Bimmerfest - BMW Forums - View Single Post - help with secondary air system
Old 06-10-2020, 05:42 PM
[email protected] dmytroa@telus.n is offline
Dmytro
Mein Auto: 1998 z3
Thanks for the reply, not dealing with this issue as promptly as I should, apologies. So I hooked up my Schwaben scanner, and I'm getting a reading from the coolant temp sensor, reading approximately ambient temperature, so I think it's not a sensor/lack of signal problem. Rightly or wrongly I've become convinced that it is the elusive (big orange) 40 amp. fuse number 48, which is marked in the fuse box as "fuse not in fusebox, under steering wheel". I can't find it, any advice as to where to look (pre 9/98 Z3 2.8) would be much appreciated. Is it perhaps wrapped in one of the wire bundles? Thanks in advance.
