Bimmerfest - BMW Forums - View Single Post - Fuel Mileage - puzzling discrepancy . . . indicated vs. actual/manual
Old 09-05-2019, 08:34 AM
RPsX5d RPsX5d is offline
Mein Auto: X5 35d, MY2011 150,000 mi
I wonder what (if anything) would cause the K-factor effect to change? i.e. once set to match manual calculation, why would the two readings drift apart?
For several years, my indicated reading and manually calculated values pretty much matched . . . about 22.5 mpg. This value held for a very long time (several years). Then suddenly the indicated dropped to about 18 mpg, and as I indicated above I didn't repeat the manual calculation . . . I assumed something was going wrong, however, no fault codes.
I am now rechecking indicated vs. manual . . . two tanks done . . . both showing the indicated around 18 mpg . . . manual about 22.5 mpg, same as what it has been for a very long time.
One possibility is after resetting the K-factor your drive profile has changed substantially, re-adjust the K-factor to match the new drive profile. In my case, the drive profile did not change, same fuel station, etc . . .
