Bimmerfest - BMW Forums - View Single Post - 18d timing chain maintenance
Old 09-11-2018, 09:23 AM
Yukoner Yukoner is offline
Mein Auto: 2011 328i x-drive
Originally Posted by Rotorblade View Post
Thanks.
I'll start by halving the oil change interval which is recommended regardless of the problem. Some say it helps.
I've also heard that keeping the intervals within spec (or earlier) is better. Also not rat-bagging your car will help. But, in the end, it may just be a roll of the dice as to whether yours fails or not. It's a known issue, but I don't think it's THAT common. Like I don't think your odds are 50/50 or anything nearly that grim.
Not even sure if -40 degrees is cold anymore ?
