Bimmerfest - BMW Forums - View Single Post - Power output under different temperature for N55 335i
Old 03-09-2018, 03:33 PM
Matthew424 Matthew424 is offline
Mein Auto: 2015 328 X-Drive
Originally Posted by N52 Moistenor View Post
First off, that little chart is not an accurate way of determining how much power your car is making. Yes, different temps affect performance (below 100c or above 110c and you lose some power) but it could’ve been something simple like how you apply the throttle. Easing into the pedal gradually in manual mode will help the turbo respond better than just flooring it right away. Try it.
I agree. I think the OP may also be describing turbo lag, where the RPMs need to be build (so the turbo spools up) and you feel the surge in the power.
2015 BMW 328 X-drive : Dinan Stage 1: Dinan Exhaust: Dinan Springs: Dinan Supplemental Ride: Dinan Intercooler: Dinan Pedals: BMW Performance Headlight Bulbs : Bimmertech Front/Rear Cameras: Bimmertech MirrorCast : BMWCCA Member #516886 (Feel free to use my BMWCCA # for a referral).
