the rear console panel, if you have the wiring you will see a larger unused connector that locks with one of those 90 degree arms (IIRC) it is the "input" for the DVD player.
Iíll go at it and check this weekend.
What are you asking for the unit?
Sent from my iPhone using Tapatalk
